i just love this project
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
I finally finished the cloister roofs!
I was also able to test a first ageing of the church/cloister ensemble before inserting, later, some vegetation.
Some tests are also being done on the hall...
So, here are the final views of this part : I'm going to throw you a tsunami of pictures ! 😁
Some views with my hand and ruler to realize the scale!
Close-up on the base of the hall:
Looking very good Ekis
One down and ??? to go!
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
very impressive ...........you've done a spectacular job with this project.   .......took you .......what,  20 years to bring 'er back out.....and look what a splendid model!  kudos!  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Amazing!!!! You've done good, very realistic but in miniature 😁 The market hall  is absolutely medieval Europe.
Edited by Edwardkenway
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
I didn't realize it was that small.   But wow... looking great.  I do really like like the photo below.
I finished laying the tiles in the covered market.
So I'm moving on to the suite that will be the "rural" house... Actually a town house. I'll have more to do, but this is the one from the basic kit.
And I'm transforming a bit what was planned: everything was to be made of stone. My version will have half-timbering on the first floor, which will be filled with bricks, the ground level remaining in stone.
The back wall is a part of the village wall: it will be with large stones for the sole, and normal size for the rest.
A 1st thin structure (1mm) of the studs is in place: it allows the 3mm thick bricks to be wedged. Once the bricks have been sanded, a 2nd layer of 2mm stained wood will come flush with the bricks ;)
Edited by Ekis
The construction continues quietly with the installation of the openings.
On the back, the stones are part of the outer wall, so they are rougher on purpose. The first bricks between the half-timbering are also started to see what it looks like.
A little idea of the mess on the desks:
Very Nice work again. Can I ask are there going to be any columns/pillars for the first floor overhang?
Current builds;
Completed:
Thanks for your answer: I still appreciate it! ☺️
Yes, of course, there will be pillars to support this very heavy first floor.
For this first house, I don't know yet whether I'm making them out of stone columns or wooden pillars.
I'll see that at the end of the construction...
But it will look like this type of thing:
really nice....the houses look great!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Beautiful work Ekis.  Your village is really coming along - nice work.  I especially like the dusting on the statue and the half-timbering looks very authentic.  Such a cool project!
Gary
Completed Scratch Builds
I'm at a loss for words..... You can find this architecture all over europe, but the cloister has a definitely northern italian feel to it....
Beautiful job.... it will be spectacular when finished....
Edited by Egilman
Quote:
Thank you all for your comments: it really motivates to keep putting stones and bricks on top of each other!
There's still a very long way to go to the end of this village, but if I manage to shape all the ideas I have planned, then it will be a success for this stone model.
It has waited 20 years for me to build it, it deserves some attention... 😁
This just gets more impressive every time I look in.
Fantastic work.
I have never seen post and beam construction with the fill area so much thicker than the beams. Interesting look.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Thank you all!
In fact Imagna, what you see at the moment is the placing of the bricks and stones with a first layer of wood that helps to glue properly and make the cuts.
In order not to put dust everywhere on the studs during the sanding, I first finish this step before "filling" the gaps with a 2nd layer of wood, this time tinted dark like at the time ...
But this final step will be in place only when I will not make any more dust, including with the roof tiles.
Small update :
- finished stone walls
- the studs are in place
- the first floor roof canopy
- window shutters
- all doors
There's still work to be done:
- the tiles in their entirety
- the stairs on the right (stone) and left (wood)
- stone doorsteps
- paving on the floor
- the pillars of support
- overall ageing
