I have the distinct honor of being able to work with Chuck again on my  next project,
the HMS Winchelsea.  This is the same ship that Chuck is designing and currently
building. I cannot put into words my gratitude to Chuck for allowing me to participate
in his project. I will make every effort to build her as described in the plans and
practicum although I will never be able to reach the outstanding level of craftsmanship
Chuck has set.
 The HMS Winchelsea was launched in 1764 and is a Niger class 32 gun frigate. This
build will show how she appeared during the American Revolution. The model will be
fully rigged at 3/16" scale. I will be using various woods throughout the build but the
primary wood used will be Boxwood, Holly and Swiss Pear. All of these woods are
from Jeff at Hobby Mill.
As Chuck has very eloquently detailed his log and I could never reproduce that either.
I will just show how I worked my way through the build.
Here is a sample of some the plans that I will be using to build the Winchelsea.
The first step in the build will be to cut out and assemble the knee of the head. There are
eleven parts to the head knee assembly and they will all be cut from 3/16" Boxwood. The
pieces were rough cut with the scroll saw and finished with files, sandpaper and chisels.
To simulate the caulked joints.
Once assembled Chuck states " The entire assembly must be tapered. This taper extends
from the upper stem piece towards the bobstay piece.  The aft edge of the upper stem
should remain 3/16” thick.  It should gradually be reduced to 3/32” thick along the
forward edge of the bobstay piece. The taper is 3/32” at the top of the bobstay piece
but it also gradually widens back to 3/16” as it works its way down towards the cutwater. "
Hopefully you can see this taper in the photograph.
Next it will be time to cut out the bulkheads and the bulkhead former. These will all cut
from Birch 3/16" aircraft 4 ply plywood. As there are so many bulkheads, a total of 27,
I anticipate it taking a least a week to cut them out and fit them prior to gluing.
That is if my mind doesn't wander! ;)
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Thanks Bob, The good news is that it will eventually be available through Seawatch Books!
Rusty
I wish you good fortune on this project.  The plans alone are suitable for framing  I'll be following (and drooling).
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Rusty,
I'm pulling up a chair and going to follow along.  Good luck and happy building.  You're off to a good start and I predict a great finish.
Rusty - I think this particular build will be the closest I ever get to scratch building. I will watch your work with great interest.
Current Builds - 18th Century Longboat, MS Syren
Completed Builds - MS Bluenose, Panart BatteStation Cross section, Endevour J Boat Half Hull, Windego Half Hull, R/C T37 Breezing Along, R/C Victoria 32, SolCat 18
On the shelf - Panart San Felipe, Euromodel Ajax, C.Mamoli America,
Its a sailor's Life for me! :10_1_10:
Looks like a great project Rusty and a terrific start.
Will watch with interest how your build progresses and the lessons to be learned.
Juggling four projects in the workshop must provide an additional challenge/interest?
Alan
Whew, just made it in time for a front row seat! :) Another great project Rusty. I'll enjoy following along with this one too.
Rusty...so nice to see you start on her.  I am working on mine today and it will be nice to collaborate again on building.   Should have more updates on the prototype real soon.
Chuck
Thank you for all the likes and comments. It is very much appreciated! :)
Joe that means I'd have to do design work and we know that isn't gonna happen!
Thank you Remco. Your Kingfisher continues to inspire me.
Thanks E&T.
Hi Chris. Yeah we may have started around the same time but my little ones are into houses
of their own so my distraction level is much lower!
Thanks Ben. I can't begin to express how lucky I am to be involved in this.
Hi Augie. You should see them spread out on a 40" x 40' sheet. Truly amazing! You know when
you finish the Confederacy this would be a good project for you. Come to the dark side...come..... B)
Hi Mark. Thanks for your continued support and encouragement.
Thanks Floyd.
Hi Greg. Tall order? Try impossible! I'll just do the best I can and have a whole lot of fun.
Hi Alan and welcome aboard.
Hi Alan from down under. Once this gets underway full steam there will only be two projects ongoing. Well maybe......
Hi Grant all seats are in the front row here!
Hi Chuck. I don't know how much fun you'll have....but I'm planning on having a ball.
Again thank you all for stopping by. I will be away for a couple of days so probably no new updates until the weekend. :(
Rusty
Thanks for stopping by Daniel.
Well I'm back and I have got a start on cutting the bulkheads out.
Care was used to ensure the plywood I have is free of warping. There are 27 bulkheads
to cut out. I used my standard method of cutting the individual bulkheads from the plans
and glued them one at a time to the plywood using a temporary paper craft glue. This
allows for removal of the plans should I so desire.
Once the bulkheads have been cut on the scroll saw I use my x-acto knife to score the
various reference lines that will be needed later. This is done just in case the plans are
removed from the bulkhead later.
I then take the bulkheads and make stacks of about 6 bulkheads of similar size and shape
and place a heavy weight on the to help ensure that they do not warp while I finish cutting
the remaining bulkheads and the former.
Well I'm off to cut more bulkheads out. B)
Rusty
Send along Ben. I can screw them up in a heart beat! :D
Rusty
Nice work Rusty! I'll be following along.
Jim L
What we ever hope to do with ease, we must learn first to do with diligence. - Samuel Johnson
     On the Building Ways:                           Launched:                                                 Contracts Signed:                    Member:
       The Nautical Research Guild
        The US Naval Institute
Thanks Greg, I think I started doing that on the Confederacy.
Glad to have you here Jim. Are you going to make it up to CT for the show?
Hi Dirk, I hope you do build her. I would love to see it.
Also thanks everyone for stopping by and all the likes.
I had a great weekend. The real world left me to my devices  and I had a lot of
shop time.  Bulkheads are all cut out and stacked as previously mentioned and I
then attacked the bulkhead former . It is laid out in two pieces and I thought of
just cutting it out as one whole piece. But as Chuck pointed out to me that getting
one piece of plywood that long that wouldn't twist would be extremely difficult.
So after an unsuccessful search I relented and cut it from two pieces. I knew  I
shouldn't have wasted my time but then again I'm not known for my better
judgment and decision making. :huh:
Any way the former plans were cut out and glued up, then I cut it out on the scroll
saw and fine tuned it with the disk sander and a sanding block. Once satisfied I
applied glue to both pieces, put wax paper over and under the joint, placed a scrap
board on it and some heavy weights and allowed it to dry over night.
Now I will test fit all of the bulkheads and then start gluing them up.
Rusty
Looks like a great start Rusty.
Michael
Looking good Rusty. It's actually a lot shorter then I had expected to be. 24 inches? Thats smaller than a 1/48 Swan class, pretty challenging to detail that.
Remco
Treat each part as if it is a model on its own, you will finish more models in a day than others do in a lifetime.
Current build HMS Kingfisher
MSW 1.0 log click here
Hi Rusty,
Yep, I'll be at the show. I send in my check about a month ago. Looking forward to seeing you.
Jim L
Hi Augie, Yeah there a lot of bulkheads and hopefully the former remains flat!
Thanks Michael.
Hi Remco. Yeah at 1/64 she is smaller but I guess my magnifier will get a workout! Plus if I
need help on producing small details I know I can count on your help.
Thanks Bob, Always a pleasure.
Sounds great Jim.
Rusty
