Floyd gave a good explanation of the messengers.......if you want to see more,  go into Dafi's Victory project.  somewhere in the middle of the log,  he shows these ropes and their function.  she's look'in good Jesse.......very nice progress.   any tool is a good tool,  if it does the job. ;)  I don't even own one.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Dave, I'm not sure. This is how close the instructions show them. If I remember right this was discussed some on Dirks and several other Syren builds. Don't remember the details of the discussion  but everyone agrees that everything is very close together here.
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Making a little progress. Made the boarding panels, hammock cranes and boards. Cut a strip of card stock paper and marked the spacing for them off of the instruction sheets. I have had to re-glue these many times as I keep bumping and snagging them. I wonder how much of a problem I'm going to have with these as the build continues.
Jesse
Continued.....
look'in really nice Jesse.  are you going to add tulle netting?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nicely done JesseLee. Your jeweler's touch is showing my friend, splendid work.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Hi Jesse -
When I was adding the netting, I found that a couple of small dabs of super glue worked very well to hold it in place.  Be sure to get the netting all the way down to the bottom of the hammock cranes and not leave a big gap between the netting and the rail.
Your model is looking very very nice.  I admire the quality of your work.
<<Gary>>
current build: SYREN
nearly done:  Fair American, Benjamin W. Latham
future builds:  Emma C. Berry
completed builds:  Rattlesnake, Newsboy, Sultana
Thanks for the likes and encouragement. Yes, I'm working on the netting now.
Jesse
Making the netting. Taped a section of it down flat. I cut out a guide from a sheet of paper. This took several tries until I got it that fits in the cranes the same size of the netting. Once this was checked, double checked and triple checked I used the paper as a size guide for the netting. I laid it down over the taped down netting and carefully stretched thread along the edges of the paper guide taping the ends of the thread down. (Somehow missed getting a shot of this step)
When I had all 4 thread sides in place I used something called Fray Check I picked up in the sewing section at Walmart. to hold the thread in place. This made a little bit of semi-clear places along the edges but thats ok. After cutting out and tying the netting all around alcohol was used to dissolve the Fray check and remove that stuff out of the netting holes.
This all took me much longer to do than I expected. I touched up some edges with CA glue where the netting looked pulled away form the rope. I realized too late that I probably used one size too large threading for this net siding but I'm gonna let it go like it is and be ok with it.
Jesse
Netting looks quite nice JesseLee.
Cheers,
                       VOC Ship Surabaya
Merry Christmas to you and your family and a good 2018.
Cheers,
                       VOC Ship Surabaya
Got the hammock netting installed. Didn't turn out as good as I would like. My camera doesn't capture the details I can see. I would suggest if anyone ties the netting to the rope edging use a much finer thread. Mine had too large of knots everywhere I tied one. Most of it is hidden though.
Went on and tied the longboat on. was worried it would be in the way of trying to tie to the pin rails but then thought that it might be just as hard to tie it down later too.
Jesse
Nice tutorial on how you did your netting Jesse.
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
I agree with everyone Jesse......the netting came out great!  I'm sure you plan on adding the rolled up hammocks......wait till you do that to make a final decision.
very well done my friend!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Tried to use the open hearts supplied with the kit but every one broke or split. I cut out my own from wood disks from Hobby Lobby. Theses are very thin layered wood disks so they had the strength not to break. Got the open & closed hearts ready to add onto the Bowsprit.
Jesse
Bowsprit, Jibboom & flying Jibboom assembly.....
Attached the hearts.
This seemed to take up more room than the pictures and instructions show. It was like I made the ropes for the hearts too thick but I didn't want to tear it all up and start over. I'm going with what I got but wish it all fit more snug like the pictures and diagrams show.
Jesse
Edited by JesseLee
Bowsprit, Jibboom & Flying Jibboom all assembled and glued into place. Figurehead glued on. Could not get a good close-up shot of it like I wanted.
This is the part of the build where I have to be extra careful because I always bump, snag and break things that stick out. I actually delayed this step until now for this very reason.
Jesse
Very nice progress JesseLee. Your netting looks just fine and I'm especially impresed by how great the ship's boat came ot.  The hearts look equally marvy and don't fret about the ropes being a tad too large, it seems you are managing alright.
Cheers,
                       VOC Ship Surabaya
