Good eyes Rick. 😳 Guess I get to build and use a special tool or two. 😆 One of the reasons I love using this forum! Thank you! 👍
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
10 hours ago, Dave_E said:
catwalks
Rat lines 😊
Hopefully the lines aren’t fixed yet so you can loose them in order to get inside for the boom and gaff as well as those missing cleats. Remember I mentioned bottom up, middle out.
Bees wax can help with furry lines.  Interesting comment about MS rope, I haven’t seen ROS’s product but there is no comparison to what Chuck provides, it’s worth its cost.
You’re doing fine for a first model, hang in there. It will all pay off on your next one.
Edited by glbarlow
Regards,
Glenn
Current Build: HM Flirt
Thanks Glenn,
Cat 😳😆. No argument from me on ROS or Syren ropes for sure. I certainly hope all my boo-boos and learning will make my next build that much better. 👍
Dave
So sorry your rudder broke, Dave, that's such a drag. All the 100% cotton thread I've every seen has been fuzzy. There are cotton/polyester blends that are less fuzzy but for the time spent why not go polyester and be done with it. Poly doesn't rot like cotton but some folks say polyester thread stretches. I have a model I rigged years ago with poly and I don't see any sag. Some museums are now using polyester line on renovations.
I may ask this more than once. In the photo below… how do I attach the block to the yard?
Dave
Dave, I'd use some wire and CA glue. Wrap the wire around the block then twist together then around the yard and glue. When cured snip of the excess and paint.
Current Build: Fair American - Model Shipways
Awaiting Parts - Rattlesnake
On the Shelf - English Pinnace
                        18Th Century Longboat
I stand firmly against piracy!
See post #626 in my Cheerful log, substitute the block for the thimble. Personally I’d never use wire for any rigging.
Edited by glbarlow
Regards,
Glenn
Keith, the rudder wasn’t too bad a disaster. Broke a couple hing points but the pieces were all there, so I was able to put the rudder back together, a little paint touch up and all good. Then I put it aside! 😆 Here is an update. I took apart the forward two shroud assemblies to better get at things. My career in aviation manufacturing and reading “drawings” has brought me to the conclusion that I hope the average set of drawings is not as bad as these of the LN. I have found so many discrepancies it’s not funny. However, I’ve learned to look past them. You can see in the photo, I had to add 3 pieces of block rigging to the top of the shroud stack on the mast cap. I’m pretty sure those should have been below the shroud stack. I got the cleats on the mast and have decided to leave the forward shrouds undone for now. I think my next step should be to get all the blocks onto eyelets that are on the deck. Still wondering how to do that. Glenn? 😁
Dave
 Dave, you have to make a hook and then rig/tie the hook on the end of the block. As you may know I use wire to strop my blocks so for me it's relatively easy to do so. Glen doesn't use wire but the process is the same except you use line.
Edited by Keith Black
Your LN is looking great Dave. You mentioned getting blocks attached to eyebolts on the deck. Have you glued the eyebolts in yet? If not, it's easy to attach a block and eyebolt together and then glue the eyebolt and block assembly in place. If you have already glued the eyebolt in place, it's harder, but only by a little bit and will probably involve a bit longer piece of thread. Do you know about a "figure of eight" seizing?
Thread the line through the eyebolt, then make a "figure of eight" and add a seizing. Place the block in the loop and slide the seizing up tight against the block. Then you can pull both ends of the line and the block will snug up against the eyebolt. If you use a fairly long piece of line, you can add the seizing well away from the deck, where it's easy to hold the line in your "helping hands" clip.
This is also how I would attach a block to a yard, as you asked in an earlier post.
I hope I'm understanding your question correctly and I'm sorry if this is redundant.
David
Current Build - St. Roch, Billing Boats; HMS Agamemnon, Caldercraft (on hold)
Previous Builds - Armed Virginia Sloop, Model Shipways; Constitution, Model Shipways; Rattlesnake, Mamoli; Virginia Privateer, Marine Model Co, restoration; Prince de Neufchatel, Model Shipways; Charles W. Morgan, Model Shipways; Pride of Baltimore II, Model Shipways, Bluenose, Model Shipways (x2); Niagara, Model Shipways; Mayfower, Model Shipways; Shamrock V, Amati; HMS Pegasus, Victory/Amati
 Dave, here is a great blog on making hooks.
By not putting those eyelets in until the blocks are attached.  I drill the holes per the plan but don't add those particular eyelets until the rigging phase, same with any on the outer hull.  So at this point pull them out, attach the blocks, re-drill the hole and add them back. blocks attached. Seizing the blocks to the eyelets is well explained above by Keith and David.
Edited by glbarlow
Regards,
Glenn
You guys are good! Dave, Glenn, silly me. You bet I’m going to yank those eyes out and do the rigging with the third hand arms. Keith, thanks for the block and hook tips, another bookmark. 😀 Got some thread in the mail and picked up a few new rigging helpers this morning.
Edited by Dave_E
Dave
The best tool for rigging are cuticle cutters and embroidery scissors - your snips won't help a lot with thin line. I wrote a bit about them in my Cheerful log somewhere.
Regards,
Glenn
Hi Dave,
From Lees' Masting and Rigging the lower yard sling cleats were 1/25 the length of the yard between 1763 and 1815.  If this is an important point for you, the shape is in the sketch below.  The topsail yards were the same to about 1775, then were made like stop cleats set one yard diameter apart.
The lower yard rope strop style to about 1840 is also shown.  I agree with Glenn that wire was not used to secure any block, but for a super small scale model, I believe McNarry and others use wire at times.
Allan
Edited by allanyed
Whilst you've got reasonable access to the mast you may want to think about adding a rest to the mast for the yoke to sit on. This is how I've fitted one to s tripped down version of the Lady Nelson.
DSCF4366.thumb.JPG.d29d0c736708a8345082ca4eae5256db.JPGDSCF4368.thumb.JPG.9e2b2948d24630c955a2ba5757196ea0.JPG
... and here's one on a replica of a similar period ship.
It'll make life easier when fitting the boom.
Rick
Hi All,
Afte a week of preparing the garage work bench for a place to do the sanding work, I have finished the yards and booms. I actually found the yards easy to make using a mini plane and sandpaper. Now on to the complete pre-assembly of each spar.
I actually had the mast top turned in one piece and then broke it when I reached across to get something while it was chucked up in the drill. 😖 It will glue back ok.
Dave
 Dave, I agree with Glenn. There's going to be a lot of tension (more than you think) on the mast when you start rigging particularly the stays.
Hi All,
I’m stumped. Should I remove all the shrouds in order to attempt to tie off lines on the belaying pins? There’s no way on God’s green earth I’m going to pull this off. I think I might have discovered why some builders forego the rigging of a ship model and make it with stubby masts and bow sprit. 😣 If my couple of hours looking at this and the plans are anywhere near correct, the shrouds should almost be the last items attached.
I did order smaller belaying pins and they were to small, fell right through the holes. And then there is the coiling of excess line after securing it to the belaying pin? 🤣😅😆 I believe rigging skills might just be a gift everyone does not have.
Not feeling to positive at the moment about completion.
Dave
Don't give up Dave.  Regarding the belaying pins, would you consider removing the kit pin racks and make new ones with the proper size holes?  Looking at the photos there appears to be enough room to work.
For running rigging, it really should go on after the standing rigging.  A couple tweezers to handle the running lines are a must, that way you can work from either side of the model.  I use both straight and bent forms, spring type and locking type as needed.  SHARP scissors or a cutter of some kind is a must as well.   Blunt end suture scissors work well as it is less likely you will snag and cut an already rigged line when reaching in to snip off and Irish pendants.  Some like nail clippers but they can be difficult to maneuver into the rigging at times.  I prefer barber scissors as they are so sharp and hold an edge, my favorites being Joewell 4 inch and 5 inch from Tokosha Company.
Again, don't give up!!
Allan
Edited by allanyed
I see where some other folks have started their next build while finishing up the rigging. It appears to be less daunting when done a little at a time.
When in doubt, reread post #219.
Jonathan
Current Build: Zulu - Lady Isabella
Completed Builds: Lowell GB Dory, Norwegian Pram, Lowell GB Dory Redux, Bounty Launch, Nisha, Lady Eleanor - Fifie
On the Shelf: Sherbourne, Ranger, AlertErycina, etc, etc.
Last seen at the bottom of Lake Champlain: Gunboat Philadelphia
Some builders (cough, cough myself included) separate this into two pieces of line. You tie off the first line and then glue a coil, that was created off ship, on separately.
Hang in there Dave! Think outside the box and you may yet find a solution. I always see roadblocks like this as a perfect opportunity to invest in new tools 😆
Current Build: USS Constitution 1:76 Model Shipways MS 2040
At Sea [Completed 2023]: 1805 Swift
Hi Dave, if the holes in the pin rack are too big you could try pushing the rope down through the hole and tying it to the rack. Then push the belaying pin into the hole. Hang a coil of on the pin.  On a few of mine I found it easier to make a clove hitch and slide it up onto the pin under the rack, tension the line and then put a hitch on the pin above the rack. That area sure is a challenge.
Best Regards……..Paul
