Great workmanship Bob! Love it.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Bob,
Your deck looks amazing! Always a pleasure to follow your builds.
- Tim
Thanks so much Nils, George, Chuck, David, Rusty and Tim for the generous comments and thanks also to the "likes". I appreciate all of your continuing interest.
Bob
Beautiful deck, Bob.
Wonderful decking Bob, I just love it.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
 It has rained for several days in usually sunny south Florida. Rain means no golf. No golf means more modeling. All of this is a long way to say that I've done a number of items of work on the hull. Included in this list are the opening for the rudder in the transom and the extension of the stern post; the stern gun port lids; the timber heads; the hull steps; the jib outhaul fixed block on the stem; and the scuppers.
All of this work was straightforward and doesn't seem to require explanation. The last photo shows the hull as it looks to this point. I am now working on the channels and waiting for the arrival of brass strip for the chainplates.
Bob
Lovely detailing Bob!
hamilton
Thanks so much Sal, Nigel, Hamilton, Crackers and Grant for the very nice comments and also to the "likes".
Guys, I'm rooting hard for some sunshine, so I can out of the work room and back on the golf course. :D  :D  ;)
Bob
I've now done the channels and chainplates. The channels were made to fit between the two hull moldings, shaped on the bottom and one side of each, and slots filed for the chainplates. After adding some eyebolts, they were pinned and glued to the hull. The chainplates were made from brass strip, shaped with files, and holes drilled for pins. They were then blackened. The deadeyes were strapped with black wire and the chainplates were bent around them before mounting them with pins into holes drilled in the hull. The smaller chainplates were made the same way, making sure that hooks (Chuck's acrylic hooks) would fit into their loops.
I am now finishing up the remaining outer hull details.
Bob
She looks awesome Bob, and it's a pleasure to behold.  :)
GEORGE
Thanks so much John, George and Sjors for the nice comments and thanks also to the "likes".
Sjors, I think you're quite right that it's easier than making up the individual links for chains, but these had their moments as well. :)  :)
Bob
Hi Bob.                                 I am following your log with great interest,i would be interested non which adhesive you used
                                           when you planked your deck.    Regards Janet B
Edited by Janet B
Bob....Your work makes me want to do her again with no deadline or time constraints. Chuck's Cheerful is a beautiful model, and you are doing an outstanding job. I had to double check to make sure I had not pulled up his log by mistake.
Sawdust Dave -
Current build - USS Constitution 1:60th (scratch)....
Visit my blog site - All previous builds.... http://davesmodelships.blogspot.com
Thanks so much Janet and Dave and the "likes".
Janet, I use Elmers Carpenters glue for all of my wood to wood joins.
Dave, you're very generous. Constraints or not, you did a great job on your Cheerful.
Bob
I neither wanted, nor intended, to get ahead of Chuck on this build, but I'm afraid that it's happening. After finishing the outer hull detailing by doing the boom supports and adding the keel plates (there are still some eyebolts to be added during rigging), I moved on to the interior by doing the stern seats, which Chuck hasn't done yet.
The seats were made from boxwood sheet using card templates to make the parts. Some discards before they fit, but fairly straightforward work. The seats were painted red to match the inner planking.
I think that I will start making some gun carriages now, while waiting to see where Chuck goes next.
Bob
