Hello,
and thank you all for your comments and likes.
At the shipyard the carpenters set the last pillars at the gun deck. Next are then the carlings and the last smaller things at the deck.
Regards,
Siggi
Recent build: HMS Tiger (1747)
Gokstad ship (ca900) scratch build
Captains Barge ca. 1760, scratch build
HMS Dragon 74 gunner 1760, scratch build
Hello and many thanks for your likes.
I'll tell the carpenters.
Today they where also very busy to lay out the next rows. I hope that we get the rest tomorrow ready.
Regards,
Siggi
Hello,
the carpenters say many thanks for your likes. I should tell you that 😉
Today we finished the carlings and the carpenters started to cut the slots for the ledges. That will take some time, even when we install only there ledges where you could see them later.
Regards,
Siggi
excellent work Siggi,
Nils
Current builds
-Lightship Elbe 1
Completed
Hello,
the carpenters have there work done. That is the region where you later will see through the deck down to the gun deck. The next days I think, has the painter a lot of work 🙁
Regards,
Siggi
Hello, and many thanks for all the likes
the painter has all the beams, carlings and ledges painted and the carpenters have reinstalled them. I think, that is here the last action for the next years 😲 Before I set them permanent in, I have to finish the outside of the ship.
From the forge came the rail for the stairs.
Regards,
Siggi
Very beautiful and precise, Siggi.   Have a great holiday season.
Hello, and many thanks for your likes and comments
If you think you are ready, then it comes. I forgot the elm-tree pump 😳
So I activated the carpenters, and they build the extra carlings and ledges for them.
Regards,
Siggi
Hello and many thanks for your likes,
Thank you Jason, the next update is not far away. The main and topsail jeer bits. For that I think I have to change something with the chain pumps fore handle. Sorry I do not know all these names. But that will take some time and thinking.
Regards,
Siggi
Hello,
the bits and gallows for the main mast are ready. I changed also the sprouts of the elm tree pumps.
And here some pictures from the gun deck
Regards,
Siggi
🎄 The shipwright (thats me) and the crew wish you all a merry Christmas, a happy new year and stay sound in this complicated time. 🎄
Edited by Siggi52
Regards,
Siggi
Love that fifth photo! And a Merry Christmas to you and yours, Siggi
Edited by Keith Black
Hello,
and many thanks for your likes and wishes.
After a short break between the years, I'm back at the shipyard. Now all port lids at least are build, but not all are lined.
At the picture above you see the lids without lining, flush with the planking. At the picture below the lids have already the lining, and they are now not flush with the planking. All who where not ill with measles ore what else when it came to addition at school, know what is now to do. And that is not a shortcut ☹️
Above without lining and below with lining.
At the picture above the lids are looking more like at most historic models. At the Centurion (below) is interesting, that they build the lids just plain, without the bulky wails or thick planking on top!
1481324631_Bildschirmfoto2021-01-13um17_17_18.jpg.595ae5cafcdd2a8e71ea63a1a90e4da9.jpg
Edited by Siggi52
Regards,
Siggi
Hi Siggi,
I am just catching up with your posts. I missed these for some time, after the scratch build entries were divided into decades. I forgot that your ship predates 1750! Apologies.
The work is looking great, up to your usual very high standards. The gun deck photos make it feel like we are in the real ship.
The pillars at the centerline look terrific and very consistent even though you turned each one by hand. Did you use a special shaped cutter, or just normal tools and a template to check measurements? I am facing this fun challenge soon myself.
Best wishes,
Hello, and many thanks for your likes.
today I finished the gun ports so far, that they fit and being painted. The rest comes, after I painted the outside of the ship.
Regards,
Siggi
Siggi
 Nice detail work making the port lids follow the hull profile, the Tiger is turning into a real beauty. The work crew must have had the day off?
Hello Keith,
no, the painter had a lot of work with the lids and the rest of the gang had to plan how it's going on with the rails and rigols.
Regards,
Siggi
Hello,
yesterday the carpenters profiled the planks for the sheer rail and produced a lot of shavings. Today we fit them in at the port side. After I got a little routine with the ends, it was an easy job. Tomorrow we will make the starboard side.
Regards,
Siggi
Thank you Matt, and also all others for your likes
Today I finished the rail at the star board side and some small things at the gun ports and there lids. Just to mention the dimensions of the rail, she is 4,5 mm broad and 1,2 mm high.
The next things are the rigols 😧
Regards,
Siggi
Hello,
today I could proudly present the first installed rigols 😓
First I draw them at the computer
Then followed a sawing marathon
And here they are. I carved them at the ship. There they are fast and could't move, so it is also healthier for the fingers. To the right is the jig for the high.
Regards,
Siggi
Very neatly done, Siggi!
Another way is to glue the blank to a piece of wood using white glue. The advantage is that you can turn the piece in any direction while carving and also keeping your fingers safe. Also, if you slip, it won't harm your model. Soak the piece in rubbing alcohol to free it when you are finished.
Edited by druxey
Thank you Druxey and all others, also in advance, for your likes
that was also first my intention, but they are so small (1,3 X 1,5 mm)  that I did't risk it to destroy them when doing this. In this case, if you start carving from the outside, you are with the grain at the save side. And later come those, who go over the upper wales, and you must carve also from the underside. So I thought that it is saver this way.
Edited by Siggi52
Regards,
Siggi
