Everything posted by mtaylor
Ron, Great looking ratlines. It's tedious and time-consuming but they add so much to build when done right. Yours are done very right!!!
- 240 replies
- supply
- caldercraft
Grant, Fantastic looking blocks even If they are "proof of concept". I like the mods to the box.
Augie, What can I say... besides what a great and fantastic build. I know you'll do a great job on Confederacy. And we'll try to keep moose, mice, popcorn, and assorted other topics away from her. So, here's the obligatory emoticons: and some fireworks
- 1,668 replies
- syren
- model shipways
Tarawa03, I can't answer your questions as I've not done this model. I'm sure someone else will. Have you given any thought to doing a buildlog? It's a ready made way to get help and answers. It will also leave a legacy for anyone else who buiids this kit. They'll see your problems and solutions.
- 49 replies
- pinnace
- Syren Ship Model Company
Thanks guys. Aldo, the pic shows a square section chain wale.... I think. And French ships had their differences.. <sigh> which is both wonderful and an aggrevation. It was pointed out to me here: http://modelshipworld.com/index.php?/topic/3032-chain-wales-and-gunport-linings-french-ship-question/ That others have seen the same thing... sometimes square, sometimes profiled. I'm pretty much decided on square-ish instead of carved for this wale. Meantime, back to sanding and squaring away the gunports....
Actually, you're not taking up anyone's time... Research is a big part of scratchbuilding and kit bashing, so why not include it? It will certainly help anyone who follows and also, gives the rest of us some insight and possibly answers to our own questions.
- 346 replies
- terror
- polar exploration
Amanda by Tblack - FINISHED - RESTORATION
mtaylor replied to TBlack's topic in - Build logs for subjects built 1851 - 1900
Hmm... she looks to be a clipper to my eyes. Might have a look at Cutty and Harvey builds for ideas on the missing bits and pieces. As for weathering... check the painting section and also, have a look at Sailcat's Cutty Restoration, Dafi's Victory, and Frank's Supply in the Kit Builds. Might give you some ideas. I know there's other builds doing serious weathering but I'm not finding them at this moment.- 40 replies
- restoration
- finished
Joe, I remember that also about Hahn. But in this case, the chain wale (upper red arrow) runs the length of the hull. I can't imagine it having that profile the entire length. Nor can I imagine a transition point near the mid-section. The blue arrow points to the mid-section area which is where the profiled part is from the plan in the previous post. The transition areas would be right at the rear-most forward deadeyes and around the area of the main mast. Maybe there is a change in profile there...??? I have to admit, this isn't the most detailed set of Hahn plans that I've seen. Probably the least detailed. I'm thinking it's probably squared and he drew a profile in. I don't have that particular NMM plan (6213/39) to verify. I have the others but the cross section isn't on them. Nor is there a head-on drawing as Hahn did on his other plan sets which would let me see the profiles.
Mercury by DSiemens - FINISHED - BOTTLE
mtaylor replied to DSiemens's topic in - Build logs for subjects built 1801 - 1850
So much impressiveness in such a tiny ship, Daniel. Holes in the chainplates??? Are you going to make miniature deadeyes??? -
John, Have a cold one of your choice. Splice the main brace and all that. That is one sweet coppering job. And you say you've done it before???
- 2,250 replies
- model shipways
- Charles W Morgan
- 1,668 replies
- syren
- model shipways
Running away is not permitted until a) the ratlines are done, and we see pictures!!!!! The rigging spiders need guidance and if you run away, no one can predict what they'll do.
- 1,873 replies
- occre
- san ildefonso
NIce work Matti. Don't try to get too precise in the cutting of the towers using the plans. As I recall, I cut close on the angles and dimensions and then had to spend much time fitting them exactly into place. Any tolerance build up in the hull, planking, etc. will throw off what the plans says for dimensions.
Nice fix on the gunport. Can we blame some evil shipbuilding fairy for filling in the gunport when you weren't looking?
- 1,319 replies
- caldercraft
- Victory
NIce etchings, Clare. It's probably a good idea to revisit your process with the eyes of a newbie. I think most of us, after having an early success either miss a step or aren't as careful as when we were first trying a process out. I hope it works out and you can get some repeat success.
I've hit a bit of a dilemma on my Licorne build.... chain wales, sheer strake, and gunport linings. The plans show the chain wale and by inference, the sheer strake as being contoured (red arrows). The photos of Hahn's build show them as being more of a square cross-section. Also, the pictures of the build show the gunports as being unlined (blue arrow). I've looked at other French ship models and I'm seeing a mixed bag here. No consistency. Any thoughts would be appreciated.
Thanks for the warm words. It's good to be able to spend some quality time in the shipyard. I've hit a bit of a dilemma.... chain wales, sheer strake, and gunport linings. The plans show the chain wale and by inference, the sheer strake as being contoured (red arrows). The photos of Hahn's build show them as being more of a square cross-section. Also, the pictures of the build show the gunports as being unlined (blue arrow). I've looked at other French ship models and I'm seeing a mixed bag here. No consistency. Any thoughts would be appreciated.
Door hinges
mtaylor replied to src's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
Sam Some folks use black paper, others foil. I'm not sure where you'd get black foil, though. Worst case, heat the brass to red and then then hammer it thinner.
