Everything posted by druxey
Sorry, folks, but I respectfully beg to differ. The planking runs at the bow don't look right to my eye. The garboard strake runs too far up the bow, causing crowding further up the bow (if it were the right way up!). See my sketch for what I think would be closer to the way it was done. Others have already commented on the plank butt scheme, which seems random to me. However, ultimately the result has to please the builder.
That last photo, with the height of the keelson, gives one a real appreciation of both the original ship's structure and your re-creation of it, Ed.
- 3,618 replies
- young america
- clipper
From contemporary models, the wash cants appear to be composed of planks laid diagonally, as Dan has shown.
what is the ideal modelling table?
druxey replied to AON's topic in Modeling tools and Workshop Equipment
Better smuggle your new stuff in using plain brown bags, Alan! -
That is probably one of the most tricky strakes in the whole build. Your scratch molding cutter worked very well.
- 1,449 replies
No apology required. Curve - I mean curse - spell-check!
- 889 replies
HMS Ocean 1898 by tozbekler
druxey replied to tozbekler's topic in - Build logs for subjects built 1851 - 1900
Very nice! -
From personal experience, I find it far easier to cut the sill scores before erecting the frames. The drawback is that one needs to be exceedingly accurate in the positioning of the frames vertically. If 'off', it will throw the line of the ports out of whack. The reasonable compromise is to temporarily erect the frames, mark the sill line out, take the frames off and then cut the scores to the mark-out. After permanent re-assembly everything should line up perfectly. Small silly point: bridle is the word for the foremost port, as in horse's bridle. Not bridal, as for something belonging to a principal player in the cast of a wedding!
- 889 replies
ancre LE BONHOMME RICHARD by Jeronimo - FINISHED
druxey replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Impressive battery of guns, impressive work, Karl!- 662 replies
- bonhomme richard
- frigate
You'll probably find, with wood movement over time, that the seams and treenails will 'read' more than they do right now.
- 1,215 replies
- sloop
- kingfisher
I wonder how awkward it was to 'hook' the propellor in order to raise it?
- 346 replies
- terror
- polar exploration
Are you planning to actually have the raising mechanism work? The assembly so far looks terrific.
- 346 replies
- terror
- polar exploration
Removing paint
druxey replied to Don Quixote's topic in Painting, finishing and weathering products and techniques
Yes, please be very cautious using solvents like acetone. Plenty of good ventilation, no sparks! If you have a solvent-use style respirator as well, even better. -
Decisions, decisions.... It's always a hard thing to choose, isn't it? Either way, I'm sure the result will look great. Your overhead picture gives a good impression of the complexity of even a small sixth rate's construction. I bet you are glad you aren't building a 74.
- 1,449 replies
