While your clamping process will work, I still prefer a plaster outer jacket for stability of the mold - especially during a 'pour'!
This is how it looks with the upper mold removed and then out of the mold.
98185625_Casting6a.thumb.jpg.98803a1f390a357fc9719919ffc3402e.jpg608608686_Casting7c2.jpg.e35f8b64fb4ba10d4eb0e067d1090c6e.jpg
In the middle is the master anchor, to the right is the cast anchor after polishing and to the left is the anchor after taking a bath in Blue Jacket's Pewter Black.
I applied the seizing and puddening to the anchor ring and then installed them on the anchors.
The anchor stock was made next.  You can see the holes drilled for the bolts and treenails.
The stock was then applied to the anchor and the "iron" rings were applied.   These are actually made from paper.  Overall, I am pleased with the result.
As I mentioned previously, I want to show the starboard anchor lashed to the hull.  As the ship's base will be a launching ways, the hawser cable would not be attached.  These pictures show the only location for the anchor that does not block any of the ports.  I have been looking in all the books I have, as well as looking at models on the RMG site, and cannot figure out how it should be secured.  I presume the shaft would be lashed to the aft timberhead but there must be some other rope securing it.  Any advise would be greatly appreciated.
1302371806_Anchorinplace1a.thumb.jpg.907e1319cdb34d54da03454c0e49e37f.jpg997025316_Anchorinplace2a.thumb.jpg.8d66f67240e47c121d5fe3217a0056ce.jpg
Toni
Member IPMS
                           Utrecht-1742
Toni-
First:  fantastic work!
Second: while no expert on the subject, it seems to me that some sort of temporary block and tackle would have been rigged through the cathead to support the "forward" end of the anchor while a lashing was made to the timber head to support the "aft" end (as you mentioned).  Sometime after launch, during fitting out, the permanent tackle for the cathead would replace the temporary one. This is all conjecture, though, in light of the high probability that the anchors would not have been shipped at all until final fitting out and the installation of the hawsers.
Jack
Nice castings and finish, Toni!
There may well have been a shankpainter chain used to secure the anchor, rather than the anchor lovingly hugging the swivel mount. It would be about in line with the aft end of the billboard/lining. This would raise the anchor shank parallel to the rail and the stock should then clear the water.
Although I installed a shankpainter chain on Atalanta, I have no idea how they worked.  Getting the stock out of the water sounds like a good idea.
Toni
Member IPMS
                           Utrecht-1742
How does this look?  The shankpainter would be bolted to the hull and drawn up over the bottom of the anchor shank and secured to a cleat on the inside bulwark.  The top of the shank would be secured to a timberhead.
Toni
Member IPMS
                           Utrecht-1742
Yep. Sounds good to me too.
"Anchors Aweigh!"...Nice work, Toni.
Ron
Former Director, Nautical Research Guild, 2021-2025
@modelshipdood on Instagram
Current Build: HMS Diana Update
Completed Builds: HM Gunbrig Cracker #13 (HM Adder Gunbrig)Grace & Peace (Wyoming, 6-masted Schooner), HMS GrecianHMS Sphinx (as HMS CamillaOngakuka Maru, (Higaki Kaisen, It Takes A Village), Le Tigre Privateer, HMS Swan, HMS Godspeed, HMS Ardent, HMS Diana, Russian brig Mercury, Elizabethan Warship Revenge, Xebec Syf'Allah, USF Confederacy, HMS Granado, USS Brig Syren
That's the general idea, Toni. There would also be sacrificial blocks of wood on the rail to protect it. However, there is one drawback: it would be tricky to get the anchor past the fore channel, deadeyes and laniards. I think that the chain would be secured to an eyebolt inside the bulwark with a hook on the 'free' end that engages a second eyebolt inside. Call in the Time Machine to be really sure!
Hi Toni -
Those are two excellent anchors.  And thanks for showing your casting methods.  My own experiments in that area have been less than completely satisfactory.
Next time I will turn back to your explanations and try again.
As for handling the anchor, since I don't have access to druxey's time machine, I pull out "The Young Sea Officer's Sheet Anchor" by Darcy Lever and see what he says.
There is usually a good explanation of the process.
Congratulations on the completion, or near completion, of a really sweet ship model.
Dan
Thank you to everyone who has looked in.  Dan, I looked at Darcy Lever initially and (possibly because of his archaic writing style) ended up more confused then ever.  A 21st century interpretation would be great.  In the meantime, I will try druxey's advise.
Toni
Member IPMS
                           Utrecht-1742
After looking at other models for ships this size, I decided to secure the lower shank with the shank painter.  As druxey suggested, one end is attached to a ringbolt inside the bulwark and the free end terminates in a hook which is secured in a second ringbolt. The upper part of the shaft and the ring were tied off to timberheads.  I have added a block of wood on the rail under the anchor to protect the rail from damage.
Toni
Member IPMS
                           Utrecht-1742
Wow, looking really good there.
JD
Current build: Schooner Mary Day (scratch)
Previous builds:  Model Shipways Pride of Baltimore 2, Amati HMS Endeavour, Midwest Muscongus Bay Lobster Smack, Bluejacket America, Midwest Sharpie Schooner
I am getting ready to install the swivel guns I made last year.  They look too tall to be used comfortably.  Does anyone know what elevation the muzzle should be from the deck when it is horizontal?  I am guessing eye level but would hate to install them and then find out I guessed wrong.
Toni
Member IPMS
                           Utrecht-1742
Based in information obtained in another thread (thanks to everyone for their input), I have decided to have the muzzle height at 4 feet from the deck.  Leaving for the Admiralty Models workshop tomorrow morning so there will not be any updates for a week.
Toni
Member IPMS
                           Utrecht-1742
Thanks, Greg.
Toni
Member IPMS
                           Utrecht-1742
Swallow is finished, other than a few touch-ups which will be addressed after I mount her.  My plan is to duplicate the base from RMG as much as possible.  It will probably take me a few weeks to source the wood and draw up the plans.
802308756_Finishedstarboardforequartercopya.thumb.jpg.e18dd9bc6c4f929bc32611baed716b9f.jpg
Toni
Member IPMS
                           Utrecht-1742
Would you build a model of the model (which is what I seriously thought of doing) or a model of how she and her sister ship Drake were built?
Toni
Member IPMS
                           Utrecht-1742
I would have probably built a model of the model....because source info is scarce on her.   The model in the NMM of course.  I would have found a draft of a similar ship and used those lines but then I would try and replicate the model.  It would be tough with it being in the UK however.  But if it was in the Rogers Collection I would do it for certain.
Nice work. Have fun at the workshop!
JD
A beautiful model, Toni, with great attention to detail.
That's a beautiful model Toni. I especially admire the fact that you have cast all the iron work yourself despite the presence of perfectly respectable items in the market place. Perhaps one day you'll come back and rig her when the mood strikes.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Thanks to everyone for your support.  Greg, rigging her is not on the horizon.  I already have three models that are incomplete because I abandoned their rigging.  As to what's next, the base will take a bit of time.  I have been considering Chapelle's  Glad Tidings as a change of century.  It only took the Smithsonian a year to send me the plans.  Their excuse was that their copier was broken (and, no, I did not suggest Office Max).
Toni
Member IPMS
                           Utrecht-1742
