Everything posted by Louie da fly
Looking good, Clare. Sorry to hear the carpet monster has struck again!
- 175 replies
- hanse kogge
- shipyard
Probably the best bed linen is stuff that is old and worn thin - just before it's ready to be thrown out, but not so thin it's ready to rip apart when you look at it. Then it's closer to the thickness (to scale) of the original.
Beautiful work on the planking, Bigpetr. That view from the bow is just amazing - what an exquisite shape! I like what you're doing with the triangles. If you can get it to work without the paint "bleeding", I think scoring the lines is probably the better way to go. Regarding the colour scheme, I like to top one with the single black stripe better than the bottom one with two. But that's just me.
1 mm should probably be ok. My planks are about that thick and I only have trouble at the stern where the plank has to twist from almost horizontal to almost vertical in a very short length- which you probably won't have on your model.
- 179 replies
- longship
- Helga Holm
Well, I've fixed the wrong track I'd got onto. I removed the outer plank on the port side (because it couldn't be fixed) and cut back the next one to the shape I'd pencilled in. Then made the replacement for the plank I'd removed and put it in place: Then repeated the process on the starboard side: And now that's sorted, I can get on with adding extra planks.
- 740 replies
- Tudor
- restoration
(and 4 more)
Beautiful work, Rodolfo! By the way I see this picture is from the book "Le navi di Colombo" - Heinrich Winter - Ed. MURSIA, but does the book tell what is the original source?
But . . . beware of the day, if your snark be a Boojum! For then - you will softly and suddenly vanish away, and never be met with again . . .
- 186 replies
- keelless
- reverse clinker
- (and 4 more)
I hadn't realised the model dated back so far! You're doing a very good job with her. I'm enjoying watching your progress. One of your photos shows the ship seen from directly ahead - is there supposed to be a part filling in that strange gap at the front of the forecastle, or is that the way the model has it? The reason I'm asking is the pictures I have indicate a sharp point at the front of the forecastle, with a panel across further back and higher up (if that makes sense) where the shape of the forecastle dictates it. Here's my interpretation of this in my Great Harry and here's a detail (the first 2 pics from from the painting above) showing the evidence for it You might also like to consider silkspan for the sails - it's used as fabric covering for model aircraft and is very fine. I haven't tried it myself, but quite a few people have reported good results.
You've done a beautiful job with this, Rodolfo. It's so much better than what the model recommends.
Yes, if you look at contemporary pictures of galleons, generally the foremast is raked forward and the mizzen(s) is raked aft (though on this example though bonaventure mizzen is raked aft the mizzen seems to be raked forward for some reason) . So the model is correct.
- 165 replies
- english galleon
- revell
Actually, I've realised that at the bow I've been on completely the wrong track. I've drawn in pencil where the planks should be going at the bow. If I kept going the way I was I'd end up with a horrible mish-mash - similar to the bow planking you find on those model kits that just give you parallel sided planks and don't care that it's not the way it was done. I think I owe it to myself and also to the people who've posted tutorials, and even more to those who've given me valuable advice personally, to pull the wrong bits off and get it right. I probably still have to tweak the pencil lines a bit, but now I think I'm (finally) on the right track. Planking has never been my strong point, but if I'm patient and painstaking, I think I'll improve in this area to the point I actually know what I'm doing.
- 740 replies
- Tudor
- restoration
(and 4 more)
Well, after a glitch that resulted in my removing and replacing two planks that I'd already glued down, I seem to have picked up momentum . . . It looks worse in the photos than on the model, but I'll need to compensate for a width problem with the foremost plank on the starboard side - it's got a wave in it between frames 3 and 4 caused by the previous plank, that I hadn't noticed till it was too late. Still, my attitude with all this is that the Great Harry is where I'm learning my trade with planking. Mistakes just get put down to experience, with a resolve to avoid that particular mistake in future builds. There are inequalities in the surface of adjacent planks, due to unequal thickness planks and other issues. This should all be resolved when it comes to sanding.
- 740 replies
- Tudor
- restoration
(and 4 more)
Regarding the weight of the sails, you might like to try paper instead of fabric - it can be very convincing - see https://modelshipworld.com/topic/25784-barco-catalan-by-gbmodeler-148-scale-mediterranean-fishing-boat-finished/page/2/?tab=comments#comment-756498 I agree, the painting is a bit unclear - I magnified my original as much as I could, but it's hard to tell whether the mainyard is single or double. Double mainyards are very common in contemporary representations, but I think there's enough uncertainty there for you to feel justified in making yours single.
It's very interesting following this build and seeing your ingenious solutions to problems. Walnut has a reputation of being easily broken and unwilling to bend without splintering. However, I'm using it on my Great Harry without much trouble, though my planks are pretty thin because the model is at 1:200 scale. What is the thickness of the planks on the Helga Holm? Your rivets look very good. Yes, paper or card would probably be good for the other side.
- 179 replies
- longship
- Helga Holm
Interesting problem. The general principle is that in the Mediterranean they fixed the lower ends of the shrouds with pairs of blocks, while in the Atlantic they used deadeyes (caps de mouton). Columbus set forth from Palos de la Frontera, on the southern coast of Spain, on the Atlantic side of the Straits of Gibraltar. So perhaps his ships were fitted with caps de mouton, as was this Spanish carrack of 1475, from an altarpiece depicting the battle of Zumaia, off Gibraltar. Note that these are fixed on the outer side of the hull.
Good decision. Are you planning to make a two-part mainyard? That is, two spars overlapped at the centre? This was normal practice at this time. And note from the painting above the mainsail (and I think also the foresail) had sheets not only at the lower corners, but also "sheets" in the middle of the sail - which your model's pre-cast sails don't show. There was an interesting discussion of how to achieve that here https://modelshipworld.com/topic/4915-venetian-carrack-or-cocha-164-by-woodrat-completed/page/14/ and the following pages. I think Woodrat did an amazing job of it, but it was pretty difficult to achieve.
Oh, yes! Beautiful work. I particularly like your Lancaster diorama. Very lifelike! I made the Airfix Victory back when I was a teenager. My parents had been to the U.K. and brought back all kinds of detailed drawings for me. It was very much a labour of love. I hope you enjoy it as much as I did.
Welcome to MSW, Jon! Not sure if you're not already past the "beginner" level, but you might like to look at this for some idea of what to build first - these kits are all distinguished by good clear instructions and relative ease of building, but with a good-looking model at the end. https://modelshipworld.com/topic/18657-new-to-ship-modelling-but-what-do-you-build-first/ And make sure you start a build log of your own - this is how you do it: https://modelshipworld.com/topic/24705-before-you-post-your-build-log-please-read-this-starting-and-naming-your-build-log/ It's the best way to get advice, help and encouragement from the other members. Pretty much any problem you might encounter has probably been met and dealt with by someone else, and the members are very willing to give the benefit of their experience. There are quite a few build logs of Viking vessels on the forum - look under "Up to and including 1500 AD" - both under "kits" and "scratch builds". You should get a lot of information on the joys of building a model Viking ship, as well as the trials and tribulations. This period is my own favourite, so if you start a Viking ship you'll probably find me chipping in every now and then. The Amati Drakkar is a popular Viking model and there are a couple of logs on MSW for it. Type in "Amati Drakkar" in the search button at the top right of the page. Most seem to have had success, but at least one member has had trouble with getting the planking to follow the shape of the frames, though. Another has had a similar problem with a Dusek Viking model, so maybe it's something common to clinker-planked kits? I haven't built either of these, so I'm not in a position to comment further. Just a heads-up, not an attempt to discourage you.
Looking for advice on starting a build log
Louie da fly replied to Ken_2's topic in New member Introductions
Welcome to MSW! Yes, put up whatever seems appropriate in your log. At the bottom of the box as you write your post there's a note: Drag files here to attach, or choose files... - that's how you upload photos. And there's a useful trick - If you want to re-size your photos, double click on the picture you've placed in the text - it gives you a menu to reduce the size of your photo if you wish. The other thing I'd suggest is that you outline the steps you took in making something, so others who follow after get the benefit of your experience - including the mistakes (sometimes the best way of learning!). Other than that it's pretty much open slather. And have fun with it. That's what it's all about, after all.
