cog
Everything posted by cog
  1. Why not replace the blocks as well ... while you are at it.
  2. She may be right, but it looks like there won't be much of a health hazzard ...
  3. I love these subs, and often considered buying the one from Krick as it is the "sailing" one, but lacks a lot of detail. Your build, has got me thinking again. Especially with the added PE it will most certainly make a beautiful build. I was wondering with regards to the lighting: Wouldn't the cables run on the inside of the hull, especially during that period of shipbuilding. You could make it less hard on yourself with regards to not making them invisble if you let them run on the inside instead of on the outside ...
  4. So your not sanding, but milling ... very confusing all this talk about this days, and dust On the other hand I love the way you are making your build log another example on how one can build a model from scratch ...
  5. Questions, questions, questions ... decals ... white text. You make outlined text, the outline should have the same colour as the background you put the decal on, the surrounding area of the decal to. Not that hard I woul say, just to come up with, I needed it a while ago, hence the quick response I'll look into the mast. You'll need riging from the yard down (flags and such) wire to the readio room etc. Look at the plastic builds!
  6. Fair job, mate. Why did you use the plastic for the superstructures anywas. It looks like one big lump of brass ... does it come in "all brass" too???
  7. As time evolved, the wood quality of the models decreased (not only for wooden ships). Lasercutting only made things look easier. You should realise you didn't start a jigsaw which you've found out by now, but besides the manual in the box, you've got a "walking" knowledge base at your feet here at msw. Use it to your advantage, and your build will be a lot of fun
  8. I am still looking for the minor defects. Marvelous detail as we have come to expect of you
  9. Glad you got that wrapped around. Next time build a larger scale, it will be easier by far on the soldering. You might want to get a larger dining table too in that case. Your railing looks actually rather good, just enjoy the view
  10. Ofcourse you can, but you need water to do that maybe alcohol will work too
  11. Just take care not to heat it to much ... it will burn away, so no torch. Keep in mind it will deform more easily too
  12. But that wouldn't be fair, it wouldn't be a tube as depicted in the "brochure". Besides, RGL wouldn't stand for it!
  13. I know, but how you will shape it and make the tube, isn't laddy
  14. Thanks for your warm welcome mate Roll the PE around a metal rod ... that's the easy (not very creative) part. Getting it glued, without the rod inside, and keeping it round ... now that is a different muddle. You do, however, get the hang of it when I look at the picture. i am more curious as to how you will make the open end for the tube, that is a lot harder
  15. That should be enough if you are a fervent Ikea modeller ... They just would have to cope now, wouldn't they ... When I look at Musashi (old tool) with FlyHawk and Pontos PE sets, that would be about the same, instruction-wise that is. You just start at the beginning and muddle through. A bit like every model you've made ...
  16. Iwould sooner try my hand on tissue,or rice paper as those are thinner. Tissue ... you can even peel layers ... just ideas at the top of me hat
  17. Then the question arises, will she be displayed in a museum or at a navy board ... I presume neither, so you can do what you want
  18. Love the way the rigging is progressing. Not so certain about the flag. Looks a bit ... crumpled. Will you show her with or without sails? If with sails, furled or unfurled? (I know, it's easy to comment from the sideline)
  19. Not surprisingly with earthen-ware druxey. Sorry Pieter couldn't resist it either.
