Battle of Waterloo Attack on La Haye Sainte Farm 1/56 28mm
OC, the pond started out looking good. The color is very good.  Like others have said, let the resin do it's own thing as it sets.
Ken
Started: MS Bounty Longboat,
Link to comment
Share on other sites
Good day all,  I have decided to put the display case cover away  so I can work on the base - I  have placed  the building  plan on the base to check its positioning and room  - still lots more to do.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
Evening all,   more work on the base courtyard area  - this needed a lot of fiddling to get the pieces to fit to gether  - some choping here  adding pieces there  and adjusting the pond area base.
Oh  I have also re worked the pond  by adding some bricks that had fell in after the KGL  hacked then out to make firing  holes, I then added another layer of gel  and let it set over night  (I did not touch it and still needs more time to fully set)
OC.
Current builds
Completed works.
Link to comment
2 minutes ago, CDW said:
I like that pond! Makes me want to go fishing. 🙂
Thank you kindly  Craig, no fish in there  - I think the KGL  had then (if there were any)   the night before.
OC.
Current builds
Completed works.
Link to comment
52 minutes ago, king derelict said:
The pond water came out really nicely. Looks very wet!
Alan
Thank you Alan,   It taught me a  lesson to not play with it after pooring in the gel  - the second layer was poored than put away in the cabinet to harden on its own - not with a hairdryer.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Link to comment
OC,
  The model looks awesome!  Well done on the pond!
Sorry to hear about the wife’s fall.  Glad to hear she’s okay.
In the States we have something called Icy Hot and Bengay.  I use both heavily when I get banged up (as stated earlier, we don’t heal as quick as we get older).  They work wonders for me.
Edited by GrandpaPhil
Building: 1:64 HMS Revenge (Victory Models plans)
On the building slip: 1:72 French Ironclad Magenta (original shipyard plans)
On hold: 1:98 Mantua HMS Victory (kit bash), 1:96 Shipyard HMS Mercury
Favorite finished builds:  1:60 Sampang Good Fortune (Amati plans), 1:200 Orel Ironclad Solferino, 1:72 Schooner Hannah (Hahn plans), 1:72 Privateer Prince de Neufchatel (Chapelle plans), Model Shipways Sultana, Heller La Reale, Encore USS Olympia
Goal: Become better than I was yesterday
"The hardest part is deciding to try." - me
Link to comment
It's coming along nicely, OC.   I like the little touch of the brick in the pond.  I gather you'll put some more on the ground under the places they were hacked out?
Link to comment
27 minutes ago, GrandpaPhil said:
OC,
Thank  you kindly Alan, we have those  fabric things with  weat inside taht oyu heat up in the microwave  - she uses those  to help the pain,  she can't stand anything cold/freezing on the area though.
OC.
Current builds
Completed works.
Link to comment
Thank you kinldy Mark,      Indeed  - both sides of the wall, I might even mess around making some random rain puddles using my gel  - seeing as it was so wet the night before with pooring rain  the whole ground was sturated.
OC.
Current builds
Completed works.
Link to comment
Pond looks great, especially since it's was for the ducks. A few puddles will really make the ground "pop". Coming along nicely.
Ken
Link to comment
Thanks Ken.
OC.
Current builds
Completed works.
Link to comment
Evening all,  more work around the pond  -  I  cleaned up the slabs around the pond  then put down a few layers of  stone, then I did the same to the base around the pond,  and after some washes and dust, and finished with a couple of coats of flat.
OC.
Current builds
Completed works.
Link to comment
Good day all,   bit of an early post  -  next stage with this  I think I will be playing with some tables and  placing some KGL  around the  pond  firing from the walls,    I think it will be easier to do it that way than trying to see what I am doing when its all constructed.
OC.
Current builds
Completed works.
Link to comment
Evening all,    so  where were we?   ah yes  adding some details around the pond  -  the KGL lads  were desperate for firing platforms, so they raided the kitchen and found a couple of tables and benches  "perfect job"  these were positioned inside the wall between the brick holes.
First though  mr giant had to  assemble and paint/weather them then glue them in place.
Ok good start but needs some figures  - so I got my completed box out  and chose a few 2nd KGL to start with, first job was to carefuly remove the plastic bases they are moulded to  - had to be careful not to cut into thier feet,   then a little CA underneath  and they were glued down.
So its a start  and much easier with room to move them around.
OC.
Current builds
Completed works.
Link to comment
12 minutes ago, king derelict said:
And BANG it suddenly comes to life. The buildings are a great showcase for your figure painting. I'm so glad you are removing the bases instead of a war gaming style diorama.  The guys on the table look perfect.
Alan
Thank you so much Alan.
OC.
Current builds
Completed works.
Link to comment
The guy firing from the table is  this guy   -  https://projecthougoumont.com/rifleman-friedrich-lindau-2nd-light-battalion-kgl/
OC.
Current builds
Completed works.
Link to comment
Evening all,  Back on doing  some figures  -  as I was going to try out my airbrush  using the vallejo  acrylic primer, my first  job was to make my ultra expensive cardboard box spray booth,   I went the technical route and used  celotape  and a sharp blade  - so I cut a part roof out and frontage.
I took my compressor out of its box  - same with my airbrush  (reminded me of a fancy  fountain pan)  I unwraped  the airline  conected one end to the compressor  and went to attach the other to the airbrush   "where is the coupler to screw in"   "ah sussed it"  found it  with the spare  filter bowl  - then "hey pressto"  it just  pushes on with a click.
I adjusted the pressure to aboit 1.5 turned it on  "wow  its quiet"  I poored a bit of un diluted vallejo primer  (next time perhaps it needs a bit of diluting)?  as it dried very quick in the airbrush bowl  (should I have stired it while using it)?    anyway   the trigger has a double action  - down and  front/back  it was a bit fiddly to find a sweet spot so I just pressed it down and mainly fully back  and sprayed away on Three of my KGL figures.
No worries even first attempt the  primer went on smooth and a nice thin layer - "very impressed".
So  I used my  airbrush cleaner and blasted it thorugh several times till all the primer had gone and it was fully clean, carried on just blowing ar through it then to make sure it was clean.
Anyway  here is the result  and my set up  including my first brushed on pink layers  for faces and hands  - stage one of the skin laywers.
OC.
Current builds
Completed works.
Link to comment
Nice job with your airbrush on the primer!
The figures on the firing steps look fantastic,  a taste of what's to come!
Keep on with the great work OC😉
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
Thank you kindly Edward.
OC.
Current builds
Completed works.
Link to comment
Looks great OC. You made a good choice for your 1st airbrush. You will gets years of fun with it.
In your spare time, practice spraying the airbrush on card or paper to get a better feel for everything you can do with it. As you pull back on the trigger, you increase the amount of paint coming out of it. Pull back little and you can paint very fine lines. Pull back more and the line width will increase. With practice, you will become comfortable with how much is enough for the particular task.
Link to comment
Thank you for the advice Craig  (certainly a new experience for me)   how about the compressor pressure - I set it to 1.5bar, is that about right for most acrylic paints used with it?
OC.
Current builds
Completed works.
Link to comment
OC.
Sounds about right. Here in the USA, I use a pounds per square inch (PSI) scale rather than bars, but the conversion is 1.5 bars = approximately 22 PSI. The thicker your paint, the more pressure you will need to push it out of the brush. When you are doing large work and need high paint volume, you turn the pressure up. When you are doing fine work, you thin the paint and turn the pressure down a bit. It's something you will have to experiment with to get the hang of it. Vallejo Air paints are supposed to be ready to spray through your airbrush straight from the bottle, but sometimes I may need to add a drop or two of thinner to get it to behave properly through my airbrush.
I set my pressure at the compressor around 24 PSI, then I use a second air valve to regulate my pressure down at the airbrush. With this valve, I adjust it by feel, not by a gauge since I already know the pressure is 24 PSI on the high end, I just adjust it down according to my particular need, testing it on a piece of paper or scrap plastic first before spraying my model.
Look on youtube. There are a ton of good videos on how to use the airbrush as well as how to thin the various paints.
Link to comment
OC.
Congratulations on your first air brush session. I use any left over paint in the cup to experiment on a piece of cardboard to learn about distance, pressure, trigger position (mine is a double action brush too). I'm still trying to get away from trigger down and fully back for everything and learn to use the part positions for finer lines. I think that is a key skill for free hand use of the air brush.
The figures have very dynamic poses and great faces. Its hard to remember that they are not 54mm
Great Stuff
Alan
Link to comment
Thank you kindly for explaining all that  - currently doing some reading up.
OC.
Current builds
Completed works.
Link to comment
Great Stuff
Alan
Thank you Alan,   I guess its that dexterity situation of getting used to fine adjutments and knowing how to control the flow.
OC.
Current builds
Completed works.
Link to comment
Good job on your first airbrush session. Great info from Craig and Alan.
I've read and seen on the YouTube vids a technique to put a drop or two of flow improver into the paint cup with your conditioned paint. Opinions, gents?
Ken
Link to comment
not so much a stranger this time...........catching up was a lot quicker  ;)     really nice job with the dio.........the pool looks great and your small set up shows how good it's gonna look!  I got back into airbrushing when I started to build wood ships........too much surface area for a brush alone! ;)   yup...practice will make all the difference.   the more you do,  the better your gonna get!  fantastic job so far my friend.......keep up the good work! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
