Greetings. I debated for some time whether I should start a log given my relative lack of experience with a scratch build. Indeed, I started this build around three years ago and shelved it for two years mainly because of health issues but also because I think I just got lazy. I don't have a lot of pictures and the ones I do have are probably a bit poor but once I get to present day that deficiency will be remedied. The 2 main reasons I am proceeding with this log are that I need to ask questions and get help from the more knowledgeable among you and secondly I have always found that a log inspires some needed motivation.
The Hayling Hoy was documented and produced by David Antscherl and presented in 3 plan sheets and a book entitled - The Hayling Hoy - First Fully Framed Model
Edited by Seventynet
Clean up
I moved this to proper place in the scratch area for the time period.
Congratulations on a terrific start to your scratch building endeavors! Looks like you've done an excellent job on those difficult apron and aft deadwood stepping lines and she's fairing up nicely inboard.
Greg
website
Admiralty Models
Finished build
Pegasus, 1776, cross-section
Current build
Speedwell, 1752
Thanks all. Apologies for the somewhat haphazard collection of photos as I'm drawing from a bunch of different devices from different time periods. Here is a picture of my pile of frames that precedes several of the pictures above. Rather than waste your time with numerous photos that I have little recollection of, i will jump to close to where I am today. The next one is of the transom and filler pieces. This was one of the most challenging tasks so far.
This last tranche brings me just about to where I am today but I will post a separate one marking that situation.
Couple of things worth noting. First, not everything has gone smoothly by any means resulting in several re-dos especially with the clamps and breast hook locations. My failing was not appreciating how important it is to find a way to clamp these structures while the glue is setting. So I had to re-do many of them more than once. On the other hand I think I can be considered an expert de-gluer now. Whereas I used to rely heavily on water and alcohol I now exclusively use heat with my heat gun.
A couple of pictures of the bow and stern that I think illustrates the amount of wood that must be faired. Call me crazy but I actually like that part of the build. What remains to be done is the final fairing at the top timber level and a few places where the external planking will meet the stem and stern.
And here is where I am at the moment. I have used pear to contrast with the Castello Boxwood and holly for the decking. I am not sure I'll use holly for the starboard exterior planking but will likely start with that and see how it is to work with for hull planking.
I am not clear on how to lay the forward ends of the planks onto the breast hook because obviously there is downward angle as it approaches the stem that will not allow one to achieve a flush situation. I am going to fashion some kind of angled piece that the planks can lie on. No big deal, it is likely just a typical thing a scratch builder has to deal with.
Cheers, Ian
Thanks so much for the likes, encouragement and overly generous praise Allan, David, dvm27, giampieroricci and VTHokiEE; and thanks mtaylor for moving this log to the correct area. Very much appreciated.
Ian
A quick update folks. I have planked the fore platform and installed the scuttle. One notable departure from the plan is that I decided to chisel the breast hook corner flush so that the margin plank fitted over it. As is explained in the book, the reason it was left intact was for strength in this critical area of the hull. I actually tried the other way first but concluded that it didn't look similar enough to David Antscherl's version (see B&W photo - I hope it is ok to reproduce the occasional photo from the book David, please let me know if not) that protruded a bit higher. So the shipwright decided that this would allow more deck space. 😁
Ian
Greetings,
This update seems minor but it took quite a bit of time to complete the planking to the ceiling and then to shape and install the floor and futtock riders. Now I need to determine whether I can poly the floor planks and riders without compromising future gluing operations. Comments, criticisms welcome.
Ian
Time for a brief update. Everything has gone without too many redos 🙂. I must say David’s book explains things very well and I rarely have to go beyond it for guidance. A few notables:
I found my self-levelling laser quite helpful for getting things to stand vertically. If I would just find the energy to build a proper height gauge I would accomplish the same goal, but the laser is a pretty good substitute.
When it came time to make the windlass pins I was puzzled about how to make a round hole on both holders considering each holder is in two parts (pins and retaining caps). This is likely elementary to many of you. My solution was to first slice the mid part of where the hole would go using a slitting blade. I then made sure I could get a solid clamp with my mill so that it would hold firmly when I used my 3/8 inch Brad bit.
The carlings for the huge main hatch follow the deck sheer so they should be pre-bent before installation.
Ian
Laser setup.
Checking deck beams for height.
Hole for windlass pins and retaining caps.
Windlass pins installed.
Carlings, hanging and lodging knees.
Forward starboard bulkhead made of baltic birch core and 9 inch holly planks with dados to key into pawl post and windlass pin.
Forward starboard bulkhead installed.
Capstan holder (unattached). Tapered to be level.
View from stern.
Bow to stern.
Well it turns out the massive main hatch wasn't big enough. I made a measurement booboo which meant that the hatch was 1 cm too narrow. So...I had to rip everything out and redo most of the supporting structures.
1727144067_dissamblyofmainhatchandsupports.thumb.jpg.7be0ec906109662bb6136769487fbbf4.jpg
After I made the repairs I started on the main hatch coamings and ledges. They were assembled by forming the same 90" radius for the longitudinals and the 26" radius for the ledges (concave and convex) and milling half lap joints. A strip was laminated onto the logitudinals to form an inside rabbet while the rabbet was milled into the ledges before they were bent. The strip on the longitudinals was extended to overlap the gap on the ledges.
The cross pieces (battens) were tricky to make and I will redo them at some point in the future. The end stops are very difficult for someone of my limited chiseling skills. They too must be bent to match their respective orientations.
985288809_mainhatchmastpartnerandcompanionway.thumb.jpg.2e7cadba653d0b26c8acdd7a6629b000.jpg327930522_bowtostern.thumb.jpg.4658c383de672aedf6658673dff81b44.jpg
Mast parteners were straightforward and dropped about 2mm below the carlings and the underside rounded up to fit the respective curves. The mast is raked 2 degrees so I was as precise as I could be in positioning it (although it is not glued in place yet). The companion coaming abuts the forward end of the parteners and will be later fitted with a ladder.
 253748106_mainhatchmastpartnerandcompanionway.thumb.jpg.05bac2c4d09219f362f7b1412ea555a1.jpg
Cheers,
Ian
Gorgeous work, beautiful recovery.
Thanks very much Keith. I was angling for the admiral to talk me out of the redo but she said I very well knew I’d always regret it.
6 minutes ago, Seventynet said:
she said that I very well knew that I’d always regret it
Our dear wives are rarely wrong, thank God.
1 hour ago, druxey said:
Ouch. That mis-measurement hurt. Glad you were able to fix it using a tool I find very useful: The scrap box, aka the Quality Control Center.
Your model is looking very good indeed, Ian.
Thanks druxey, the QCC is getting pretty full right now.😁
Hi all,
I constructed the waterway using three pieces laminated together. The widest piece was edge bent to a card pattern and then the two other thinner pieces were laminated to the main plank. I used a chisel to scrape the waterway to 45 degrees. Black acrylic paint was used on the outboard piece to represent caulking between the waterway and side planking.
The ladder was milled using the approach shown in David's book. I had to redo the tread slots on the carriages because of a poor end mill (prior try shown).
The 8-sided pump tubes were made on the mill using a highly sophisticated tailstock and broken end mill :-). Carlings and ledges were installed to enclose the 10 inch tubes. They extend into the limber channel and are topped with a 3inch faux iron band. Note I wish I had read ahead to see that I could have made the carling and ledge notches before installing the beams. The photo shows a 10 sided pear tube which I switched out for boxwood and proper 8-sided configuration.
1554274717_topofpumptubes.thumb.JPG.69cd6ce98551bb8c7f8a0f65cbae5740.JPG2057908617_bottompumtubes.thumb.JPG.3a3dae36eff174cba74d52218058f512.JPG
Scupper holes were carefully filed in and tube holders inserted between frames in 4 locations. The outboard holes were located one and a half strakes above the wale so that they don't emerge between strakes.
1345404598_inboardscupperhole.thumb.JPG.bb6e30e2f6acb21c09b6911b959352dd.JPG1829975663_Scuppersoutboard.thumb.jpg.8fe7cc22507b14610ed917643b45ce39.jpg
Top view:
Thanks all for the comments and likes. I am on to planking the deck. However I think I will plank the upper decks with Castello instead of Holly because otherwise there seems to be too much color. I don't see any good reason to pull out the existing holly decks and restart.
Hi all,
Thanks for all the likes. I have planked the deck and fitted bulwark planking and am now ready to turn it over to plank the hull. Nothing remarkable about these last steps. I am not certain that the holly decking fore and aft can remain but I'll decide what to do once I've finished the hull planking.
Ian
IMG_3833.thumb.jpg.1914614a9127ed11916d8fd45beccfc8.jpgIMG_3831.thumb.jpg.f16b7d16cb9deb5d68661ad8f99243db.jpg
Ian, your Hayling Hoy is looking beautiful. You must be really enjoying this part of the build. The woods are very easy on the eyes. Could look at these pics all day
Best Regards……..Paul
Thanks Paul, I appreciate it. I have found this part of the build to be very enjoyable and working with these woods makes life very easy.
Ian
