Everything posted by Landlubber Mike
Really amazing work Greg. I'm not sure that I could keep my sanity with all those tiny PE pieces. Hard enough with the ones in a wooden ship kit! Just out of curiosity, for these plastic models, do you use CA or some other kind of glue? I seem to recall doing plastic models as a kid with my dad and using something other than CA. For whatever reason, I can't seem to get the hang of using CA, so I don't think doing a plastic kit is in the cards for me (as incredible as these models with the add-ons are).
Next up is the planksheer, which sits on top of the waterway. This is a critical piece to get right, as it helps form the shape of the hull and it extends past the outer hull planking making a decorative pinstripe or "rail" on the outer hull. The planksheer is ochre inboard, and white on the outside of the hull. It's the lower white stripe in the picture below: To make the planksheer, I'm using yellowheart with a thin piece of holly for the outbound portion to represent the white stripe. Yellowheart is a tricky wood to work with. It is a hard, yet splintery wood, kinda like walnut. It machines pretty nicely, but I notice a bit of char at times when cutting it on my table saw. It wasn't too difficult to construct the planksheer, which I did out of three pieces. The first was the bow section, followed by two long strips that run the length of the hull to the stern. Here are some pictures, along with the start of the main rail which similarly is going to be yellowheart, except with both an ebony and holly strip laminated to it. Right now I'm in the middle of adding the stanchions. Not including the knightheads and timbertheads, there are 44 stanchions to add to the ship I'll post pictures later this weekend when completed.
Happy holidays and new year to all my friends! It's been a while since my last update, mostly because of work and other issues, but I did manage to make some progress the last couple of months. As per usual, most of it was planning, with only a little on the actual building. The approach of avoiding paint on the model has required a lot of careful planning, but so far so good. I spent a good part of a week making sure that the bulkheads and bulkhead stubs were level with one another, and that the stubs were equidistant from the center line of the hull. Unfortunately, the stubs weren't crisply cut and weren't identical on each side in most cases, which required some shims, etc. - to be expected I suppose from using basswood for the bulkheads This was a pain in the posterior, but worth the time I think to ensure that the deck planking and hull are symmetrical. The Morgan has white pinstripes running along the hull, so the bulkheads and stubs need to be in a smooth line or the pin stripes will look wonky and ruin the look of the hull. This kit is a little different from the Caldercraft and Amati kits in that you don't have bulwark/gunport strips. Instead, you have to frame out the bulwarks which is a completely new approach for me (but good practice when it comes to scratch building I suppose). A good picture of what is involved is below which is taken from the plans (actual picture is borrowed from John's website): After setting up the bulkheads and the counter block and stem and stern filler blocks, the waterway is installed. The waterway helped to draw water down through the scuppers out of the ship. It's tricky in that it runs the length of the hull, sits against the bulkhead stubs, and has a bevel cut into it. The thickness supposedly varies as well. Here's a picture from the actual Morgan: I decided to go with pear stained with General Finishes Antique Oak to get a nice dark brown color. I originally tried cutting the waterway into three sections, but it just didn't look right as I wanted a nice smooth line for the waterway along the hull. Eventually I settled on cutting the waterway as a single piece on the Byrnes saw, sanded a bevel using the Byrnes disc sander (first time I used the angle adjustment on the table which made things really easy), soaked the strips, and then clamped them overnight. Pear is a really great wood in so many aspects. I forget the exact measurements, but the waterway strips were like 3.5mm x 4.25mm or so. When soaked, the pear holds the shape very nicely and I was very happy in the end with how it came out. Here are a couple of pictures:
Need advice - what should I build after the AVS?
Landlubber Mike replied to pdx_matthew's topic in Wood ship model kits
My first build was the Caldercraft Badger, and I moved onto the Amati Pegasus. If you have the TFFM books, I would think about either the Pegasus or Fly, or scratching your own. Lots of great logs on here, and the TFFM series is top notch. -
Really nice Mark. Are you using ebony for the black areas? Just out of curiosity, is yours jet black? It looks like it might have a little brown in it which I really like. The ebony I'm using for my Morgan build is solid jet black, and I would probably prefer wood with a little more color variation.
Are you adding masts and rigging? That will make for a really tall model at that size
- 742 replies
- constitution
- frigate
Thanks JP. It should be a fun ride whichever flag ends up on the ship. I've been a little busy with work and family stuff the past few months, but recently turned back to my Morgan build to get that going. I'm still trying to figure out the color scheme for the LAR. I'm toying with the idea of using holly to simulate the white stuff. I bought a bunch of holly from Jeff from his close-out, but didn't get any pieces thick enough for the keel and stem, which I think comes out around 7mm in thickness. So, I'm trying to decide whether to go that route, and then buy milled stock that not only is in that width, but whether I would need extra for the hull so that the holly is all the same color. I might end up going with paint on the build, particularly with the ornamentation, so I could always paint on the white stuff. I'm not a fan of white paint because it usually requires a number of coats to cover, which then looks thick. I found a whitewash stain from General Finishes that goes on nice and thin though, so that might be an option.
Very cool! Nice of you to donate it too. Is the model going to come in a little over 5 feet in length?
- 742 replies
- constitution
- frigate
For some woods, and depending on the size you need to bend, it doesn't seem like you need boiling water. Most of the time I just run hot water from the tap. Usually, by the time I get the piece situated, the water is room temperature. I boiled water for my first build's planks, but haven't noticed a difference just going with warm water on my current builds. If you were bending tricky woods like ebony, you probably do need heat. One thing to remember is that the wood may expand a little when soaked. So, if you glue it right away when wet, by the time it dries, it might shrink leading to gaps. I've been a little more conservative these days in soaking, pinning and letting the piece dry overnight before gluing just to be on the safe side.
Wow, that's beautiful Jason. Very clean look, and love the color of the coppering! I was re-reading your issue on the stern lights. I would think about doing them from scratch, as I think you are going to be annoyed going with the kit parts. The stern is really where a lot of the character of these ships comes out (at least in my opinion), and I think many a model suffers when things are slightly off there. Plus, your model is coming along so nicely, no sense in settling at this point. If you don't have a table saw, maybe try either by hand or getting a friend to help? I could always try cutting/milling some pieces if you want. I was planning on scratching the quarter galleries and stern on my Pegasus, including the lights in holly, so depending on how that goes, I could similarly cut some pieces for you if you want to go that route.
Workshop Advice
Landlubber Mike replied to ChrisLBren's topic in Modeling tools and Workshop Equipment
Great decisions Chris. If I had the space you had, I would do something similar. The workstation desk in particular is going to be nice with its depth. I think you'll like the Fein and JET system. The Fein is a bit of a pain when it comes to attaching to the Byrnes dust ports, but I think there is a thread here where I came up with a solution (essentially involved pairing two adaptors, which I include on each of my tools so that I just have to move the vac hose from tool to tool). A bit of an added expense, but pretty easy. Think about getting the dust deputy cyclone system. It works very well. Another pain to attach to the Fein, but use some gaffer tape and you'll be fine. -
Guidance, Encouragement, or just a Sanity Check
Landlubber Mike replied to RFP's topic in Wood ship model kits
Hey Rob, I'd also say you should go for it! I think the most important thing is that you find a subject your heart is into, given that these are very long term projects. I saw the Morgan in person a few years ago, and knew it was a ship I had to build. I just started the Morgan, and it certainly is a little more complicated than many of the model kits that are out there. But, the good news is that there are a lot more Morgan build logs going here than there used to be - so, you have a treasure trove of resources. Just take your time on it, study the plans, ask questions. For me, building these ships is more about the journey, and not the destination anyway. -
Hey Don, I've been away from MSW for a while, but logged on this morning to catch up with your build and had a nice treat in seeing your build and ship's wheel. I plan to order three from you in the future if you don't mind for my current builds Really nice work!
- 653 replies
- trabakul
- marisstella
Workshop Advice
Hey Chris, looks like you have a nice room for the new workshop. Mine is in the furnace room in my basement, so I first hung some inexpensive fluorescents over my benches. The nice thing about the furnace room is that it is not finished, so I could very easily run power lines and hang the lights and air filtration system (discussed below) from the ceiling joists. I have the Jim power tool set, and for dust collection, I use a Fein II shop vac and an overhead air filter system from Jet that I bought from Woodcraft on sale. Kurt has a good point about air circulation though - the Jet is supposed to circulate the air in the room a few times over, but having extra circulation is probably a good idea. For the shop vac, I recently added a Dust Deputy cyclone system. It's amazing how much dust gets dropped into it (i'd say 99%) which saves on shop vac bags and reduces the strain on the shop vac which should hopefully make it last longer. Having a window for natural light is really nice, and something I wish I had. One thing to consider though is that if you use woods that change color dramatically with UV (bloodwood, redheart, purpleheart, etc.), you have to be a little careful. -
Daniel, I meant to comment on your sloop, very nice! Really well done. Do you mind me asking how you did the mast (hinge method or otherwise), and which point you fixed the stays (bowsprit? stern? Mast?) since you used an upright bottle? I'm still working on my Great Lakes schooner, which will also be in an upright bottle. Haven't figured out yet how to do the mast and rigging, which will be a little tricky since it is really long and tall (which makes me think to not use a hinge for the masts) and has shrouds/ratlines (which I will probably tie off after inserting into the bottle). Any tips would be greatly appreciated. Feel free to respond by PM if you don't want me cluttering up your log with a discussion of a different build. Thanks so much!
Really nice work Mark. The personal touches really make for a nice build.
- 652 replies
- royal william
- euromodel
Beautiful work Doug. Agree with BE, the colors you are using are working very nicely together.
His books are excellent. I would highly recommend his more recent book, where he displays some more refined techniques, and where the pictures are in very high quality color: https://www.amazon.com/Building-Miniature-Navy-Board-Model/dp/1848321864/ref=la_B001JP2ALM_1_3?s=books&ie=UTF8&qid=1479145996&sr=1-3 I have to say, I always thought that I would jump to 1:48 scale or bigger on my future scratch builds. After reading his books and seeing his work, I'm rethinking that. It's astounding the level of detail that he is able to create at the 1:200 scale or thereabouts, at less cost for materials, and less space in the workshop and home.
