The completion of the standing rigging
The top gallant masts were added next,plus the jib boom and martingale and then rest of the standing rigging has been done.
Top gallants fitted
Jib boom & Martingale fitted
Standing Rigging
Ray
 Current build A set of HMS Diana`s boats @ 1/48
 HMS Royal Marine a Military class Trawler
 Completed  HMS Diana
Completed build The Lady Nelson
Completed Build HMS Pegasus
Ray,
love that wonderful built "threepack"
Nils
Current builds
-Lightship Elbe 1
Completed
The Yards Part 1
The yards,the larger yards have octagonal center sections, and the ones I made when building Pegasus I thought were only just about acceptable, and the way I made those was to file the octagon shape from the dowel. I decided to try a different method for Diana s yards,the two yard sizes, at the large diameter point, are 8mm & 6mm, I tried my new method on a mock up yard in 8mm which proved successful so this is how they were made.
I cut the dowel over length by 20mm, I then ran some tape around the dowel at the ends of the center section,then started to reduce the out ends ( mainly to allow the dowel to go into the small lathe further) I the reduced the center section down from 8mm to 6.8mm, and then I laid in four 4mm x 1mm wood strips top & bottom and both sides,then when dry filled in the gaps with wood filler,when the filler was dry  I filed clean the wood strips, and then filed the filled gaps so that all sides where the same width,this gives a really nice octagonal center section and at 8.5mm just .5mm over size I can live with that.
The next step was to shape and tapper the yard from the octagonal section to the ends in my model lathe, then I cut off the 10mm over length each end to give a nice square end. I made all the yard cleats from ABS plastic adding them as oversized bits and filing to shape when dry. I then added some tape around the octagonal part to simulate the iron bands.
Reduced center
Building up the center
Center now octagonal
With cleat and band
Ray
 Completed  HMS Diana
It looks great.   I may have steal your method...  :)  :)
Part 2
The yards with the stun-sails booms have domed end brackets with legs, these do require some fettling, I first thinned the legs both inside and outside as they are way to thick to start with,they were glued to the end of the yard, and reshaped  (see photos) I then added the rope lashings, I then made a dummy stun sail boom ( the real ones will made from hard wood dowel) to allow the brackets to be aligned, next the mid yard boom brackets were fixed to the yard in conjunction with the outer boom brackets which are not yet glued in, both brackets were set up so that the the rear edge of the boom is over the front edge of the yard which allows the 3mm blocks to be added later, and for them to be in the centre of the top of the yard. I then drilled a hole to the rear of the yard at the centre and added a 1-2mm pin to allow the yard  to be fitted to the mast.
Yard end bracket as supplied
After rework
Yard brackets on with dummy boom
All brackets and cleats added
Ray
 Completed  HMS Diana
Next two coats of dull black paint was applied  to the yard before all the blocks and rigging tackle was added. The lower main yard also had the yard slings added, also the slings with a block to support it made and added to the tops , all the lifting tackle blocks were also fixed to the yard finishing with the pendant lines and blocks, lastly the stirrups and foot-ropes completed the yards, the stirrups were made by using stanchions left over from the quarter deck conversion they looked better than my bent wire test stirrups. Lastly the stun-sail booms were made and fitted and lashed down,I must say there is a considerable amount of work, and time and effort, that goes into each yard and I am very pleased with the results.
The main yard and cross-jack are done, now its back to the others.
Cross-jack
pinned to mast
Main yard with some blocks
Main yard fully rigged without stun-sail booms
Main yard sling
Finished main yard
Ray
 Completed  HMS Diana
beautiful Yard modeling Ray,
Nils
Current builds
-Lightship Elbe 1
Completed
All the main and lower yards with stun sail booms and the mizzen cross jack are now finished, I will next take some photos with them on the masts.
Stanchions used for the stirrups
Completed yards
Stun sail booms
Ray
 Completed  HMS Diana
Many thanks for all the ticks and comments guys.
B.E The booms are smaller than in the plans, as I am a great believer that something should look right, also I use slightly smaller dia threads for rigging sometimes as well, as again no one spots if something is slightly undersize but most can spot something that is oversize.
Ray
 Completed  HMS Diana
Some photos below showing the yards, with stun-sail booms, on the masts, not fixed just in the pin holes. Next job make the remainder of the yards and gaff booms.
Ray
 Completed  HMS Diana
Excellent work Ray
The more I see your progress, the more it itches me to  resume my shipbuilding activites.
I'm really looking forward to this as the move to our new house is scheduled the next months
Kind regards
Christian
"The original always beats the copy"
(supportive statement)
Hi Christian
                   It will be great to have back in the shipyard again, hope the move into the new house goes well, so your Diana build can restart.
Ray
 Completed  HMS Diana
Just catching up on your log Ray and your doing some superb work mate.
Love those yards, keep it up.
Be Good
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
The rest of the yards and the sprit-sail yard have now been made up and rigged, they were a bit of a doddle after the lower ones, I have also made the two gaffs but I will leave them off for as long as possible to allow turning her  from side to side to gain access, when adding the yards and rigging,as she is getting longer. Again the yards are only in the pin holes.
Top yards
Top yards made up before rigging
Gaffs
Top yards completed
Yards on masts
Ray
 Completed  HMS Diana
Running rigging
Part 1
   The last job before the running rigging was to add the shroud cleats.
The yards, I added the two main yards  first and then the cross-jack, I first made and fixed the Truss Pendants to the yards,I then fixed the yard to the mast held in by the pin, then tied the jeers, then after making sure the yard was horizontal and square cynoed the yard into the mast,and after giving it time to set,set up the blocks and tackle to complete the rigging of the Truss Pendants and the the main slings.
fitting the yard to the mast
truss pendants and jeers
Main yards rigged
Deck view
Ray
 Completed  HMS Diana
Ray - thanks for the tip on the jeers, not got there yet but they've always appeared to look very tricky to get right and you nailed it.  You look to be getting very close to completion Ray, dare I ask what is next?   ;)
Cheers,
Jason
In the shipyard:
Truss- and jeers tackle look super Ray,
the whole rigging to date is beautiful and a delight to look at....
Nils
Current builds
-Lightship Elbe 1
Completed
Thanks for the ticks and comments guys.
Jason
          Firstly I still have a long way to go most likely many weeks or months on the rigging which will include all the rope coils, which took a time to do on Pegasus, there are also the ships boats to build, which I may build and use as a break from the rigging at some point.
        Secondly my next build will be something completely different,it will be a WW2 Hunt Class Destroyer a Deans Marine kit built as a static model. My reason for building the Destroyer are two fold one she was the favourite ship my father served on, he served on her a the time of the D Day landings at Omaha Beach, she was one of the destroyers that closed the beach to 800 yards to silence the shore guns that were decimating the US troops landing that day. Secondly it will be nice to build something different.
HMS Tanatside
Ray
 Completed  HMS Diana
Part 2
The topsail yards were next to be added to the masts these are connected to the mast with the Parral, I assembled them adding the ribs and trucks until the Paarral went around the mast ,I remember they were a real pain to fit and rig on Pegasus when I left them lose on the strings so this time I added a spot of glue at each end, I then tac glued them to the mast, after trying a fair few times to rig the without doing this, then with them held in place like this, the yard was glue in place, setting it horizontal to the yard below and checking it was also square viewed from above. The Parral`s rigging was then fixed around the yard. The tyes and halliard rigging was added with the trucks tied to the after most topsail mast standing back stay.
The first photo shows why I have not yet added the gaffs and will leave off for as long as possible,limited room.
Parral
Halliards
Yard hight
Ray
 Completed  HMS Diana
Excellent images along with the superb technique and craftsmanship!...I'll add this as a "go to" source for any future queries  I may have.......
JP
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
