Exquisite Dan!!  are those bolts properly threaded?
Michael
Every time I stop by your build I'm amazed - such precision on such a small piece! Absolutely spectacular!
The capstan plans for my San Felipe show the bars placed on the deck around the capstan...I'm guessing to keep them out of the way until needed. Was this common practice on the British ships as well, or just something unique to Spanish ships or maybe just the manufacturer of the plans?
Sherry
Every goodbye is the birth of a memory...
Current Build: San Felipe
Finished Builds: Mayflower Build Log
Gallery: Mayflower
Thanks John, Druxey, lamarvalley, TJ, Michael, Sherry, Pat and Laman - much appreciated :) .
where are the retaining pins for the capstan bars?
I'll leave those for Remco :D .
Of course they are ;)  . Just kidding :D .
Common to all Sherry - They take up a LOT of space when in use.
Can you link the upper deck and lower deck capstans together for heavy lifting?
Yes, they are linked for that purpose.
:cheers:  Danny
Cheers, Danny
Very, very impressive!!!!!.....and always look forward to future updates.
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
OK, I took Druxey's challenge after all - here's a prototype REPRESENTATION of a Bar Pin and "Chain" which took me about half an hour to make. I used 0.2mm (blackened) copper wire wrapped around a 0.25mm drill bit for the "chain", and made two "eyebolts" from the same wire :
And here's an approximation of how it looks by the naked eye :
I'm going to do another one using a simplified method (no actual Pin and Bolt, just one curled wire). If I can get it down to 5 minutes each and they look OK I'll do all 15. Stay tuned :D .
:cheers:  Danny
Cheers, Danny
Thank you John and Brian.
Here's #2 - about 10 minutes worth, including blackening. It's the one on the left in pic 4 and looks even better than #1, so I'm going ahead with all 15. Am I going crazy ??? :D :D  :
:cheers:  Danny
Cheers, Danny
I guess Remco will now have to "catch up" to you?  I think you rose to the "Druxey Challenge" and exceeded it . post-76-0-33090400-1366613753.gif
Also if there is such a cup can Danny drink his Ale from it.
Danny,
    Excellent detail work as always, and I agree Remco is now going to have to catch up to you LOL. Keep the pictures and post coming.
Wacko
Joe :D
Go MSW :) :)
Very nice Danny!
I guess Remco will now have to "catch up" to you?  I think you rose to the "Druxey Challenge" and exceeded it . attachicon.gifalarenverse.gif
 We'll see when I get there, my capstans 1.0 definitely don't have retaining pins. I think Danny is pushing me now to make 2.0 ;)
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Thanks Mark, John, Joe, lamarvalley (you got a name? ;)  ), Grant and Remco.
No need for a remake Remco, just drill a few more holes in the ones you've already made :D .
Here's the final results - they look pretty realistic in real life. One tip - Birchwood Casey Brass Black doesn't work on copper (I should have remembered this). It turns black all right, but it flakes off straight away leaving a mess behind :(  . I'll have to get some Liver of Sulphur for future work with copper :
:cheers:  Danny
Cheers, Danny
Looks super nice, Danny.
I think the next order of business is to design the "Druxey Challenge Cup".   Maybe something at 1:48?   :cheers:
Thank you Pat, Mark and Crackers.
You may have opened yourself up here mate; what's the next challenge going to be?
Compared to the bar pins, quite an easy one - the Capstan Pawls. These prevent the capstan from turning back, they were very simple things that were pushed into place with the foot of the sailor nearest to them. Later ships had more complex arrangements.
These were made from a piece of 1/16" square brass, filed down to 1/32" for most of their length - they step up to full height on the end that locks into the capstan whelps. They are held in place with a 3/4" bolt. Note how one pawl locks into place whilst the other is almost halfway across a whelp - this gave them two bites with a smaller rotation between.
I've also made the two for the upper capstan with these.
That concludes the work on the capstans for now - all that's left is to fit them, which I'll do after I've placed the Guns in this area (I'm still waiting on the barrels before I can start on them).
Next job will be the Rudder and associated works.
:cheers:  Danny
Cheers, Danny
Danny,
   I know it has already been said, but this is an excellent build you are doing. I also like the fact that you also show everyone that you are human just like the rest of us. Keep the pictures coming.
Wacko
Joe :D
Go MSW :) :)
Caramba!!!! I only expected the pins in their holes, not their chains as well, Dan. You've exceeded the challenge; which was only in jest, by the way! Well done. Now, what fiendish detail can I think of?
:o I have only one word that comes to mind: waw! Is this even possible? Well done Danny... The chains were there so that the bar pins would not be lost, right?
Will you make a working rudder assembly? (trying to contribute to the "druxey challenge cup" :D )
Padeen (Adeline)
"When there is a will, there is a way"
Completed build: Le Camaret - Constructo - static wood 1:35  (build log, gallery)
Current build (very limited modelling time at the moment...): HMS Fly - Amati/Victory Models - static wood 1:64 (build log)
Projected build: HMS Victory - Chris Watton's design - static wood 1:64 (when available..., no rush!)
Thanks Joe, Druxey, Adeline, reckon54 and Geoff.
I knew that Druxey ;):D  .
Correct :) .
Yes Adeline - it's not very difficult to do, apart from the rigging to the ship's wheel.
Rudder
The rudder is made from two main pieces of timber which are "tabled" together. I've made a simplified joint, there should be alternating tables in each piece but as only one side is seen at a time the difference isn't noticeable :
:cheers:  Danny
Cheers, Danny
Danny, you continue to astound me. My hat is off, and I bow to your mastery!! Keep the pics coming please...I am trying to soak some of that skill through the computer into my own fingers!
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Very nicely done Danny.
Michael
NICE :)
it's amazing how wood obeys u , keep up the good work
He trains it specially! Wait until you see his performing wood worms!!! :D :D :D
