OK.  I have come to the conclusion that Amalio isn't building this model himself at all.   I believe that there are 1 inch tall boat-wrights that build this model in the middle of the night.  I'm sure that I see there tiny foot prints in the sanding dust.  That's what it has to be!!  No one can work that precise in that scale!!!  :default_wallbash:
One will never ever have enough clamps, druxey.
Look at it, Amalio can't even finish an entire length ...
Another fine day at the shipyard Amalio
Carl
Finally I see that he is human did you all see the blobs of glue. Phew! and sanding dust too. now my question is how do you clean up the glue with the clamps in the way, or do you do that later?
As always superb model making.
Michael
Good morning.
I use a lot to remove the tail, these circular brushes from Dremel. When two hours have passed after having glued. There are corners where it does not arrive and you have to take it into account so that it does not overflow in those places.
It is necessary to put the machine at the lowest possible speed so as not to burn the nylon of the brush.
AMALIO
Or it could be just a trick to make us THINK he's human! All the while he's operating with those 8 arms :)
Am I understanding you Amalio that you remove the dried glue with the nylon brushes turning very slowly? I've never heard of removing PVA glue that way and I've been using it for too many years. Interesting.
Amalio: isn't it easier to clean up PVA glue squeeze-out with a damp (or wet) brush before it dries? That's been my practice for years.
I use the same method as Amalio, same nylon brushes (discovered it by accident), and it works great! Especially on half-dried glue.
It is just much faster and simpler than water. But water works better in tight areas, for sure. Especially water plus scraping with some xacto blade.
Edited by Mike Y
But wouldn't you run the risk of making markings on the wood with the exacto blade, which you cannot see with Amalio's method ...
Carl
We can open any of your pictures and Just stay there for a Lot of time, mesmerized by your workmanship. I only dream to be as good some day. You're an artist for sure.
Amalio,
Crisp and clean as usual. Beautiful work!
Respectfully
