HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
Thanks, Glenn.   I was looking at the wear grooves in that shaft.  From your description it sounds like it was built and put to work with repairs on the fly.
This last week was Spring Break for us.  I took a few days off so I didn't get much done.  I was able make a little progress on the paddlewheel.  They just need the buckets and they will be complete.  Hopefully, this next week will be a little more productive.
Glenn
___________________________________
My Gallery
9 inch Dahlgren on Marsilly Carriage<p><p>
Heroine Shipwreck Diorama
Glenn, it's beautiful !  WOW !
Jack
Current buildUS Constellation
This week I tried to finish up the Paddle wheels.  I just about made it, just the nuts on the starboard wheel to finish.
The buckets for the paddle wheels were 15 to 16 inches wide, 60 inches long and 1 1/2 inches thick.  Each was attached to the spokes with two U-bolts.  The U-bolts were about 3/4 inch in section with a 2 inch nut.  Some of the bolts were entirely square in section, some were round and as in the photo, some were a little of both.  I'm not sure if there was a reason for the nuts being put on flat side out.
The area around where the bolts went through the bucket was reinforced with a short plank about 14 inches by 8 inches by 1 1/2.  Sizes varied and the seemed to be crudely cut.
I made several attempts to bend the u-bolts by hand but I couldn't get them to sit properly against the spokes.  I made a simple jig to swage each bolt and it worked well.  I was able to make the entire pile of 96 in less than a half an hour.
The individual pieces of the buckets going together.
The completed port wheel (minus the throw-out bearing) and the almost complete starboard bearing.
Kevin and I had the pleasure of a visit from Mitch Michelson this week.  Mitch, we enjoyed the day and hope to see you again soon.
Glenn
My Gallery
96 U bolts, that's 192 threaded ends, a lot of threading and tapping on top of the woodwork, you were a busy man this week.
Michael
Interesting. So the buckets were one wide plank, with one U-bolt per spoke. In comparison, both Bertrand and Arabia had two parallel planks, each with two U-bolts per spoke, like this:
Arabia: http://janetbtaylor.com/wp-content/uploads/2010/10/arabia4.jpg?w=300
Bertrand (my model): http://modelshipworld.com/index.php/topic/10356-steamboat-bertrand-by-cathead-187-wooden-missouri-river-sternwheeler/page-7#entry344717
Bertrand (as displayed at the museum): http://modelshipworld.com/index.php/topic/10356-steamboat-bertrand-by-cathead-187-wooden-missouri-river-sternwheeler/page-7#entry348901
These two also don't have any reinforcing planks, just the bucket planks, which appear narrower in Arabia and Bertrand than in Heroine, though I can't tell for sure. Your reinforcing plank is 14" wide, which makes the bucket plank a bit wider still, while the others look like 12" or less to my eyes. But the overall bucket would be wider on both the later boats, given the double planks.
Any theories on these differences in wheel configuration? Is it just that Heroine is a smaller boat and so used a simple one-plank paddle? Or was there an evolution to broader, two-plank paddles as being preferable?
EDIT: additional question: what's the diameter of Heroine's wheel overall, compared to the width of the bucket? On Bertrand, the wheel was estimated at 18' diameter, with each bucket about 2' wide overall. My eye feels like Heroine has a different ratio, but measurements will tell if I'm off.
Also, looking back at my Bertrand wheel, it hit me that I never finished one important detail: the U-bolts on the buckets! I'd meant to draw them in with a fine marker, as I didn't think I could get them right with wire at 1:87, but apparently never did and never noticed. Luckily the wheel turns, so I can still do it without too much fuss. Embarrassing.
Edited by Cathead
Love those details Glenn! Nicely done!  :)
GEORGE
Thanks everybody,
Michael, I hope I haven't let you down. I cheated a bit with the u-bolt nuts. The hole is undersized and they are driven on tightly-- no threads. 00-90 is the smallest tap and die I have - too large for the 1/32 inch rod. So far, all the other fasteners have been threaded. Sorry about that.
Cathead, Heroine's paddle wheels were 16 feet from spoke tip to tip. We haven't given the dimensions the full consideration that they need yet but your observations have started me wondering. I need to look back at the table in Adam Kane's thesis. I think he lists several vessels with the size of their paddle wheels. Hopefully, we can find a pattern.
Glenn
Glenn
My Gallery
Oh Glenn.... I'm mortified.... simply mortified
Actually I had not realized the rods were that small a diameter, and if you mentioned the diameter in the text I missed it because of the impact of the pictures. And who need to struggle with 000 x 120 anyway.
Michael
I finally completed the paddle wheels to the point I can start tying the drive train to the engine.  This week I was able to get most of the pittman/crosshead assembly done.  Just the feedwater pump and reach rods to finish before moving onto the boilers.
U-joints for the reach rods.
Crosshead slides.
Testing the fit of the crosshead and end of the pittman.
Pittman ends freshly milled.
Straps soldered to pittman ends.
Finished pittman strap with bearing, wedge and keys before blackening.
After blackening with bolts added.
Flywheel end of pittman.
Crosshead end of pittman.
Glenn
My Gallery
I am in awe !  WOW !
Jack
That is so freakin' cool! I agree with Greg, I keep expecting to see it leap into action.
What can you say beyond what has already been said. WOW!!!!
Flying Fish --  MSW
Essex ---  MSW
Constitution  --  MSW
Confederacy -- MSW
Philadelphia -- MSW
Chaperon -- MSW
San Felipe -- Panart
Portland -- Bluejacket
My grandfather was a stationary Engineer at the Duquesne Brewery it Pittsburgh,and he used to take me with him on Sundays when he had to check things.
The details of this bring me back to those trips. Wow again. Heat up a kettle and connect the steam.
Flying Fish --  MSW
Essex ---  MSW
Constitution  --  MSW
Confederacy -- MSW
Philadelphia -- MSW
Chaperon -- MSW
If I didn't know it wasn't full size . . . wait is it?
Bob
Current build:  SS_ Mariefred
post-76-0-62050600-1459619167.gifpost-76-0-54557200-1459619223.gif  I do believe we all looked at that thought "well, fire up the boiler and get this rolling on the river".
