Thank you very much to Druxey, Tom and Crackers,
and all the "likes"
Druxey,
yes I thought about modifying the 1:144 figurines already, but then gave up, because they are just too small. Second thought was if possibly it could be done to scan in larger scale figurines and reproduce in any desired scale with a 3D printer, although I have absolutely no experience with that
Tom,
thanks for joining in to this log, and for your appreciative words
Crackers,
wonderful figurines, I agree, they would be perfect, if in the correct scale.  Presume they are about 19 mm high (H0 scale), which is too high for my application, but good to know....., may I kindly ask where you have found that source, even if not available in Germany ?
Nils
Just a reminder...
the scale 1:144 figurines are only of this hight (relation to my pointer finger)
Edited by Mirabell61
Current builds
-Lightship Elbe 1
Completed
Many thanks to Mark, Crackers and Bill,
Mark,
I just had some luck on the web Ebay-fleamarket with Scale N (1:60) figures, a Family around 1900.  :)
Thanks for your helpful tip. I thought 1:160 would be too small, but the figures (grown ups) measure 13 mm hight, and that is just like Preiser`s scale 1:144
Crackers,
thanks again for your Kind help, Those metal figurines certainly shall be interesting for a vintage ship-model builder doing scale 1:100
Bill,
thank you for your Input here, trust there are some 1:160 figurines in appr. the same hight as nominal 1:160
Nils
Current builds
-Lightship Elbe 1
Completed
Update
parts (some) of the decoration for bow and stern..... (first trial...)
Nils
up and in the centre of the golden decoration at stern is the badge with the "Kaiser.Eagle". This is printed in appr. scale on Photopaper, and the badge baseplate is cut out with a hole-punch  tool. Because of the rubber plate under the soft anealed  brass stockplate the edges become that rounded badge character
a small drop of semi-thickened-viscosity CA mounts the emblem to the badge base, so it looks like a small button
the upper bow decoration gets the mini-badges with the state Bremen`s "Himmelsschlüssel" (sky key), which the NDL line showed on their liners. The metal antique bronze decor base parts  will be goldened as well
the little blue "sky key" badges are made in the same way, but smaller in diameter
Current builds
-Lightship Elbe 1
Completed
Many thanks to Grant - Patrick - Bob - Dimitris - Sal - Boyd,
and all the "likes", for their appraisals and appreciations  :)  :)  :)
Grant,
thanks for you nice comment... :)
Patrick,
it. was an idea and it worked out quite well.. ;)
Bob,
I thought about how to do a badge with a surface that resembled enamail a little bit.. :rolleyes:
Possibly this may be a way that also fellow builders could do historic badges and emblems for their ships
Dimitris,
yes, the portholes take their time to do, I`m still stuck in producing over 450 of them alone on the hull    :huh:
The most tasky side of it is doing all those drill holes without misdrillng or too much unplaned offset
SAL,
the CA was only to glue the photopaper emblem on the brass badge plate. In this case I unfortunately do`nt know how long the glossy photo side wil stay ^_^  shiny and keep the colors. (may need to be replaced after some years)
Boyd,
Thanks, I also love helpful comments from fellow builders, many thanks to all, for example the highly appreciated way to do the paint borderline over riveted structure, as by Dirk`s  ( Dubz`s) suggestuion, that was a complete new one to me   ;)
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils, very informative on how the badges were made,( I will have to try that ) they look Fantastic, well done
Best Regards,
Pete
"may your sails be full of wind and the sun on your back"
Current Builds :
 Future Builds :
N.G Herreshoff 12 1/2 Scratch Build 3/4" = 1' - 0" Scale
Completed Builds :
Volvo 65 Farr Yacht Design
Herreshoff Alerion
Herreshoff Buzzards Bay 14
Volvo Open 70
 Member :
The Herreshoff Registry                                  Montgomery Sailboat Owners Group       Peter Kunst Sailboat Models
http://www.herreshoffregistry.org/                       http://www.msog.org/                      http://www.facebook.com/Peter-Kunst-Sailboat-Models-1524464774524480/
Thank you very much Pete,
perhaps we`ll find a nice "Herreshoff" badge for your models..... ;)
Nils
Current builds
-Lightship Elbe 1
Completed
Hi Nils, That would be great
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Clever solution (pun intended) for the badges Nils.
Michael
Every time I look in I learn something new.  Making those badges was really thing outside the box.
David B
Many thanks for your Kind words,
Pete, Michael, Crackers and David..., and all the "likes"
Pete,
the typical "Herreshoff" logo, because its too Long, unfortunately could`nt be rounded in order to fit onto a round badge, would take an oval badge base...
Michael,
many thanks for your appreciation
Crackers
nice comment , thanks very much
David,
many thanks to you, glad you like it
Nils
Current builds
-Lightship Elbe 1
Completed
Build log part 25
the portholes are not fitted yet, (to be mounted after final painting of hull), but the hull is drilled in the oppropriate places, and the upper two rows will have "eyebrows", to keep the porthole glasses clear
The unsymmerical tubing for the aft anchorchain is set and stb-side has the upper bow-decoration attached
Nils
I am satisfied with the dull black hull color
front bow decoration as shown / made in the last post
the number of portholes and positions are corresponding with the overview drawing
Current builds
-Lightship Elbe 1
Completed
Beautiful work, Nils, especially the bow decorations.
Is your sailor cursing the gods or just shielding his eyes from the sun?
Dan
Beautiful Nils, the badges really set her off nicely
Best Regards,
Pete
Current Builds :
 Future Builds :
Completed Builds :
Herreshoff Alerion
Volvo Open 70
 Member :
Many thanks to Dan, Patrick, Pete and John,
and all the "likes", for your appreciations,
Dan,
he`s just calling the dry dock crane Operator for Attention......
Patrick,
nice comment, thanks...
Pete,
I do hope that the badges will not fade out (UV light) on the photo paper..
John,
yore always wellcome John, glad you like it..
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful work, as always.
Bob
Current build:  SS_ Mariefred
Thank you very much Bob,
I`m trying to Keep the upper hull rails clean and in natural wood appeal whilst applying the black paint without messing, and with help of the Tamiya tape masking it really works very well...
Nils
Current builds
-Lightship Elbe 1
Completed
Moin Hartmut,
Thank you very much for your Kind words, I`m very glad the KWdG model finds your interest in this log...
Nils
Current builds
-Lightship Elbe 1
Completed
a little update.....
the first of the 458 hull`s portholes are put on, and before that the areas were painted...
These close ups  really don`nt hide anything
Nils
the most left one is the tube bushing for the aft anchor chain
the upper forecastle portholes between the rails
twenty of them on each side
The plugged off two porthole in the third line from the top were due to misaligned drilling
poop deck portholes
upper hull portholes on white background strip, under the promenade deck
Current builds
-Lightship Elbe 1
Completed
