Hi Rusty, everything looks great but maybe you could have modified the planking below the gunports so there wasn't that little strip beneath them, using the tabbed approach. That's what I intend to do on the Echo.
Keep the updates coming buddy.
Ben
Hi Ben. You read my mind. After looking at the pictures I remembered Chuck doing it
and will attempt it on the tops. Not gonna rip off the old though. :huh:
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Ok here is my attempt to duplicate Chuck’s work, again. Not as good as his but I’m satisfied.
When I planked around the sills I thought I was going to be around ½ a plank wide. But once I
put the plank in place finished trimmed it and sanded it flush you see I only have about a
¼ plank width. So with that I attempted to do the tabbed approach Ben mentioned and Chuck
demonstrated on the Winnie.
I started with cutting a plank the width of a regular plank plus the width of the tab to cover the
lintel. I then marked the entire plank at the regular plank width, then marked the widest point
of the of the tab and the narrowest point so I would know what angle to cut. I then slowley
removed the excess wood and kept testing it until I was satisfied with the finished piece.
Then it was glued in placed.
Next I'll treenail both sides.
Rusty
Rusty....
   Very nice touch on your models...the result was worth the extra effort.
It is so amazing how this many people can start with the same plans and come out with what seems endless variations of the model by adding their own touch.
You have done a great job on yours :10_1_10:
Triton Cross Section 1:32
SEE YA LATER
im-outta-here-bye-bye-smiley-emoticon.gi
Looking Good.
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Thank you Pete, both Grants, David, Matrim, Ben, Paddy and 42 Rocker! :)
Bob, Funny you say that. I've always looked to you for insperation to do my best. Thanks! B)
Ok I've spent a whle drilling hole for the treenails.
Gonna draw the treenails tonight and start plugging those holes!
Rusty
lovely work - i have so much to learn - loves the wood colours
all the best
All the best
Kevin
KEEP IT REAL!
On the build table
https://modelshipworld.com/topic/25373-hms-enterprise-by-kevin-caf-148-august-2020/
My other builds:
Rusty, u still going to use boxwood for treenails?
I just drew down a load of bamboo for the Echo frames, installed and sanded them and they are invisible!!! I expected to be able to see them a little bit!! You wouldn't know they were there!
Your drilling is excellent as always.
Ben
Hi Ben,
Thanks and yes I'm going to continue using boxwood for the treenails for this build.
I think I will try bamboo later on the Echo. :)
Rusty
Boxwoods a little to delicate for tree nails for me so well done for having the patience to draw them. I  only used bamboo because of my rather cack-handed way of pulling them..
:D LOL :D I had to google "cack-handed" just to make sure I had the right meaning! Love It!
Rusty
LOL.... not at you but with you. Sounds like someone I know very well. :D
1st Year Apprentice :mellow:
A new member of the NRG as of 8/28/13
Work in Progress -
 Triton 28 Gun Frigate Cross Section
Hi Lee-c, Thanks and welcome aboard!
Nothing much, just filled all of those holes and sanded the treenails down.
I think I'll finish the inboard planking before I do the fenders and steps.
Rusty
Hi All,
Well I’ve completed planking the inboard bulwarks with the red heart.
It was very straight forward and went every well.
Now it's time to make the steps and fenders. :)
Rusty
Thanks Pete and Russ. It was fun using something different.
Rusty
Rusty,
You continue to push the bar higher..  Love the colors.  I never thought of redheart for bulwarks but that looks great.
Question, I understand redheart darkens with time.  Do you know if a finish will stop that?  Or like cherry, does it just get darker and darker?
Thanks Mark. I first used Red Heart on the Mayflower around 3 ½ years ago. I applied
around 4 coats satin wipe on poly and it still is the same color. I’m hoping that several
coats on the Triton will help it hold the color too. I’ve also heard that the biggest cause
of color change is sunlight. So I also plan on keeping it away from direct sunlight.
Time will tell. :)
Thanks Bob. I’d say great minds think alike but the Admiral would have issue with my side of the equation. :o
Thanks Ben.
Rusty
