Welcome to our new sponsor - Engine DIY. See banner ad on Home page. ×
As there is no rest for the wicked, I am now launched into my next project - the Pobpob! - (plank on bulkhead Pride of Baltimore.) Actually two projects, as I'm doing something I've never done before and am building two kits at the same time, the other being the Artesania Latina Titanic lifeboat.
On the POB, I have the bearding line cut and the bulkheads in place. These are the best fitting bulkheads I've run across yet; they lined up perfectly with the top of the keel and the bearding line/rabbet at the bottom. Not sure how they will all line up when I start fairing, but at a glance they look like they will be pretty good. This doesn't look like it will be too hard a planking job either.
David
Current Build - St. Roch, Billing Boats; HMS Agamemnon, Caldercraft (on hold)
Previous Builds - Armed Virginia Sloop, Model Shipways; Constitution, Model Shipways; Rattlesnake, Mamoli; Virginia Privateer, Marine Model Co, restoration; Prince de Neufchatel, Model Shipways; Charles W. Morgan, Model Shipways; Pride of Baltimore II, Model Shipways, Bluenose, Model Shipways (x2); Niagara, Model Shipways; Mayfower, Model Shipways; Shamrock V, Amati; HMS Pegasus, Victory/Amati
you are certainly keeping your momentum going David!  I’m sure this will be another great build. I don’t find POB rolls off the tongue as well as PdN did but it is better than pobpob🧐
Edited by Heronguy
Doug
Current BuildsBluenose II - AKrabbenkutter / Prince de Neufchatel / Essex Cross-section / Syren / Barque Stefano / Winchelsea / Half Hull / Maria HF31 - Dusek / Bandirma - Turkmodel
On the Shelf: Santisima Trinidad and Cross Section / HMS Cutter Alert / Tender AVOS / Confederacy
Suspended Build: Bluenose II - Billing Boats Nr 600
Good Morning,
I have been progressing slowly on my POB; too many leaves to rake and too much painting at my daughter's house to do!
I've attached the plankshear and wales. This plankshear is a tricky piece to position correctly. As is so often the case, the location of the gunports is key. I think I have it more or less in the right spot.
I hate to add paint this early on in the process, but I couldn't think of another way to get a good crisp delineation between the yellow and the black where the plankshear and the wales meet the hull. I have now completely covered this area with masking tape to protect it while I proceed to other areas.
The plankshear is yellow outboard and dark red inboard. I've scored it with a razor blade to help with the delineation when I add the red paint and the inboard side.
The plankshear doesn't actually fit the hull very well. No matter what I did it came up about a half inch too short. This has to be a design flaw, because even allowing for minor differences in the way the hull is shaped or faired from one builder to another, a half inch is a lot.
By getting the holes for the stanchions where it appears they ought to be according to the plan, the shortfall was at the bow. I ended up cutting off the mating ends of the plankshear and making a new piece to fill in the space at the bow. It looks a little rough at this stage, but there is much to add at this location which will virtually bury it.
Parts of the framework appear discoloured because I wasn't happy with its location on my first attempt and decided to remove it and relocate it. Dissolving the glue spread the black paint around a little bit.
So, that's all for the time being. I'm now about to start planking the counter and lower transom.
David
Good Morning,
Brief update -
One problem I often encounter is this: early on in the build, before planking the hull, I glue pieces of scrap the mast mortises and then cut a rectangular tenon on the ends of the masts and fit them snugly in the mortises. So far so good. However, much later, when I square up the top ends of the masts, I often have trouble getting the square exactly in the right plane. If I leave it like that, the mast top isn't properly aligned and it can't be left that way. In order to fix it, I end up trimming the lower tenon, so I can rotate the mast, but it results in a very loose and poor fit and I wonder why the heck I spent so much time getting the tenon to fit well in the first place.
This time, I'm trying something different. I padded the mast mortises with scraps of wood, so that they are actually square rather than rectangular. Then I carved round tenons on the masts. They fit very snugly and at the right angles. Now my hope is that later I can simply rotate the masts to line up properly without losing the nice snug fit.
Planking - I have to admit it - I am probably the world's worst hull planker. It's never my favourite part of the build and I never approach it with a good attitude. The POB is a single planked hull and I was not happy with the job I was doing. On top of that, the plans indicate planks 1/8" wide but the provided strips are 3/16" wide which doesn't look quite right to me. I was fretting about it all, but I think I have a solution.
I had bought some cherry from Cornwall Model Boats that is .5mm x 3mm to upgrade the decking and I bought a ton of it. (Might as well get my money's worth out of the shipping fee, right?) 3mm is approximately 1/8" so I am going to double plank the hull with this material. It's so thin that it's really just a veneer, but I think it's going to address my problem. Once I made this decision, I was able to finish the first layer without more fretting, as I knew I would just sand the heck out of it and use a lot of wood filler.
I've now got a good smooth solid base, (although ugly as sin,) and I'm ready for the veneer layer.
Thanks again for your comments and likes.
David
Good Morning,
A little more progress on my POB.
I took this picture at the Tall Ships Challenge this summer and have been working to try to replicate the colours on the deck.
The deck on this ship is quite dark (and actually a bit rough looking.)
I wanted to get a dark colour for my deck, but hopefully not quite as rough. I used a .5 mm veneer strip (I believe it's cherry) and then painted it with watered down acrylic paint, a mixture of brown and orange. It was so thin that it worked more like a stain than a paint. I then finished it with amber shellac. The result is pretty much the effect I was after.
After a bit of experimentation, I found red and yellow colours that match the actual ship pretty well. (That's yellow masking tape on the outboard edge of the plankshear, not a really poor paint line.)
Installing the stanchions looked like a daunting task to me. The instructions show installing them all first and then planking them afterward. I knew I would have trouble getting them all at the right angle. I have Bob Hunt's practicum for this kit, and while I haven't been following it, I did use the method that Bob suggested for this job. He suggested building each section of bulwarks between the gunports off the model, (spacing the stanchions correctly of course,) and then installing each as a sub assembly. This method is proving to work very well.
In the photo below, the sections are just sitting in place for the picture, not glued in yet. I'm also painting each section before installing it. I can't imagine painting those stanchions successfully after they're installed.
That's all for now. It looks like a really windy and rainy day shaping up, so a good one to spend in my workship.
David
Hi David, I'm just catching up on this build.  Looks like it's coming along nicely. I never would have thought to fit up the masts this early in the build.  Good idea. Mind if I pull up a chair?
Derek
If you want to build a ship, don't drum up the men to gather wood, divide the work and give orders. Instead, teach them to yearn for the vast and endless sea
Antoine de Saint Exupery
Current Builds
Bluenose - Model Shipways - 1:64 Scale
Fair American - Model Shipways - 1:48 Scale
HMS Winchelsea 1764 - Group Build
On Deck
Guns of History Naval Smoothbore Deck Gun - 1:24 Scale
Finished Builds
Mare Nostrum - Artesania Latina - 1:35 Scale
Guns of History Carronade - Model Shipways - 1:24 Scale
Happy New Year Everyone!
I have been pretty derelict in my posting lately, so thought I better do something before the build gets too far along.
The hull is pretty much finished, bulwarks installed and top rail in place. The upper hull and inner bulwarks are painted. I'm still debating on the shade of green I'm going to use on the lower hull.
The stern caused me a bit of trouble. I never manage to get a perfectly symmetrical hull, which doesn't matter too much when you view the side of the model, but it's more noticeable when viewed from one end or the another. So, just as a carpenter has to do some fudging to get square factory made kitchen cabinets to fit into an out of square kitchen, I had to do quite a bit of tweaking to get the lettering and other details to fit an out of whack stern. This isn't the best stern I've produced, but after many tries, this is the one I'm going to live with.
I've started in on the deck furniture. There is a ton of it on this ship and the tolerances are pretty small - very little space between components. I know from experience that if I simply start at one end and work to the other that I'll either have no space left or too much space left. I was particularly concerned about that on this ship because of the number of items. That's the reason that I didn't build the coamings in before I planked the deck, which is my preferred method. I opted to have all of the pieces finished and moveable before fixing any of them in place.
My only exception is for the fife rails which I like to do first and get them positioned and then locate the other things working from the fife rails in both directions.
This ship has a lot of natural honey coloured woodwork and I was concerned about duplicating the look with basswood which is notoriously difficult to finish. My solution seems to be ok. It's a light wash of orange acrylic paint, very watered down, then followed up with a couple of coats of orange shellac.
One detail that this ship has that I haven't run across before is "baggywrinkles."
I've been wondering how I'm going to recreate those. I asked a friend who is an avid knitter if she had any fuzzy wool, so she gave me these samples:
I might be able to make one of them work, but then yesterday I spied this in the grocery store and bought it on spec:
In many ways it looks less like a cleaning mitt than a baggywrinkle dispenser! If this proves to be my solution,  it looks like I have a lifetime supply of baggywrinkles.
That's where I'm at for now. Many thanks for looking int.
David
  • 2 months later...
Hello All,
In my last post I was experimenting with ways to make the baggywrinkles. I found this “cleaning mitt” which looked like an ideal solution. It would have been perfect, however the scale was way too big, and the pieces fell apart if I tried to cut them down.
So I prowled the dollar store and found this cat toy. These little thingys would have been perfect, as they were about the right scale, but when I cut them off and attempted to thread them on the line, they just crumbled, so it’s back to the drawing board for the baggywrinkles.
At this point, the deck and hull are pretty much finished; later I just have to add the stanchions and rope railing along the rail.
I really hated the supplied life rings. They are cast, including the rope that surrounds them, which looked ridiculous to my eye, so I found these ones at Bluejacket without rope and then I added some rope myself. Not actually all that much fun to do, but the result is well worth it.
You may notice that I have omitted the airports that run down both sides of the deck. The ones provided have a large rim that protrudes above the surface, and I just hated the look of it. I did use them on the cabins, but I hated the thought of them on the deck. I know I can buy flush ones, but they would have required very precise holes to be drilled and I doubted my ability to do that 14 times. One misstep and the whole deck would have been ruined. The supplied ones with the large rim would have been forgiving and the holes easy to drill, but I opted to omit them nevertheless.
I was perplexed by the colour of the hull. It never appears the same twice in any of the pictures I find. It seems to change over the course of a season in the water. However, I found a picture of the hull being painted, so I used that one as my guide and managed to find a decent enough match.
I’m now well into the rigging and it’s always the same – as I near the end of the woodworking part of the build, I can’t wait to start the rigging and then as soon as I’m into it I wonder why I was so anxious to begin. In any case, it’s going fine.
I have been experimenting with upgraded blocks. On my CW Morgan I used Bluejacket cast blocks for the larger ones and Syren for the smaller ones. Both were great. For this model, I am trying Master Korabel which I bought from Vanguard Models. In addition to being good looking, these ones are also nice to use. They have very sharp grooves cut into each corner and the line really grabs. They never slip out of place. However, they are so finely made, that every hole has to be re-drilled to get the rigging line through.
I recreated the star decoration on the bowsprit on the computer.
So that’s it for now. Many thanks,
David
Very nice work David!  Very creative with your build, love it!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    Hs129B-2 1/48  SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32   IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48  Eduard Sikorsky JRS-1 1/72
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
I have now essentially finished the rigging. I haven't posted during the rigging phase as it wasn't very interesting and it simply progressed in the usual way.
I had one minor setback though. I had the same problem on a previous model, but failed to learn the lesson. I managed to break both the aft cross tree on the fore mast and the long spreader on the main mast. In both cases I had quite a bit of rigging already attached. I attempted to repair the breaks, but the result was pretty bad, so I had to undo the rigging and replace both broken pieces. The lesson I failed to learn is to not use the kit supplied basswood for these parts. There's a fair bit of tension on them and when I caught my finger on attached lines, it was enough to snap the parts. The basswood really isn't quite strong enough. It's much better to use some walnut or other hard wood for these parts which is what I did for the replacements. I suppose it would also work to use some very thin sheets and build up the thickness plywood style. I definitely will not forget this next time around.
Three jobs left to do - add the rope coils on the belaying pins - touch up the paint in a couple of places - and add the rope railing that runs along the top rail. It's not included in the kit, but I found some really great stanchions for it at Cornwall Model Boats.
I opted to omit the netting that hangs below the jibboom. I know that I simply couldn't model it in such a way that it would enhance the model, so I just left it off.
This model has two turnbuckles which are placed just aft of the fore mast near the top. I've seen several methods for making them on-line, but I don't really have the metal working skills required and in most cases I think the results tend to look a bit bulky and over scale, so I made dummy ones by sanding down a dowel to a very small diameter and adding a small eyebolt at each end. I think they fit the bill ok and are scaled according to the plan.
I always struggle a bit with some of the running rigging when not using sails. The plans show the model with sails and there is always a bit of tweaking involved by eliminated some of it and adapting some of it. I'm sure I haven't hit it 100% correct, but oh well.
So, I'm really in the home stretch now.
Thanks for your comments and likes.
David
My Pride of Baltimore II is now finished. I added the rope coils, the railing and stanchions along the top as well as the running lights.
I meant to mention the baggywrinkles earlier, but forgot. I tried many different ways to make them and nothing would work. In the end, I decided I'd been overthinking it and just used some pieces of wool. I found some wool the right colour and about the right size. I simply cut it into lengths and threading it onto the line and glued it. On close inspection it's obvious what it is, but from a slight distance, it certainly gives the right effect.
On the real ship, the stanchions for the rail are just a dull metal colour. The ones I have were brass, so I blackened them only slightly so that they aren't quite black, but aren't bright shiny brass either.
I always have trouble getting my rope coils to behave. I use Amati hemp from Cornwall Model Boats for the rigging and it's very nice line to use. However I can never get it to coil easily. The coils always want to go too round without appearing to hang. To solve the problem, I switch to crochet/tatting thread for the coils. I found one that matches really well and it's essential to use a very small size. It's Lizbeth thread, size 40, colour - medium mocha brown. This stuff is very soft and I find it much easier to use and it's virtually impossible to notice any difference.
If anyone is contemplating building this model, I can highly recommend it. It's a really good kit and the plans are very accurate. There are many resources available for confirmation and I found virtually no discrepancies.
Many thanks for your interest, and everyone, please stay well.
David
Wonderful work on your Pride of Baltimore, David. She has such beautiful lines. I have this model on the shelf and I'm beginning to think of my next build since I am nearly completion of the Medway Longboat which is my third model. My first two models were the Indian Canoe by Midwest and the Batelina by MarisStella. Both of these models were plank on frame as is the Medway Longboat so I've never done a POB build yet.
I've been spoiled by the quality of the instructions and materials of Chuck's Medway Longboat kit so I'm hesitant about jumping into the Pride of Baltimore primarily because of all the basswood that is used. The Medway Longboat uses Alaskan Yellow Cedar and the Batelina is walnut and both of those wood finish so nicely and crisp. The Alaskan Yellow Cedar is particularly nice to work with. Would you suggest substituting some other wood for much of the basswood in the Pride of Baltimore kit?
Congratulations on beautiful ship!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
This really came out well.  I really love the PoB II.  I am from Baltimore and remember when she was being built.  My father also has pictures of me in the shipyard when the Pride (original) was being built.  I also have this kit on the shelf and will eventually get to it.
Outstanding work, David! She looks a treat.
Bob, just my two cents, but basswood is more than adequate if you intend to hide all your work under paint (and PoB II has such a pretty paint job). Also, being a large model, replacing the kit wood might cost you some.
Cheers!
When you have to shoot, shoot. Don't talk.
- Tuco
Thank you GrandpaPhil and Bob. Much appreciated.
Bob - I don't have a lot of experience with woods other than basswood. I tend to be an "out of the box" builder, with only minor changes. I don't have too much trouble working with basswood, but of course you can't really scrape profiles into the edges of railings or any detailing of that sort of thing. My biggest complaint about it is how hard it is to get a decent natural finish on it. It tends to take stain poorly, with blotchy results. This isn't too big an issue for me generally as I prefer painted models rather than ones left natural, so basswood works just fine in that case. It does tend to stay a bit fuzzy no matter how much you sand it, so the secret is to get paint on it sooner rather than later, even if it still seems a bit fuzzy and sand it well between coats of paint - the fuzziness problem will go away.
However, on this ship there is quite a bit of natural woodwork on the deck furnishings. This was a bit of a challenge for me to finish. My end result might be a tad too orange, but it's not very far off the real ship. I find that watered down acrylic artists' paint works better on basswood than stain. So I used a bit of orange mixed with a bit of yellow and plenty of water. I topped it with amber shellac. At least it didn't go blotchy and looks fairly natural.
The deck on the real ship is quite a dark colour and I knew that finishing the basswood would be a problem no matter what I did so I opted to change the wood for the deck. I ordered .5mm strips in the appropriate width (3mm I think) and laid them over a solid thin subdeck. I got the strips from Cornwall Model Boats. They had both cherry and tanganyka in the right size. I wasn't sure which would be best and since it wasn't expensive, I ordered both. When it came it was in two unlabeled bundles and I literally couldn't tell the two apart, so I just dumped them all into one bin. They were completely indistinguishable from each other. Nevertheless it was all very nice to work with and stained beautifully.
So, to answer your question about substitution of wood, I wouldn't worry about changing it for the hull planking, the basswood will work just fine. It will work just fine too for the painted parts of the deck furnishings (basically the walls and coamings of the components.) You might consider changing it for the decking, mainly because it will be hard to finish the basswood and I suppose if you wanted to, it would be a nice touch to upgrade the wood for the railing and the parts of the furnishings that have a natural finish.(basically, the roofs or tops.)
The only things I upgraded other than the decking were the blocks and the rigging line. I've gotten so I really hate kit supplied blocks and the Model Shipways rigging line isn't all that nice. I've used Syren and Bluejacket blocks in the past and like both of them, but for this model I decided to try the ones from Master Korabel which I bought from Chris Watton. They are very good too. I would love to use Syren rigging line, but I tend to be a very profligate rigger and would have a fit for every inch of Syren line that I wasted. The Amati line from Cornwall Model Boats is a compromise that works well for me - it's pretty good to work with, the colour of the natural line is great and I find it to be quite affordable, even when I cut off a piece about three times as long as I actually need.
You will find the instructions with this kit to be useless. In fact I almost never even refer to them. The plans however are excellent. There are six sheets and every detail is there. So far as I can tell, they are very accurate and true to the real ship. Of course they aren't much help with respect to sequence and often you have to flip among several different sheets to find everything you need for a particular aspect. If I have any complaint about them, it's the rigging sheets. There are two rigging sheets and there is a bit too much information on each one. It would be easier to decipher if it was spread out over three sheets. Nevertheless, it's all there; it just takes a bit of work to ferret it out.
I chose this model for a couple of reasons - it really is a very beautiful ship, the model isn't too large, it doesn't break the bank to buy it, there are plenty of resources on-line for reference and there isn't too much rigging. (Three masted, square rigged ships just seem to daunting to me anymore.) I would certainly encourage you take on your POBPOB (plank on bulkhead Pride of Baltimore) next. I think you'll find it a great project.
David
I'm working through a USS Constitution cross section which I originally bought some 30 years ago. Next up is the Pride Of Baltimore II. We moved to Maryland about 3 years ago so this ship was a natural choice. I bought a kit on eBay which someone started but did not get beyond the keel and attaching bulkheads. To my inexperienced eye it looks OK but even if I have to do some "surgery" on it, it will be OK considering that I only paid $50 plus shipping.
Your build is gorgeous and this log will be a terrific reference for me.
With any luck, I'll visit the real ship this spring/summer and hopefully go for a sail on her.
Thank you so much for your detailed reply and encouragement, David. I've got several models to choose from for my next build. I'm going to get the POB off the shelf and take a look at it again. It will certainly be in the running. I'll be looking forward to see what your next build will be too.
Bob Garcia
Current Builds:
  • 3 months later...
I"m nearly done with my Constitution cross section so I'll start my POB very soon, maybe this weekend. I came back to your build to get my juices flowing and now that I have a bit of experience with ship building, I appreciate your work even more. The Chasseur alone is a little marvel! It's such a colorful ship, and your paint job is first rate. I'm bookmarking your build and it will be a sort of practicum for me.
Question; how did you form the ribs of the Chasseur?
"I have Bob Hunt's practicum for this kit, and while I haven't been following it, I did use the method that Bob suggested for this job. He suggested building each section of bulwarks between the gunports off the model, (spacing the stanchions correctly of course,) and then installing each as a sub assembly. This method is proving to work very well."
I like this idea and when I get to that point I'll use it, but with modification. I'm thinking, insert the stanchions without glue, glue the planks and rail, remove them for painting, then glue them in place. That should eliminate having to measure the spacing of the stanchions
That should work Paul. Just be careful not to get the stanchions mixed up. It's very easy to do; the differences are minimal, but fairly crucial.
