Planking is done!
Also the bulwarks.
next thing is the rudder and then de paint job...
We have bought a spray can so hopefully it is going wright......
If not, sandpaper is close 🙂
Sjors
May want to do a test to compare a spray can to using a brush on the hull. The brush strokes on a wooden sailing ship would look more natural than the static look of spray paint, in my opinion.
Regards,
Glenn
Current Build: HM Flirt
3 hours ago, PeterB010 said:
Hi Sjors,
Just found your build log and picked up a chair to follow your progression.
I can not wait for the result of the paint job with a spray can.
Regards Peter
You are welcome Peter.
I will see how it goes with that spray can.
I understand your feelings Glenn.
That’s why I always use a brush but my wife was saying....try a can.
And who am i to go against the Admirals order? 😛
Sjors
Tell her spray cans are bad for your Lungs and the ozone layer😁
Regards,
Glenn
Nicely done, Sjors.
I somehow missed the start of this log Sjors. It’s good to see you back and building again. Your Flirt is coming along very nicely indeed.
Hi Sjors...... long time no  see or hear from you  ...like your build looking real good..Ill be stopping by now and then to watch your progress
 Give my best to Anja... have fun....
Frank
completed build: Delta River Co. Riverboat     HMAT SUPPLY
                         USRC "ALERT"
in progress: Red Dragon  (Chinese junk)
Thanks you all for the nice words.
@ Grant,
It’s still a long way till the end so, welcome!
@Frank,
 Indeed a long time ago!
 Everything allright with you?
Now and then Anja is searching for you Can not  find you...
She is saying Hi to you!
And welcome!
Sjors
looking very nice, the hull has sanded up very well
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Because I don't like the waterline I chance it a little.
I keep it this way otherwise I will damage more then I want.
Next time I will get a real waterline tool.
Sjors
Or I make a BIG mistake or I don't see it.
When you take a look at the picture of the Manuel you will see that the Stern Counter Timber are following a curve of the stern.
When I take my model and put the stern counter at the same way as te Manuel it is totally different.
That's the next picture.
At the Manuel it is saying that it has to flush with the stern underside curve.
But I don't have that curve.
So.......help or something?
Sjors
I don't have a perfect solution (and would recommend waiting for feedback from others), but that piece (I believe) is oversized to accommodate building differences. Therefore I don't think you want to line up the top part at the stern, I would align the bottom end (not the higher end towards the back) to see how it looks first.
Can you show me a photo of the stern?
It looks like you just need to trim those black wales to the curve of the stern counter. That part is definitely curved:
Ongoing:
Ok, it looks like you haven't curved the stern counter No. 38, and then clamped/pinned it to the curve on the underside of there stern frames No.30, No.31
These images are from the kit manual and plans:
All I can suggest you do is to now ignore that lack of curve and make too replacement parts for the Stern Counters, and make them match the shape of the stern on your own model.
EDIT: Looking at position of wales at your stern, there wouldn't be space to add those Stern Counter timbers, so I would just ignore them.
Ongoing:
I will see what to do.
Maybe it Is good for future Flirt builders to take attention to that.
In my opinion i have follow the curve with the planking or that building ghost is still in the house!
Thanks Jim.
Tomorrow another day with new changes.
Sjors
This is what I did. My wales took up most of the space and the boom crutch parts 128 tied into the wales so I left it at that.
I just build for fun and I'm not worried about getting things perfect, so obviously keep that in mind with anything I say or do. 😃
Sjors,
I also found the stern counter timbers tricky, although I did manage to impart a curve to the stern counter by clamping it whilst it was drying:
Here's a link to my Speedy log where I fitted the stern counter timbers.
I agree with dkuehn - if you can get the boom crutch to tie in neatly with the wales it will look fine. However if you can fit the stern counter timber as intended it will be even better.
Derek
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
Enjoying watching your build, Sjors! Great job so far 🙂
Tom (MadDog) McQuiggan.
Member of Nautical Research Guild
Current Build : VAPORETTO MOTOBATTELLO VENEZIANO           Finished Build : AIRFIX 1930 BENTLEY
And Later On : PANART VICTORY BOW SECTION                           Finished Build : BILLING BOATS, ST ROCH
And Later On : EBBRO CITROEN DS21
HOBBIES : Amateur Radio : Motorcycling : Model Making : Painting/Sketching : FlightSims : Photography : Slave to none!
I don't like the paint job at the bow so a little bit of sanding and painted again.
In my opinion it looks much better now.
Also placed the anchor hawse bolsters and the upper rail.
Sjors
Coming along nicely Sjors 👍👍
Thanks for the likes.
Always a pleasure that you see that someone is watching.....
Done a little bit more.
Place the rudder and hinges, catheads, stern section  and bow section.
All that is seen by the pictures.
Now we go to the interior .
Sjors
