Blue Ensign
  1. Looking good Lukas, a fine display of skill and perseverance on your Upper deck gun rigging, well done. B.E.
  2. Beautiful job you have made of Cheerful Bob, I will find your log an excellent reference source when I get around to trying to emulate your great skill. B.E.`
  3. Beautiful guns Thomas, wonderful example of skill and artistry. B.E.
  4. Each visit to your log is a feast for the eyes Nigel; a five month build lay-off whilst I extended my house has also resulted in not being able to find stuff, tools, parts etc; takes a little time to get re-organised. B.E.
  5. Hi Mark, you're doing a fine, fine job, love the glazing effect in the stern lights. B.E.
  6. The standing jib sail doesn't look too small to my eye Peter, but on its own stands out; are you fitting the Middle Jib and Flying Jib Sails? these are somewhat larger and where fitted would tend to draw your eye from the jib sail. Nice idea with the Hanks, and you do have one per cloth strip which seems to be the normal arrangement, although looking at some contemporary models and drawings there does seem to be somewhat more than you have rigged, are your strips to scale? Having said that your arrangement looks good to me and I love the shot of the jib sail with the photo enlarged. Nice work, Peter. B.E.
  7. Thanks Peter, I have a sagey green close woven carpet on the floor, but as its all open it won't be too difficult to spot fallen bits and pieces, and what I don't find I'm sure a spaniel nose will. You're right, it does make you hesitant to make too much dust in a newly decorated space, but as I'm now into the rigging stage shouldn't be too problematic, for any heavy stuff I'll decamp to the garage. Cheers, B.E.
  8. One of the reasons I fitted the Crossjack above the gaff on my Pickle was because I was concerned about the very large roach that would be needed on the Topsail with the Crossjack that much lower down the mast. I was therefore curious to see how it would work out on your build Peter. I think it has worked out just fine and it sits easy on my eye, nice job on the sail construction. B.E.
  9. Thanks for looking in Ray and for your kind appreciation of my build. I see you have registered on the other forum, can't understand why once you have logged on you can't gain access to the build log. Please try again and if the problem persists let me know and I will speak to Pete Coleman. Cheers, B.E.
  10. Those pumps against the Main jeer bitts do present a problem in belaying the Main Jeer falls. My approach was to drill sheave holes in the bitts and pass two loops of cotton pass thro’ the jeer bitt sheaves, and I hope to attach the falls to these and pull them tho’ at the appropriate time. The kit plans appear to show the jeers belayed at the Topsail sheet Bitts which gets around the problem. I covered this aspect on page 24 of my full build log in the "other" place. Those pump covers do look good Martin B.E.
  11. Very sad to read this news of Augie's passing, he was a great contributor to MSW and a fine model maker. I'm sure you will do justice to Augie's memory by completing his build Bug. B.E.
  12. Hi Christian, sorry to appear obtuse but I'm not entirely sure I understand what you mean by "not 100% vertical-perpendicular in front view". From the side view the cap is vertical to the waterline. The top and bottom chamfers are angled to the stive of Bowsprit and Jibboom, and so are horizontal to the line of those spars. There will be slight variance in the gap between jibboom and bowsprit as it passes thro' the cap due the bowsprit taper which gives the impression that the jibboom stive is at slight variance with that of the Bowsprit, but from head on the cap looks vertical to me. (well it does on my Pegasus) I see the arrangement for Diana is the same as for Pegasus with the cap being slightly wider to starboard of the jibboom hole to allow for the jack staff. B.E.
  13. She's looking wonderful Christian, what a fine model you are creating. I had similar issues with the Bowsprit cap on my Pegasus and ended up scratch building it from boxwood. The main issue was that the cap should be wider and the hole off centre to allow for the Jack staff to be accommodated on the Starboard side. Apart from this the kit provided part was of poor stuff and could not survive the rigours of shaping the hole to allow for a vertical fit of the piece. Cheers, B.E.
  14. Hi Hamilton, I have both a Proxxon Band Saw and Scroll saw. Both tools are very nice but I have used my scroll saw far more than the band saw. I suppose it depends how much work you are likely to do and of what type. In my model projects the scroll saw has proven more useful, particularly in relation to cutting the frames for my1:64 Pegasus Pinnace and Longboat; The Band saw simply couldn't get around the small and intricate curves, and the much finer scroll saw blade was more suited to the task. Cheers, B.E.
  15. A fitting display case for your unique and wonderful Pegasus Nils, and what a great room with such great models on display. B.E.
  16. I have made several purchases from Seawatch, and they do supply some unique and beautiful books. I appreciate they are a small business but there are a couple of things they could do to improve their internet procedures that would bring them into line with how most other internet sale businesses operate. The first is an order acknowledgement. In my experience once an order has been placed and paid for the buyer is left in limbo as to whether the order has gone through, and it would be re-assuring to have an order reference number to refer to. The second is a dispatch notification. The buyer has no idea when the order has been sent, and in the case of my last order I waited several weeks before contacting Seawatch by email querying the non receipt. After repeat emails requesting confirmation I was told I should have received the book "by now" Seawatch then instigated a tracking search and advised me of a delivery date, which was fulfilled. All this sort of thing tends to give rise to feelings of uncertainty, particularly as the books tend to be of high value, and these two simple steps could relieve a lot of it and improve the buying experience. B.E.
  17. Check out Amazon Ian, that's where I got my last supply in 2014. B.E.
  18. Let me help clear the fog of confusion for you Vince, at least from the perspective of one kit enhancer. I simply enjoy taking a kit and making it better. Kit costs are not an issue for me and I derive all the modelling satisfaction I require from what I do. Each to their own. B.E.
