mtaylor
Moderators
Everything posted by mtaylor
  1. Super nice work, Ben. Interesting find from Druxey... learn something new here everyday.
  2. A feast for the eyes, Marsalv. Looks great.
  3. No words, Frank. Whatever say would just be repeat of everyone else. This is beautiful.
  4. Good on you, Kenny. Sometimes being paranoid is a good thing.
  5. The monographs give a good history of the ship and depending on the monograph, detailed plans with lots of notes on the ship's construction.. There's some monographs only suitable for solid hull as they don't have any below deck info. Others, give you everything in the way of plans... including framing. Note of caution.. these monographs are basically how the full size ship was built and are really not an instruction manual on "do this... do this next, etc." Having said all that... the monographs are definitely wonderful books for reading and great reference works.
  6. Kenny, If you haven't done it.. make copy of anything your using to cut like the frames. It may save you some grief if you mess up a frame. Just the voice of experience here.
  7. A very versatile tool. I've used it for tapering my planking as well assorted odds and ends where I needed a small power sander.
  8. Plastic is easy... it's the PE that's hard, Carl. You're doing great with it.
  9. Welcome to the wonderful of "re-do's" or "do-overs". It pretty much seems to be a way of life around here.
  10. Not a "little progress", Giampiero but a great progress. Looking superb.
  11. Thanks Gérard and Daniel. The height surprised me also but I did a dummy cutout and that is what fits. Moxis, you have the right one which fits what Gérard said about it being the top one in my picture.
  12. I'm sort of stuck here. I'm seeing two different styles of carriages for the French 8-pdr cannon. I'm also under the impression that this applied to the 4-pdr's also. See picture. The upper one has both axle trees connected by a beam and the side supports sit on the axletrees. Note the rounded cutout at the bottom of side support. The lower one has a large "plank", if you will, that side sit on and then this is affixed to the axletrees. Which would be right for for the 1760's-1770's? I have detailed plans for both and just need to find out which one to use.
  13. The old lanterns were either large candles although some were oil fed via a wick down either in the Great Cabin, or the deck below it. So, the flame would have been yellow. This era was before the red/green navigation lights and the lanterns were more for position within the fleet at night. There was somewhere, a small lantern that would come out after dark for a couple of hours to inidicate it was ok for the crew to break out their pipes and smoke... the smoking lamp. So clear glass and not colored. If illuminating via LED, then use a yellow one.
  14. Email AL. Use Google translate to translate into Spanish as apparently they don't respond much to English emails.
  15. Hello Dave,
  16. Looking good, Bob. Just curious... are plans proper size? I had some distortion in the Licorne plans.
  17. Hello Miles, Welcome to MSW. By all means, when you're ready open a build log, as it will be the best way to get help and also over those "blah" moments. Semper Fi.. '66-'70 HMHT-301 & HMH-463 (RVN)
  18. Congratulations on a beautiful build, Sjors. Very well done.
  19. David, Have a look here and follow the links on some of the posts:
