Excellent work on the upper planking Bob,
so clean and accurate, well done   :)
Nils
Current builds
-Lightship Elbe 1
Completed
That is some very nice planking! Great job!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Hi Bob
That's a very fine Granado in the making. The kit itself is excellent and your work improves it further.
Do you plan to make openings for the quarter lights? (I did but am not sure if it's noticeable at all.)
peter
Thanks so much Albert and Peter and the "likes". It's not my intention to make openings for the windows Peter. I'm going to use Micro Kristal Klear for the glazing, which is translucent and against a black background will give apparent depth.
Bob
The port side upper planking is now completed and treenailed. It was done exactly as previously described for the starboard side.
Next up will be the second layer of the wales and the counter planking.
Bob
Neat work Bob,
lovely planking look
Nils
Current builds
-Lightship Elbe 1
Completed
Beautiful work as always!!
I will be watching your build with attention.
JP
Edited by captgino
Jean-Philippe (JP)
Current build: Syren , HMS Victory Cross Section, Essex
:dancetl6:Please visit and subscribe to my YouTube Channel
On Hold: Rattlesnake (Scratch-built)
Completed:
Good stuff Bob, I like.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Even more nice planking! It looks great!
-Elijah
Current build(s):
Completed build(s):
Member of:
Hi Bob. I had a moment from the move and was able too catch up on your build.
You sure have been making a lot of progress and doing a great job too.
Well done.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thanks Bob. Well the good news is we're moved.
The bad news is now we have to unpack it all!
Rusty
Bob, well behind you, as I still have hours left on CHEERFUL.  But I wanted to thank you for the great series you ran on her build.  As always, it helped me tremendously, and steered me away from many mistakes.  About to start the rigging,
I don't know about GRANADO, but will do some research, and perhaps she'll be my next up North build.
Thanks again,
Terry
After some time up north with family, it was back to work on Granado. I've done a few things: I added the stern post, cut from holly sheet; I planked the counter; and lastly, I planked the second layer of the wales. The counter and wales were done with boxwood strip. In doing the counter, I omitted using the kit base piece, as it seemed more trouble than useful, and used thicker planking material.
After the planking was done, I painted both the wales and counter black. While I carefully taped the top of the wales prior to painting (using Tamiya tape) I left the bottom untaped, since any paint will be covered by the lower holly planking to come. This accounts for the sloppy appearance and excess width of the wales in the attached photos.
I'm still deciding today whether to next do the lower planking or do some interior work.
Bob
Super stuff Bob, your doing her proud
Be Good
mobbsie
mobbsie
Next Build :-
I have chosen to defer the second planking of the lower hull in favor of doing work on the interior. so far, this has involved adding view blocks behind the rear ports (as per the suggestion of Joe V), adding the quarterdeck bulkhead and adding waterway-margin planks on the main deck.
The view blocks are simply black painted pieces glued in place to prevent viewing through the hull at the rear ports.
The quarterdeck bulkhead presented some uncomfortable decisions for me. The kit provides walnut pieces to support curved panels in slots precut in them. These kit pieces were virtually unusable in the manner intended. The kit also provides black decals to be applied to the curved panels. I didn't like the look. Joe V and Timmo had painted the decoration on the panels, in lieu of the black decals, and did it beautifully. My attempts at this didn't look so good. AOTS shows an alternative bulkhead consisting of plain planking .With this "official" sanction, my lack of artistic talent and the state of the kit pieces, I opted to do the alternative bulkhead. I planked it with beveled boxwood planks to make the curved surface and painted it red to match the bulwarks. A cowardly solution, perhaps, but better in my mind than something that I would have been totally unhappy with.
After completing that work, I penciled in lines on the sub-deck to mark out the deck beam lines for the deck planking joints, as shown on the AOTS deck plan.
The last item of work was to make the waterway-margin planks from holly sheet and strip.The kit plans do not show them, but they clearly appear in the AOTS drawings, which I chose to follow. The bow sections were cut from holly sheet, using card stock templates. The remainder were made using holly strip bent to shape.The waterway-margin planks were made from thicker stock than that to be used for the deck planking, and were sanded to provide a slanted profile from the bulwarks down to meet the planking height, as shown in AOTS.
Next will be the deck planking, which will also require that work be done on the mortar pits before the deck planking can be installed.
Bob
