Good evening everyone
The kit is ordered, the Deluxe PE kits is not available in the UK at present, should be another couple of weeks
The Victory is safe and secure for a while, and will be finished
The Workroom has had a bit of a make over as well, i put a window in at the weekend, at last i have some natural light in there and a different carpet as the one i had, it was impossible to find anything when dropped onto it,
research
http://www.ipmsstockholm.se/phpBB3/viewtopic.php?f=3&t=2250&start=30
http://www.kbismarck.com/models/
http://3dhistory.de/wordpress/3d-models/dkm-bismarck/bismarck-high-res
http://www.shipmodels.info/mws_forum/viewtopic.php?f=59&t=144178
http://www.bismarck-class.dk/shipmodels/shipmodels_menu.html
https://www.facebook.com/BismaarckModell148Scale/photos_stream
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Very nice Kevin and the daylight is a big plus.  Now enough 1:1 work, let's see some heavy metal @ 1:200  :)  :)
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
glad to hear your almost ready to start this build.........I will enjoy following along  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
New place, new ship, new luck :-)
Looking forward for your adventures!
Daniel
some pictures
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
hello everyone
This evening is being spent - checking it is all there
There is lots of it, all seam very well molded,
the bonus pack is a see through gun turret, which apparently makes a very nice stand alone kit, and leaves enough room for some super detailing
My intentions are not to run both builds together, just taking a break from the Victory, come Easter, depending where i am on the Bismarck i may swap over
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Looks like a very nice kit Kevin, can't wait to see this one underway!  The gun turret looks interesting, will it lift out so you can see the internal mechanism?
Cheers,
Jason
In the shipyard:
it looks great Kevin......did you get the wood deck kit as well?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
That's one monster kit Kevin! I'll follow along with interest too, even though it's you who have left us (woodies that is). :D Do you plan to keep your Vic going in parallel, or are you taking a total break from wood?
Ahoy Kevin :D
Beautiful kit. I was waiting for this one before I switched to wood. You know Eduard has a Big Ed for this
http://www.eduard.com/store/Eduard/Bismarck-1-200.html?cur=2&listtype=search&searchparam=Bismarck
Will be living the dream through your build, :P
Good luck with her
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
Ahoy Kevin :D
Good luck with her
J.Pett
good morning
I am aware that Big Ed do the PE kit but does not include the wooden deck, Where as the Mk 1 by KA does,
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Ahoy Kevin :D
That is a sweet package
http://www.model-dockyard.com/acatalog/info_MD20003.html
I have not had the pleasure of using any of MK1 PE. I have used their decks before and found them excellent even in the 700 scale
  J.Pett
Hello Kevin, ;)
Nice one mate, shall be following this topic. If you need anything, just ask.
That kit is a real beauty.
Cheers
Paul    :10_1_10:
NEVER RETREAT - NEVER SURRENDER
JUST DO IT YOUR WAY AND NEVER LOOK BACK
1:72nd German WWII Heavy Battle Cruiser DKM Scharnhorst http://modelshipworld...1:72ndDKMScharnhorst/
Future Build Logs:
German WWII Captured Flower Class Corvette.
German WWII Armed Trawler.
German WWII Aircraft Carrier - Graf Zeppelin.
That is one big model.  A 1/200 HMS Hood would go nice with it. :)
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
LOL - i don't know where to start on this one
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
to much candy kevin?? ;)  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
the problem is that Trumpeter Bismark has its problems, wrt to the portholes, to clear the manufacture mouldings the portholes on the angles areas of the hull and superstructure do not  point exactly in the right direction, they tend to point 90 dec to the fwd aft line, rather than the direction in which they are positioned,  this is made worse by the thickness of the plastic it's self, as Channell puts it, some are like wabbit burrows.
i am not at present going down the drastic route of cutting them all out as i don't know any one who would notice, the build will never been seen in a show or away from my living room, and i don't believe you could see in a photograph, i also don't have the PE kit at present, may be another two weeks before i can get it, so i want to avoid building to much, only to enhance it later
next is i dont know how to spray paint, even though i have a compressor airbrush
i may have left the woodies for a while, but a whole new set of skills to learn
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Ahoy Kevin :D
Airbrushing is a skill that requires some time to develop. The curve is pretty steep and unforgiving too. I would buy some cheap kits and get yourself to a point where you have some confidence before embarking on this beauty. I am no pro but would be happy to share with you what I know. I made a mess of a few models, the airbrush really makes it easy.
  J.Pett
my comment was not meant to be sharp.........with a kit this size......where do you start?  :)       I'm sure you have plenty of ideas,  and so much can be done to enhance the beauty of this fine kit.   I used to work with plastic,  so I know where your coming from.   when I started working with wooden ships,  I became good friends with the airbrush.  I had tried it earlier when I was younger,  but with smaller kits,  I wasn't too keen on the clean up and upkeep.   check out the Testor's EZ line of airbrushes.....not too much clean up and very easy to use:
Testors » Airbrushes » Airbrushes
I use the 'Amazing Air'  airbrush kit........costs around $30.00.  I adapted it to run it off my large compressor,  and I have been using it for around four years now.   it utilizes the 1/4 oz bottles that the Testors, Humbrol, Pactra {just to name a few} comes in........for clean empty bottles,  I just buy a bunch of the 1/4 oz bottles of thinners,  and I'm good to go.   I have two other airbrushes too.......a gravity feed w/ compressor,  and another siphon feed........haven't even tried them out yet........this crazy little unit hasn't failed me yet :)     just take it slow,  and do all you want to do.   experiment before you commit,  if you have to,  but be sure that the only person who is satisfied,  is you.    these big builds seem to be making a presence here.........this is so cool!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
