American LaFrance Eagle Fire Pumper - Trumpeter - 1:25 Scale
CDW
4 hours ago, CDW said:
I am wondering it it's supple enough to lay flat
Like EG says, I think you will find that an iron will do the trick. Just use a rolling pin on the metal stuff and then solder it here and there to make certain it stays flat. Speaking of soldering how about soldering wick?
 https://www.digikey.com/en/products/detail/chemtronics/50-6-25/306991?utm_adgroup=Desoldering Braid%2C Wick%2C Pumps&utm_source=google&utm_medium=cpc&utm_campaign=Shopping_Product_Soldering%2C Desoldering%2C Rework Products_NEW&utm_term=&utm_content=Desoldering Braid%2C Wick%2C Pumps&gclid=Cj0KCQiAoab_BRCxARIsANMx4S5RY_kIohU61_RDZmY9RG_NRLZohVNh_tW8JRx70sj1FWuMulvTDdcaAoJyEALw_wcB
Edited by lmagna
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Link to comment
Share on other sites
Actually the hose jacket is canvas and the texture is not real rough - remember the firefighters need to be able to drag it and rough ='s hard to drag.  It is a heavier canvass than used on roofs of boats.  I just looked at the roll of solder-off in my shop and it's way too coarse.   The texture will not be very noticeable at 1/24 or 1/25.  Smoother would be less noticed than too rough.  I forgot that some FD's use extruded hoses - not in this area though - smooth except for the longitudinal grooves.
Check this suppliers photos - https://www.edarley.com/fire-hose/
 They actually show yellow booster hose now!  Never saw any but it is made.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
Link to comment
Okay, I put my thinking cap on and believe I may have come up with a solution for the hose. Going to do some more painting first, then experiment with an idea for scale hose. If some type of thin metallic flat stock was used to retain a flat shape, then covered with heat shrink, that just might make a convincing facsimile for fire hose. I have saved quite a bit of photo etch "sprues", and will try using them to cover with heat shrink to see how it looks.
I could cut off some little sections of 1/8" ID brass tubing for the couplings.
Edited by CDW
Link to comment
Try gluing or soldering the hose fittings to the metal before the heat shrink is added and make a smaller shoulder on the fitting for the heat shrink to grasp
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
Link to comment
Link to comment
I have to say  - its Great having Kurt  sitting on on this build   -  Its an interesting build as It is  but also great having Kurt  chat on here 👍
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
50 ft.
I offer this as a realistic appearing option - that might be much easier and I myself wouldn't hesitate to use the technique.
Maybe they do it differently in other areas but every place I have ever visited and looked at fire apparatus the hose beds are covered by removable covers.  Water resistant to waterproof canvas covers with easy release snaps or tabs that need to be turned90 degrees to lock in that cover the hose bed side to side and end to end and then hang down at the rear so the hose stays dry on the outside.  Dirt in the canvas covering will mildew and get grungy if allowed to get wet w/o being allowed to dry out.  Packed in the hose bed it doesn't dry out.
Model the rear of the hose bed like the photo used earlier.  Make a cover that covers the hose bed and shows just a bit of the rear end that is packed in - using about 10% of what you would need to fill the entire area.  Use a Styrofoam block behind the hose to "fill the bed"
Just like using a canvas cover on a life boat so you don't need to detail the interior.
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
Link to comment
OC.
I agree 100%
Just now, kurtvd19 said:
50 ft.
Yes, exactly right...no need to go crazy making hose, just enough to show it's there with the cover over the rest. Thanks!
Link to comment
Will have to give this paint some time to cure before I apply chrome trim, accessories, interior, and decals. In the back of the cab where it's got the diamond plate texture, will mask that off and paint it aluminum. The decals will be as per the box art. I received some alternate decal lettering for Philadelphia, Scranton, and Baltimore, but I prefer the quality of the kit decals, College Park. The alternate decal sheet appears too small, out of scale. Maybe it's 1:32 scale instead of 1:24 scale.
IMG_1401.thumb.jpg.f89c977084d4f3e62c1068a17ef9f2fe.jpgIMG_1402.thumb.jpg.e8d75da228caccd03954b8e5eb6cbfd9.jpgIMG_1403.thumb.jpg.22b49e298ae1bcea9f44a814eb02c6fe.jpgIMG_1404.thumb.jpg.a0f7e29e3bcaade356e3aa1ab71b4b3d.jpg
Link to comment
They were probably just as excited as if they were reeling in Jaws when the fish grabbed the hook!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Link to comment
Fish fry anyone? Well done by the lads.👍
Ken
Started: MS Bounty Longboat,
Link to comment
The kit has a basic interior. For the most part, it cannot be seen while sitting on the shelf so I chose not to spend a lot of time trying to detail it all out. It's painted in a two-tone gray. Notice that some of the seats have the hollow seat backs so the fire fighters can be seated with their breathing apparatus on their backs.
IMG_1409.thumb.jpg.b49ba3083e3969e443363edd7abb0158.jpgIMG_1410.thumb.jpg.4329c0b3dff979b48b3cd99b75e9b94f.jpg
Link to comment
Link to comment
That's not great Craig, would a gentle heat take the warp out? Otherwise it's looking good!
Current builds;
 Henry Ramey Upcher 1:25
Providence whaleboat- 1:25     HMS Winchelsea 1764 1:48
Completed:
HM Cutter Sherbourne- 1:64- finished    Triton cross section scratch- 1:60 - finished
Link to comment
That is a bummer. Like Edward says, maybe a little heat?
Ken
Link to comment
That may work. Clear plastic is very brittle and these are particularly thin. working a heat source trying to woo them into shape is risky. Once the paint on my coachwork is thoroughly dry, I may rather try masking them tightly in place while glue dries. I can force them into place, but it will take the glue to hold them in place afterward.
Link to comment
Even heat and gentle massaging of the kit parts or replacement with thin flexible acrylic.... You should be able to bend the acrylic around the warped pieces to get the right shape, and you can pressure bend them into the right shape for gluing....
The other option for creating windshields is again using clear acrylic to make the replacements, the same as above, using .005 styrene rod or quarter round, build a frame around the opening and then install the flexible acrylic windows just like the real thing.... paint the styrene frames rubber to look like the black gasket that is used in real life to install them.....
Two best suggestions I have used.....
Quote:
Link to comment
soaking them in hot water should soften them enough to flex the warp out.......direct heat will deform them.  I hope you can fix 'em.......the model is coming along nicely........great job! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
I used rubber bands to hold/force the windscreen panels into shape, seated against the frame rails then cemented them in place with liquid cement. It worked well with the only casualty when some cement found it's way onto one of the rubber bands due to capillary action then slightly defaced one windscreen. I think I can polish most of that out, but the windscreens themselves are in place and not warped now.
I can relax a bit now. Replacement parts from Trumpeter have to come through Stevens International (USA Distributor), and they are well known for their lack of customer support/service. In other words, fuggitaboutit.
Link to comment
Off-Subject BUT, Does anyone know...did DeAgostini Model Space in the USA go out of business? All I can find now is their website in the UK.
But I did find now there is a USA website that is associated with Hachette: Agora Models
https://www.agoramodels.com/us/bismarck/#buy-bismarck
They run a business model similar to DeAgostini.
Link to comment
Wasn't they related somehow perhaps?
OC.
Current builds
Completed works.
Link to comment
Link to comment
https://www.model-space.com/us?gclid=CjwKCAiAirb_BRBNEiwALHlnD_5t0iACEvoeqkMW88xkqZHz7OWKNNJd0DqOIIIrHVdqnwluCXIGyRoCm3oQAvD_BwE
Quote:
Link to comment
Just now, Egilman said:
This is interesting. I opened a different browser and then this link worked for me. Before that, the browser I currently use most often gave an error message when I tried to open that link. That's why I was asking if DeAgostini had gone oob.
Link to comment
Fantastic work!
Mike
Current Wooden builds:  Amati/Victory Pegasus  MS Charles W. Morgan  Euromodel La Renommèe
Plastic builds:    SB2U-1 Vindicator 1/48  Five Star Yaeyama 1/700  Pit Road Asashio and Akashi 1/700 diorama  Walrus 1/48 and Albatross 1/700  Special Hobby Buffalo 1/32  Eduard Sikorsky JRS-1 1/72  IJN Notoro 1/700  Akitsu Maru 1/700
Completed builds :  Caldercraft Brig Badger   Amati Hannah - Ship in Bottle  Pit Road Hatsuzakura 1/700   Hasegawa Shimakaze 1:350
F4B-4 and P-6E 1/72  Accurate Miniatures F3F-1/F3F-2 1/48  Tamiya F4F-4 Wildcat built as FM-1 1/48  Special Hobby Buffalo 1/48
Citroen 2CV 1/24 - Airfix and Tamiya  Entex Morgan 3-wheeler 1/16
Terminated build:  HMS Lyme (based on Corel Unicorn)
On the shelf:  Euromodel Friedrich Wilhelm zu Pferde; Caldercraft Victory; too many plastic ship, plane and car kits
Future potential scratch builds:  HMS Lyme (from NMM plans); Le Gros Ventre (from Ancre monographs), Dutch ship from Ab Hoving book, HMS Sussex from McCardle book, Philadelphia gunboat (Smithsonian plans)
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
