Excellent painting  Greg.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
That is looking Superb Greg😍
OC.
Current builds
Completed works.
Simply Outstanding.... Very impressive piece as well...
Will be even more impressive when the complete train is together...  (gun tractors and lorries)
Nice work...
Quote:
Base coat of olive drab which was the US colour used for the Holts. I will now do about 3 graduating lighter shades then add a filter. My plan is to add the tracks before I add any more glue as apparently they are a nightmare to attach.
they did 10,000 of these tractor for ww1! I recently saw a 3 tone camo in a magazine (it’s a what if as there is no reference so I may just do one of these in That scheme)
Greg
Did the kit advise how many links were required per side to fit the sprockets and wheels? I lay all the links down on a flat surface using a straight edge to keep alignment, then glue each link together with Tamiya thin cement. Before the cement completely sets and is still soft, shape the track links around each side then reapply cement if/as necessary to each link. It's a real pain in the **** for sure.
44 minutes ago, RGL said:
Dry brushed the tracks to bring out the worn bits and some rust wash
There is absolutely no doubt brother, you are one of the masters of scale weathering.... My hat is off to you...
You took a what if idea and made it look real....
I'm in AWE...
Edited by Egilman
Quote:
What our  brother  above said.
OC.
Current builds
Completed works.
So when I sanded down 50% of the interior of the tracked I stuffed up and added wrong tracks to each kit, and @Egilman pointed this out to me (I hadn’t noticed as I was probably a bit focused on the weathering), so I’ve been at work all afternoon and just got home after midnight and pulled them off and swapped them. 30 minutes of weathering the tracks tomorrow and I’m back on track. (He’s know, I’d know and it would just burn me up for stuffing it up. Thanks young man for saving me. Imagine if it was after I’d finished!!!
Greg
2 hours ago, RGL said:
He’d know, I’d know, and it would just burn me up for stuffing it up. Thanks young man for saving me. Imagine if it was after I’d finished!!!
I'm so glad it was an easy fix, I figured you would want to know before you got farther into finishing...
Outstanding work my friend.....
Quote:
Looks great, Greg.  I do see a resemblance to some "custom" motorcycles (three-wheelers) though.
