Everything posted by Gregory
Is there an easy wooden tall ship out there to build?
Gregory replied to thegrindre's topic in Wood ship model kits
Any wood ship model kit is going to be complex.. But the way to keep it as simple as possible, is to reduce the armament, and reduce the rigging.. Just to get a feel for the wood kit building process, you might start with something like one of these kits from Model Expo: LOWELL GRAND BANKS DORY WITH TOOLS 1:24 SCALE It's currently bundled with a nice little tool set. Only $49 MODEL SHIPWAYS MS1457 18TH CENTURY LONGBOAT You would get a feel for how fast the building process is, then come back for ideas about a bigger, more complex project. There should be a build log or two for the kits mentioned, and you can see how others did. -
You're off to a great start.. How much experience do you have with wood ship models?
- 29 replies
- constructo
- prince
Just another little nit pick: It would be nice if modelers would consider renaming their pics before uploading them. Seeing a lot of " 20200504_152930.jpg " & etc. is distracting. In Windows, you can rename a batch of pictures by highlighting all of them, right-click to rename- and give them something short and sweet like " Schooner ", And they will all be named " Schooner(1) , Schooner(2) etc.. Just a thought..
Finished up my quarterdeck bulkhead project. The scrap pile grew considerably while refining this.. The cupola, also inspired by Greg Herbert and David Antscherl's Speedwell, was more challenging for me than I expected. Still trying to avoid paint, I settled on a wood mold that I covered with copper leaf.. The patina was created by enclosing the part in a sandwich bag with a chopped boiled egg.. Go figure... What to do next.. Capping rail? Tiller ? Cannon? I have already fiddled a bit with all of those.. Now to get it done...
One of the detail projects.. The kit plans show an unlikely door to the great cabin. Scaled from over 7 feet, it seems there was some misunderstanding about the average height back then, or even now. Here is my prototype for the bulkhead and door. I borrowed some dimension ideas from Greg Herbert and David Antscherl's Speedwell , where I calculated the door height to be about 4'7". Stooping a bit as you step down, would seem to be the order of the day. I plan on refining this a bit more and will present the final design later.
I think you will find most of the CNC work in the scratch build topics. I think the biggest challenge for kit builders, for me anyway, regarding CNC, is getting the design of the part from the kit plans to a cutting file to drive the machine. This has been true for me with my laser cutter. I have spent more hours than I want, learning to use the software to get the kind of precision and results I want. I have one of those little CNC machines that I haven't got out of the box yet. Instead I went ahead and focused on my laser work, and it has kept me busy enough, that I haven't been in the mood to tackle a new learning project. While most members here are always happy to help, they also want to spend their time building, and not teaching CNC or laser cutting techniques. They may not get past the point where they talk about their $2,000 machine and software that is $100 monthly subscription. A great example of the high end of CNC work is from a member here, HJX, is doing the CNC work for the Winchelsea kit, group project. Your best resources may be another online group that is focused on CNC work. Just because they may not be building model ships, the technique would be the same. Welcome to MSW!
Hard to believe it's been over two weeks since an update, because I have been doing some work almost every day, if it has only been to lay a plank or two. As I mentioned, I'm spiling the planks that are curved and it takes some tweaking to get a good fit. The scrap bin has grown considerably. Here is the last plank for the port side ready for gluing. The finish on the bow, while not perfect, is not as lumpy as it appears in the photo. The grain of the wood and lighting create a look that is somewhat unflattering.. But I know you all know how that goes. I'm Satisfied with the fit. I decided to go with one drop plank on the bow. While they usually show up higher on the bow, I said " what the heck " . Being close to finishing the side at this point, my laziness got the better of me and I decided to make one plank instead of three. Port side done. Not a lot left to do on the starboard: ... and I'm looking forward to working on the other aspects of this build, that aren't as repetitious as the planking.
Not an easy challenge for the first time, and YT's method is certainly an option.. Take a look at the Knight heads for Chuck's Winchelsea build. While the project comes with some laser cut starter pieces, imagine cutting out those shapes with small files and chisels. A rotary tool might be useful, but requires a lot of caution because they tend to run away and cause damage. Then it is a matter of fine tuning them.
