Thank You,   Yes I did.  I darkened the only one plank edge with a soft pencil.   I usually darken the edge of the plank being installed against the one that is already on the hull if that makes sense.  The plank edge already on the hull is  left natural.  But only after beveling it for a tight fit.
I did finally finish the nailing of the external planks.  That took a long time.  My advice would be to really consider how long it takes to drill all of those holes and insert the 10 pound black fishing line.  I think its quite worthwhile but once you commit to it you have to follow through and do it to the entire model.  So think it over first.
Once that was done, I could work on the inside...finally.  The photos below show the floorboards and platforms in position.  The floorboards are a bit different than you might be used to.  This is the way they are made on the contemporary model and I actually found some original drafts of longboats that show them this way as well.  Its very interesting and I think its a nice detail to add to make this longboat model a bit unique and different from other kits of the same subject matter.
It may be hard to tell from my photos but the center plank and two outside planks of the floorboards have a rabbet along their edges.  Normally I would scrape these details into the planks but Yellow Cedar doesnt scrape well.  So instead I made these three floorboards in two layers.  They are all pre-spiled and laser cut.  The finished thickness for the floorboards is 1/16".  So two 1/32" layers were used.  They were glued together to leave the rabbet on both sides although the outside planks of the floorboards only have a rabbet on one side.  You guys will see this on the plans.  Once completed I marked the locations where the frames would be so I could add the simulated nails before I glued the floorboards on the model.  See below.
The thinner floorboards were easy enough to glue into position.  Its the wider boards that were a bit tricky.  These are 1/16" thick as mentioned and because they are quite wide it was more difficult to pre-bend and glue into position.  Should anyone have trouble with this there are other solutions.  You could make these out of two layers of 1/32" stock like the other floorboards and glue each layer into position separately.  They would bend more easily that way.  You could also convert the wider floorboards into two thinner strips too.
The platforms were pretty straight forward.  Each of the pieces are laser cut and after gluing them together edgewise they are ready for test fitting.  I also ran some 1/16 x 3/16" strips across the bottom of the platforms to give it strength.  Probably just like they do in real life.  I also added one of these across the flat edge of each platform which will show so take your time with this.  The platforms were nailed off the model as well.
A look at the bottom of the aft platform...it aint pretty, but it doesnt have to be.   One feature not laser cut into the platforms are the notches for each frame.  Everyone's model will be slightly different as they may shift.  So you must mark there locations and file the notches before final placement can be finished.  Its not hard to do.  You may want to trace each platform on some card stock first and locate the notches that way as an alternative.  Then transfer them to your cedar versions.  The bow platform is a bit trickier because of its location.  So I recommend that you do make a card templete first and transfer it to your glued up version.  I made the pieces for the bow platform over-sized to compensate for the wide variety of bow shapes everyone will have.   But you can see how mine look ad are shaped.  Note how the notches are also beveled so they sit nicely against the frames.  This is something you will need to do as well.  The bow platform is done exactly the same way.
A look at the contemporary model.
Regarding treenail installation - isn't it easier to drill and install them while the hull is still attached to the base upside-down, before it is sanded and before the frames are cut off from the build base? Or I miss some problem with it?
Otherwise it would be easy to scratch that nice and delicate hull while drilling treenail holes... Just a thought.
Edited by Mike Y
You could but its tough to see where the frames are Mike.  So I held it up to the light because the hull is translucent and marked the locations for the frames on the outside of the hull.
Chuck
Not to many actually.  Thank you for the kind words.  I wish I had more time during the week to build.  I am only spending about 4 hours a week on this project as far as build time goes.   The platforms and floorboards took me a couple of hours.   If I had to guess actual build time (not development time for the plans and design)  I would say I have spent maybe 25  hours give or take actually constructing the model up to this point.
Installing the risers was up next.  They are designed in two pieces for each side.  They are laser cut with notches in them for the thwarts.  This means that the placement of these is crucial.  The very first thing I did was measure off the plan the distance from the top of the caprail down to the top edge of the riser.  I did this at every frame on both sides of the model so I was sure these would be placed at the same level port to starboard.  The aft piece is the first to be glued into position.  But I did add the nails ahead of time because I think it would be easier.  So I clamped it in position temporarily to mark the frame along the riser and then after unclamping, I drilled and inserted the fishing line for the nails.   This first piece is left a bit long just like I did with the planking.  So you need to mark the forward end in the middle of the frame and cut off the excess.  This is very important because the next section will butt against it and the thwart notches need to line up.  Its easy enough to do but you must be careful.  Then it was glued into position making sure that the top of aft end was level with the top of the bulkhead frame it sits against.  The cockpit seats will sit on top of this so they need to be level with each other.
You could see the forward section waiting to be glued into position.  No trimming needed.  This just needs to be butt against the aft section tightly.
Here you can see both sections of the risers in position.
Then I made up the thwarts.  Like the floorboards these have a fancy edge.  Since scraping Cedar is problematic, I made each thwart in two layers glued together.  I just cleaned the char of the edges and glued the layers together creating an even fancy edge on both sides.
These are laser cut extra long as well.  You will need to cut them to length so they fit in the notches nicely.  You may have some that require some notching around the frames.  But its pretty straight forward stuff.  These are not glued in yet.  I will wait until I make the cockpit seats next and after some detailing on those which I will describe,  they will be glued unto position.  The center thwart with the cut away for the mast also needs detailing before it can be glued into position.  Its finally moving along and actually looks like a boat!!!  It wont be long now!!!
Feel free to ask me any questions.  This model really shows the beauty of the yellow cedar which I am really liking the more I use it.
Grumble about the time it takes to 'treenail'? Try a ship of the line!
Seriously, your model looks very nice, Chuck. One question: weren't bottom boards removable for bailing and repair purposes? If so, that means less treenails!
That was my initial thought as well.  But both contemporary models have the bottom boards nailed so I followed suit since this is a model of a model.  Its easy enough for folks to decide otherwise though.
Chuck
Even if the sole were removable in some fashion, it would still have nails (this boat would seem quite light for treenails) fastening the boards to battens beneath to keep them in position. It is indeed "a model of a model" and the prototype model may have (and perhaps quite likely did) taken some liberties with the details. It would appear that there is no provision made for bailing and cleaning out the bilge unless there is some unseen way that the sole can be removed to permit access beneath it. That would not be seamanlike at all. The bilges would soon fill with crud and that would promote rot. Perhaps the rabbets on edges of the sole planks may intend to depict that the sole sections on either side of the center plank were designed to be removed, but I can't see from the model how that would be possible without deconstructing the thwarts unless the removable sole sections were cut into sections athwartships which I would expect to be the case in a real vessel of this type. It is entirely possible that the builder of the original model took that common detail as a given and didn't bother to cut them. As said, though, it's "a model of a model," and a damn fine one at that! :D
Not that I am aware of...but they were removable to allow drainage and pumping of the water that lie beneath it.
Moving right along.....I will be working my way forward on the interior.  None of the thwarts are glued into position just yet.  There will be some things that need to be done to many of them as I work my way forward.  For example,  the seats in the cockpit need to be notched into the aft thwart.  The seats are what I did next.
The seats are laser cut in two layers just like the thwarts.  The laser char was removed from their edges and then they were glued up so there was a decorative edge on one side like shown in the photos and on the plans.  The two side seats were "tweaked" for the best fit first.  They are laser cut a bit long on purpose to give everyone some wiggle room with this.  You will be shaping and sanding and test fitting many times over until these fit properly.  Everyone's model will very slightly so the notches for the frames will need to be filed in.  BUT .....
-first, I beveled the aft edge of the seats so they sit flush against the transom which is angled.
-then I held the seat in position against the frames so I could mark their locations on the seat.
-I filed the notches for the frames a little at a time constantly testing the fit and adjusting.  The edge of the seat against the frames also must be beveled to sit properly against the inside planking.
-When the slots for the frame were acceptable, I laid the seat in position to cut its forward edge to length knowing that it will be notched into the last thwart. You can see the notch I filed into the thwarts below.  Basically you must file away the lower layer of the thwart.
In the next photo you can see how it looks after test fitting.
Once they were glued into place,  the center seat was treated the same way and adjusted to fit.
This is how the whole model looks at this point.  Its getting close now with only a few more details to add.  The seats in the cockpit area will be painted red like one of the contemporary models.  The two contemporary models are painted differently but I think I will follow the scheme shown below in the unrigged contemporary version.  I also posted a photo of the rigged contemp. model to show you guys the difference.
Beautiful work, as usual, Chuck.  Excellent joinery, especially the tricky notches in the floor planks for the ribs.
Dan
I finished painting the cockpit seats.  I also added the knees atop the last thwart and the knees and bracket along the inside of the transom.  The knees on the transom were tricky but not too bad.  They need to be beveled along the sides and back to fit the angles of the bulwarks and transom.  Also note that the center bracket or panel on the transom was added to the top of the stern post and sanded flush.  But before doing so, the stern post was reduced in height about 1/16" first.  This allowed the top of the panel to sit flush with the top of the transom.  Once this was glued into position and the knees added on either side,  they were all sanded flush with each other so you couldnt see any seams.  I used some wood filler for this too.  Once painted it looks nice and clean.  The notch on the center of that panel is used as a guide to file that same notch through the transom as well.  You can see that in the photos. I hope that makes sense.
Next up working my way forward will be the windlass.
Thanks guys.  Nothing has changed.  There will be a full hull kit (everything you need in one box) followed by a smaller mini kit with all of the rigging and masting stuff.  Just like the barge, virtually every part of this hull you saw me build so far is made of laser cut parts.  In fact,  I already have 10 kits already made up.  But those are reserved for the guys in my local club.  I literally just finished cutting the last sheets today.
I am awaiting a new batch of milled cedar which should come in a couple of weeks.  I will make 10 more right away.  Each kit has about 25 sheets of laser cut parts.  Thats just for the hull.
As soon as the hull is finished and I finalize the plans,  I will be ready to get this group started if there is still any interest.  Once I get to that point I will ask again for a comitment in the online group before I start setting up a new forum area.
All I really have left to make on the hull is the windlass,  some metal work on the mast thwart,  the thole pins,  the roller at the bow....rudder and tiller.   Thats really it.  Then its time to rig it....first without sails.....then with sails.
We need a minimum of 8 to start a group....but ten would be a real nice round number to start with.
Thank You gentlemen!!
Just a quick comparison as the new larger and improved longboat is far enough along.  You can see how different and more elegant the shape is on the newer version.  It has a much fuller bow and as you proceed to the stern the newer version has a more pleasing curve.  You can see many other differences as well.  The floorboards and other features are more detailed and true to the Medway contemporary model.
Chuck,
I haven't been in ship-mode for quite a while now.  Real life has taken up too much of my time and mental space this year.  I recently returned from a trip to Denmark, where I visited the National Maritime Museum and the Viking Ship Museum.  Feeling my ship modeling interest being rekindling, I thought I'd check in here.  Wow!  I'm quite excited by this longboat kit you're working on.  While I'm hoping to channel my renewed interest into picking up where I left off with my Cheerful build, this longboat looks like it will be a phenomenal kit.  I'm impressed with how much more realistic this larger scale longboat looks, especially when compared to the 1/48 scale boat.  Though I understand the size from the dimensions you've given, I'm having a hard time picturing the actual real world size of this boat.  Any chance you can post a photo with something we can all relate to, like a can or bottle of soda/beer, or coin, or lighter, etc.  I know that's kind of gimmicky, but 1/24 scale isn't something we're used to seeing everyday. :)
Thanks, and glad to see after my time away that you're still doing what you do best!
Erik
