HMS Winchelsea 1764 by Rustyj - FINISHED - 1:48
The last few days were spent cutting 250 strips of 1/4"x3/64" for the hull planking. I found it interesting
that the strips cut from the same billet changed color not only when you worked your way through the billet
but also from end to end. Here is the strips cut from one billet. I separated the strips from each billet into
separate packages to aid in trying to use similar planks next to each other.
Also strips that look similar end up having a different look when the finished is applied.
I cut out the drop plank and placed it after lining off the first two strakes.
Well yesterday I thought I would be posting this update but when I looked at the first two strakes below the wales I
did not like the way it looked at the stern. I had to remove the last three planks and redo it. I'm happier now.
I then applied the first coat of wipe on poly.
Next should be putting on the second layer of the wales and the black strake. I'm contemplating
finishing planking the hull to minimize scraping the finished wales. I tend to manipulate the hull
a lot when I plank. I will hold it upside down, spin it around, have it in my lap etc.
Have to think about that for a bit. Hmmmmm
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Share on other sites
On ‎1‎/‎23‎/‎2020 at 8:57 PM, nzreg said:
Looking real nice Rusty, I envy your skills.
Thank you but it's more a testament to Chucks ability to design superior models and provide
such detailed instructions that we can produce such good results.
Also thanks for all the likes.
Rusty
Link to comment
I’m certain that Chuck’s design plays a part but don’t short change your skills. You log is quite impressive and has me strongly considering joining this project in a year or so when I finish up my current projects. Great work so far!
Edited by VTHokiEE
Link to comment
Thanks for the kind words VTHokiEE! Also thanks for all the likes.
Rusty
Link to comment
Much appreciated Bossman!
Rusty
Link to comment
With the upper planking done the next step should have been to plank the wales with their second layer. I decided to
skip ahead and install the 3/16" x 1/16" fairing cap. The fairing cap from the hance to the bow and stern are permanent
while the piece at the waist is temporary. The fairing cap helped maintain the 3/16" thickness of the bulkhead.
The sanding, chiseling and sanding some more of the inboard bulkheads took a few days but is mostly completed.
I wanted to do this now to save any damage to the wale that may occur with my handling.
The pieces of the aft portion were just straight and fit easily. The pieces at the bow took a bit more time.
I took a 1/16" sheet and placed it on the bulkhead. I the traced the outside edge, flipped it over and drew a rough
second line 3/16" inside the first. Cut out on the scroll saw, glued it on and then finished sanding it down to a
consistent 3/16".
I've got a bit of shop cleaning to do before I continue on. After a good cleaning I'll line off the hull
using Chucks supplied tick strips. :)
Rusty
Link to comment
Thank you Ben and JJ. Also thanks for all the likes!
Rusty
Link to comment
Thanks Chris!
Rusty
Link to comment
Fairing the inner bulkheads isn't fun no matter how one approaches it. I didn't find anything to like about it on Cheerful save I could say it was done. I am not looking forward to this aspect on this model even though you make the outcome worthy of the pursuit. The cap looks superb. I am assuming there is a outboard detail to be added in the future to the cap??? She is a beauty Rusty!!!!
Joe
Link to comment
Thanks Joe. Yes my understanding is there is "fancy molding" that will be placed.
Thank you Bossman. Build Chucks creations and you can't help but get better.
Thanks for all the likes too!
Rusty
Link to comment
Hi All,
It's that time of year where my part time job becomes more than full time. Plus the admiral decreed
that the rec room needed new decking. At least it helped me work on my plank shifting! :)
So I used Chucks supplied tick strips and lined off the hull. I then I proceeded to plank the six rows of the first belt
on the port side. It's been lightly sanded and I will wait until the full hull is planked before finishing the sanding.
I'm off to start on the first band of the starboard side.
DSC00085.thumb.JPG.12006ad52245090989a7b73fd6907a95.JPGDSC00086.thumb.JPG.7f88b993940f691e218705a8e79c3692.JPG
Rusty
Link to comment
Thanks Bob. Also thanks for all the likes too!
Three day weekend coming up so hopefully I'll get more planking done.
Rusty
Link to comment
I've spent the last couple of weeks completing the first belt of hull planking on the starboard side. Both sides have
been preliminarily sanded with 150 grit and received one coat of wipe on poly. Once I finish planking the rest of the
hull I'll give it a good final sanding with 400 grit sandpaper. Now that I have completed the first band of planking I'll
now go back and add the wales. From this point on I'll do a majority of the planking with the hull upside down.
This will minimize the damage to the wales and their paint from my clumsiness.
Rusty
Link to comment
Link to comment
Looking good Rusty -- I have to agree with nzreg & Chuck.  I love the look of the Cherry and your planking looks great.
Keep up the good work....
Till next time.....     😎
Steve
Finished:              Artesania Latina Constellation;   Model Shipways USF Confederacy:  Medway Longboat 1742 - Syren Ship Model Company
Current Build:     Syren's Winchelsea
Link to comment
Very nice planking, love the colour of your cherry. On the strength of that I think I may go the same way as I can get cherry boards easier than AYC
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
3 hours ago, Chuck said:
I think Rusty is using swiss pear and not cherry.
Yes, a quick re-read  of the log mentions he is using pear, my mistake😕 Still looks really good though!
Current builds;
Completed:
Link to comment
Hi all,
Yes it is pear wood. The color is very similar to Cherry but I had more pear on hand then Cherry so that's what I'm using.
Thank you nzreg, Chuck, Capt Morgan, Edwardkenway and Bob for the kind words. This is such a fun build!
Off to work on the Wales now. :)
Rusty
Link to comment
