Everything posted by druxey
Stealers
druxey replied to Sheerline's topic in Building, Framing, Planking and plating a ships hull and deck
You have a great attitude! Part of the problem you have is that the hull form is a very full one with round bow. This is the most tricky shape to cover neatly, but it can be done. As you've discovered, there's lots of advice available here.- 23 replies
- hms victory
- corel
Stealers
Do also read one of the planking tutorials on this site. It will help you get this planking business in perspective!- 23 replies
- hms victory
- corel
I think rubber cement to fix the paper pattern to plastic should work OK without issues of water-based adhesives. Lovely trailboard work!
- 2,699 replies
- heller
- soleil royal
(and 9 more)
Just make sure that the printout on the transparency is 100% without distortion! I used a marked stick laid along the centerline of the model to ensure that the beam spacing stayed on track.
- 889 replies
Cutter Grace 1763
druxey replied to tabycz's topic in CAD and 3D Modelling/Drafting Plans with Software
The triangular section would accommodate the swing of the tiller heel and contain any water that was forced pas the rudder coat below. The aft part (colored blue) I agree would be storage space with a hinged lid, perhaps. These spaces would be separated by a divider, unless you go for the fresh halibut theory! -
While the CNC results are unarguably excellent, they lack the irregularity and sharper edges of manually carved works. This, of course, is simply a personal observation and opinion. Manual carving seems, to me at least, more 'soul' in its imperfections. I suppose such idiosyncrasies could be programmed into CNC!
- 589 replies
- le gros ventre
- cargo
Ripping Planks - what I've learned from others
druxey replied to glbarlow's topic in Modeling tools and Workshop Equipment
Using one's hands, although potentially dangerous, gives one a better 'feel' of how stock is feeding. I often rip two thirds the way through, then flip the board over to complete the cut so that my hands never get close to the blade. Still have all ten fingers! -
If you are proficient at PhotoShop, consider 'fading' the background image so that it doesn't distract while supporting the model. The image that you posted in #1334 would work really well if you de-saturated the colors. Just a thought, Steven.
Some days it's better to walk away from it.... Obviously today was one of them! A new start tomorrow.
Translation help needed - Renaissance German
druxey replied to Louie da fly's topic in Nautical/Naval History
'erkofft' perhaps? Bought? -
Vielen Dank dafür, Karl! Nice to see a ship modeler's life work exhibited.
