Hi Mobbsie,
Thanks for that, couple of month at least before I'm there but its good to know.
Your progress is excellent as usual, I know she must be really huge now  as
if she wasn't already
Cheers mate.
George
Hi Guys,
My turn to add an update on progress made so far.
Well I ripped out all of the eyebolts from under the platforms and followed the advice from Grant on how they should be done, he kindly sent me some information from one of his practicums which illustrated it perfectly.
The big question was "How in _ells teeth am I going to do that", but it wasn't as bad as I first thought. So it was with some trepidation that I drilled my first hole in the Main Platform followed by another 11. The results you will see.
The railings and netting was fitted next.
I have since fitted the Mizzen Platform to the mast but the Main and Fore Mast Platforms are only dry fitted.
Next came the Burton Pendants, I made hard eyes for these out of 4mm dowel, I drilled out the centres with a 1.8mm bit and filed them down to the size required. I then had to serve rope for the Mizzen Pendants, Then it happened, my super duper server fell apart, the gearing got all jammed up and kept jamming, so I had to pull it apart and virtually start all over again. I now have a server that's got more holes in it than a colander, still it works which is the main thing.
With the rope served I attached the eyes and served the ends, it is now fitted to the mast.
So that's it, not a lot really, but unfortunately life has a habit of getting in the way of building, plus the fact that I have had a bit of builders block, at least that's behind me now.
Some pics.
Top of the Main Platform showing the retaining pegs.
The completed Platforms
The underside of the Platforms
The Burton Pendants on the Mizzen Platform
The served rope seized around the mast
The 3 masts with platforms
So there we have it, next step is the Mizzen shrouds.
If you have any questions please do not hesitate to ask.
Be Good
mobbsie
Edited by mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Very nice looking progress there, Mobbsie.  Sorry to hear of the difficulties with the serving machine.  I think Sjors has one he might rent to you.
Thanks for the photo of the mock gun setup.  Will come in handy in about a year.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
That looks great Mobbsie !
Especially your ropes under the platforms !
Sorry to hear about the serving machine ?
You want mine ??????? :D  :D  :D  :D
P.S. Thank you for giving me more work !
Now I have to remove my eyebolts under the platform  :(
Those masts and tops look fantastic Mobbsie.  I was about to put in some eyebolts on the underside of the top as well (although I only have 4 to do!) but may rethink my approach and copy you.  I'm sure to be embarrassing myself here, but what are burton pendants for, and did all ships have them?  I don't see any reference to them in my plans.
Cheers,
Jason
In the shipyard:
Hi Mobbsie,
Great job on the re-do of the mast platform blocks. They look great and I know you will be much happier with them. I still think this was the cause of your "block" (pun intended)! The burton pendants look very well done too. You'll race ahead from here my friend - looking forward to seeing completion photos next week. ;)
Hi Jason
Thanks for the good words mate, much appreciated.
According to my book The Art of Rigging by G. Biddlecomb they are called Burton Tackles, and they were used for setting up the Top Mast Shrouds and to support he Top Sail Yards.
As far as I'm aware and I've not done any research on this but I believe only British ship used them, most ships that were captured by the Btritish and were still serviceable had their rigging changed in the British fashion.
If you like I can send you some pictures of how I went about doing the platform blocks.
Hope that helps mate.
Be Good
mobbsie
mobbsie
Next Build :-
Thank you Grant,
They really weren't as hard to do as I first imagined, the Fore Mast platform was the first and the knots were slightly bigger but they soon got trimmed down. :)  :)
That nudge was what I really needed mate, and thanks very much for the info. :cheers:
Next weeks a bit early, maybe the week after. :D  :D :D  :D
Be Good
mobbsie
Edited by mobbsie
mobbsie
Next Build :-
Lovely work, God i miss you guys,
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Mobbsie.
Looking fine.......and if you were to stop right now and start another project, your Aggy looks like a first rate Admiralty model! :cheers:
But I suspect there are sticks, strings and ratlines in your future....... :P
Cheers,
Jim
Completed      Robert E Lee, Misisssippi riverboat
Completed,  HMS Victory Bow Section
Completed,  Wells Fargo Stagecoach...Picasa album....
Completed,  Lackawanna tugboat converted to private yacht...
Completed:  Sopwith Camel, 1:16 Scale, Model Airways...at another location...
Completed:  1961 Ferrari F-1 Sharknose
Completed: (sorta)  OcCre BR-18 Locomotive
Completed: 1/35 Pz.KPfw.III
Completed: Allerton Steam Pumper circa 1869
awesome work Mobbsie.........so your going to be doing shrouds now.......Great!   even with the scale that I'm working with,  I'm still tying on blocks...........I thought I tied on all I would need.........the great fallacy!   the tops look so good......she's going to look great.  I kinda wish I had done my masts like that......hope you get your serving machine back in order  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Looking good Mobbsie - I'm trying to picture my Blandford standing on her stern at your mid-ships....just to get a sense of the scale.....
hamilton
Hi Mobbsie, wow, looking really great.  I still have some furniture to build before I get where you are at, but you have given me a great education on how I'm going to do it.  Do you by chance have any plans or instructions for constructing you serving machine.  I am going to need one and thought I would copy yours if you have no objections....or just some dimensions and gear sizes...anything would help Mate, if Sjors can figure it out, I shouldn't have any problems with it.....lol.....sorry Sjors, culdn't resist......Take care Mate....thanks
John
Current Current Builds:
US Brig Niagara on my website
FINISHED BUILD LOGS:
New Bedford Whaleboat - page on my Morgan Website:  http://www.charleswmorganmodel.com/whaleboat-build-log-by-john-fleming.html
C.W. Morgan - Model Shipways 1:64 http://modelshipworld.com/index.php?/topic/1785-cw-morgan-by-texxn5-johnf-ms-164-kit/
USS Constitution - Revell 1:96 http://modelshipworld.com/index.php?/topic/1796-uss-constitution-by-texxn5-johnf-revell-196-kit/
website US Brig Niagara Model http://www.niagaramodel.com
website Charles W Morgan Model http://www.charleswmorganmodel.com
website PROXXON DISCOUNT TOOL STORE http://proxxontoolsdiscount.com
Mobbsie, ya' old bloke, that is some beautiful work! I may need to save up for trip to the old country to learn from a master!
Wayne
Neither should a ship rely on one small anchor, nor should life rest on a single hope.
Epictetus
Hi Mobbsie
This is an amazing build!
I follow this from a distance, there is one thing i want to ask you.
Can you give me the dimensions of the hull please.
Such as Lenght from bow to stern, and largest wide.
In centimeters please?
I'am concidering the HMS Agamemnon myself, after i finished my current project.
Current build: HMS Agamemnon 1781
Website: http://www.henkvanluinen.com
Hi Klaas,
Thanks for looking in mate.
Length from Bow Peak to Stern Lanterns is 93 ctm's,  the width of the Beam at it's widest point is 23 ctm's and the depth from keel to highest point at the stern is 26ctm's.  The height from the bottom of the base to the highest point is 28ctm's.
That's an intriguing question Klaas, are you thinking of building the ship with mast and sprit stubs, never seen that on this build yet.
Be Good
mobbsie
mobbsie
Next Build :-
Hi Guys,
Thanks every body for your very kind comments and remarks and all those who pressed the like button, it's very much appreciated.
I have a little update to show so will be posting some pics in a moment.
What have I done so far, Mizzen mast shrouds were served and fitted, Catherpins made up and fitted, Mizzen main stay served and fitted, I used Arthurs method of making the mouse and it works fine, Mizzen Futtock shrouds made up and fitted and finally Ratlines completed on the Port side.
The Catherpins look a little thick and I guess they are, I used 0.25 brass wire, served with 0.25 thread, attached it to the Futtock staves then fitted them to the shrouds, this made the process of fitting the Catherpins so much easier, I tend to look for as much as possible to do off the ship, that way there is less chance of doing damage which I'm prone to do.
I'm a little disappointed with the shroud servings, they are not as level as I would have liked above the futtock staves, the only saving grace is that it is a bit crowded in that area and difficult to see clearly.
The mouse was made using Arthurs method, anybody wanting to know what that is please look at HMS Vanguard by AEW, page 19 post 280, it really is a good method and so simple to do. I experienced the problems with serving in that the thread kept sliding down the mouse, this was cured by a drop of PVA.
The result of all this was that the Mizzen mast is now in it's correct position, tight and vertical with the correct backward angle of 2 degrees. I was a bit worried that the mast would lean over to port as was happening before fitting the ropes.
Pictures, not that many and not the best quality but you will get the idea of where I am. ( must change my camera ).
Portside deadeyes
Mizzen stay deadeyes
Mizzen mouse
Mizzen tops with the jungle of ropes
Beneath the mizzen tops showing the futtock shrouds and ratlines
Catherpins
Starboard deadeyes from the stern
Starboard deadeyes again
So there we are guys, your right up to date with where I am.
Your comments will be well received regarding the thickness of the Catherpins, I wont be changing what's done but will make alterations to the Main and Fore masts if you think they are too thick.
Stay Safe and Warm
Be Good
mobbsie
Edited by mobbsie
mobbsie
Next Build :-
Hi Mobbsie,
Great progress mate. Love your mouse. Since you asked, the catharpins do look a little thick to my eye. On mine, I just used brass wire painted with some acrylic burnt umber that gives the look of oiled leather wrapping (leave the paint a little thick). I think I picked up that trick from David Antscherl's TFFM if I recall correctly.
You might want to check your Mizzen stay deadeyes too. It looks to me from the photo that the lower one (attached to the main mast) is back to front / upside down.
Nice to see you're over the modeller's block anyway! :)
Hi Grant,
Great to hear from you mate. :)
Just checked the deadeye and you are absolutely right, it is back to front, that will be changed as soon as I have completed the starboard mizzen ratlines. :(
Thanks for the tip on the Catherpins, did you bend the wire around the futtock stave or use some other method, with the futtock stave lashings, Catherpin lashings and futtock shroud lashings it really get untidy and busy in there. :)  :) :mellow:  :mellow:
Be Good
mobbsie
mobbsie
Next Build :-
