While various parts are drying I assembled the mid deck bulkhead.
Everything fit perfectly.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
I've started making the Duchess shine with some of her fancy window and port decorations.
All were glued in place with a touch of CA glue.
DSC00252.thumb.JPG.21070886c6acc5dd797d0f30b6cb6c7f.JPGDSC00253.thumb.JPG.f7f303dc21d8bc1dfac02f7b3342d4e7.JPGDSC00256.thumb.JPG.d29f99aacca1a5187ce2e132dfcf3f26.JPGDSC00263.thumb.JPG.9badb00b8938baa017b07ee2bf2932a3.JPG
And here is the first of the photoetched decorations. Being the cautious type a tiny drop of CA was placed on the backside tacking them in place. Two coats of Future (Now Pledge Revive It) were applied and must say I'm happy with it so far.
DSC00280.thumb.JPG.b87abfb6c6a956c9c3e60bedc7ab076f.JPGDSC00283.thumb.JPG.9d25687f6dd9ce148c17ace6cc74d8cc.JPG
Rusty
That decoration is so much better than the old-school castings in kits like Royal Caroline, and contrasts beautifully with your fine planking.
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
I admire the expert painting, the gold really pops! It is so weird that the Revive It works, but clearly it does.
Regards,
Glenn
Current Build: HM Flirt
14 hours ago, glennard2523 said:
Great work
Thanks Glenn, I'm trying to keep up with your fine work.
12 hours ago, James H said:
That looks so very pretty 😊
Thanks Jim, The decoration is what attracted me to the DOK.
Thanks DelF, This is some of the nicest PE.
Thanks Glenn, I too was wondering and the cautious side of me had to use a dab of CA just in case but it seems to work just as advertised. :)
Rusty
Thanks Bob
I've completed the the fancy PE on the bulwarks to the bow now.
DSC00284.thumb.JPG.8074167de15ee4b8852d55c7f04438a4.JPGDSC00286.thumb.JPG.c14660c999ceac508beb16b1fbcdfe93.JPG
The figure head was primed and then painted gold.
After it was dry I placed it on the stem. A little sanding was needed to get it to slide in place. Then I placed the remaining PE at the bow.
DSC00291.thumb.JPG.8576bbdbc7e3144fc8777288d8589e70.JPGDSC00290.thumb.JPG.82a0b4a20322b33475c8b453fc8209b3.JPGDSC00289.thumb.JPG.68cd52ae46cea19dc2ff782f9de83e62.JPG
Rusty
That really is coming to life. I know there's a lot of PE but it does fit beautifully and doesn't take too long.
Ongoing:
Splendid work! And very beautiful golden painting on these PE.
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
Thank you Chris, Glenn, Jim, Glenn again, B.E., Jean-Paul and Bob. Also all the likes!
Everything is designed and fits so well that good results are almost guaranteed.
Rusty
Beautiful work Rusty. This is next up on my list. Question if your hull bottom is white wouldn’t the horse shoe and bow tie fittings also be white?
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Thank you PJG and all the likes
Thanks Jim, The instructions have them gold so I stuck with that. I've also seen them the same color as the hull painting and black. I don't know what would be accurate on a real ship.
10 hours ago, BobG said:
What gold paint are using? Are you hand brushing or spraying?
Thanks Bob, The gold and white are rattle can spray paint. I'll have to get the brands when I get home but they are generic paints. The red and blue colors are brushed on. They are Admiralty Paint Red Ochre and French Blue.
Rusty
Hi Bob the gold is Rust-Oleum Imagine Craft and Hobby Metallic Gold and the white is FINE surface primer.
Rusty
The channels have been placed by inserting in the designated holes. Channels were pressed against the points to mark their location. A pilot hole was drilled and the channels glued in place.
DSC00297.thumb.JPG.243c499d5cf139ae009fb2f16f194406.JPGDSC00300.thumb.JPG.218df0808fbc73280ebe98069f7270e3.JPG
The rudder was assembled and attached to the stern with the PE pintles and brace straps as per the plans.
DSC00257.thumb.JPG.9cc7767dfe827751048539598cf94d62.JPGDSC00316.thumb.JPG.4bc6c6b6bb62ca352b70666b94f58336.JPG
Rusty
Thanks Glenn. Trying to follow your, Jim's and Bob's fine examples.
Thanks Joe.
Thanks Chris, You've done a fine job designing the Duchess.
Thanks Sjors. Also thanks for all the likes.
Rusty
As the build has been progressing I've been building some of the various deck pieces.
If I'm waiting for glue or paint to dry I would work on a piece.
Here is some of what has been built so far.
DSC00268.thumb.JPG.f3ee1cb1c545ed751974e341c696713d.JPGDSC00270.thumb.JPG.d2ad468359e29a0e951946363471b6b3.JPGDSC00269.thumb.JPG.ddc29ce032f22fcc7da666059a6d407c.JPGDSC00273.thumb.JPG.1c9dc8f2768f823629537e9173ac0ef9.JPGDSC00265.thumb.JPG.3a40578fef28e3bf0aa4b179727952dc.JPGDSC00274.thumb.JPG.62cd1355d3a105854323eb26144cad0c.JPGDSC00258.thumb.JPG.ffdff62de9cff98efac2de185d2909f1.JPGDSC00259.thumb.JPG.b3523fa3cc71d93b11fbc780ac361165.JPG
This will make things move much faster when I start working inboard.
Rusty
Thats what I did also. I really enjoyed making all the inboard deck items. The grating for the middle hatch needs to be fitted later so the anchor ropes can be added. The other option, if the grating is already glued, is to fit the rope to the middle hatch assembly before it is glued to the deck.
Glenn (UK)
