Everything posted by cog
I dilute Model Air slightly, Butts, even if it is stated to be ready for use, I'd rather be safe than sorry, building up layers is easy ...
look at the image's subtitle: Wei Lee from Taiwan. I have to admit it is rather hard to see at first glance, especially when you see something unusual in the image
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
Steve, I'm drooling ... marvelous build ... I would expect the screw on the deck to be fixed so heavy weather wouldn't make it run on the deck. Come to think of it, it may be on top of an axle like mount and fixed as if on the prop shaft ... you need to find out unfortunately I can't help you out just now
- 446 replies
- zebulon b vance
- deans marine
(and 3 more)
HMCSS Victoria 1855 by BANYAN - 1:72
cog replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Marvelous Pat. What did you make the lever from, rod or sheet brass?- 1,013 replies
- gun dispatch vessel
- victoria
I know that match, IgorSky has the same blow up one he uses in his SIB build logs. About a meter in length! Very lovely detail at that size Steven!!
I couldn't make a stepped or straight stern either from the painting. It culd be either. However, I would go for the stepped version as I like it estatically ...
- 599 replies
- sidewheeler
- arabia
(and 4 more)
Won't be easy, but attach one end to a fixed point or if you have the possibility to fix both ends you can do that. Than wind the thread around the "stay". Bloady nuiscance, and it takes a lot of time, but that's what I would do.
Michael, A saddlers awl ... I would have gone for the diamond shaped awl blade it gives your stiching a better look, and is easier to pull double threads. That is, however, a personal preference. It is also advisable not to pierce all the holes in both pieces but in one as one sheet of leather may strech more than the other which could give you ugly wobbles. However, having written that, if you have it from the same hide, you will probably not encouter the latter. I like the colour combination
- 2,215 replies
It does make a difference, the rigging, Jack. Looks great
- 106 replies
- trumpeter
- john brown
You really think so mate? They are nice 'n tight, lovely straight lines, no wobbly bobbly ... Giv'n the attension you 'ave given 'er so far, t-is about the only choice you've got left for the stan'in' riggin' ...
Those woodendecks make such a difference on these models ...
- 77 replies
- icm models
- Markgraf
I like air above a boat, shows it's relative smallness, and it does not look cooped up
- 131 replies
- bottle
- the old man and the sea
looks like the rigging is reasonably straight forward, and doesn't interfere with building at deck level
rightclick on them and select delete or doubleclick and press the "Delete" key NIce work on the galleys
- 73 replies
- mediterranean
- galley
glad you discovered your "error" with the knees in time. Beautiful workmanship again on the wooden parts. How did you "solder" the hatch rings? It looks almost like welding when I see the clip on the scisors ...
- 219 replies
- smack
- cross-section
Sorry to hear that Pat. My sincere condolences- 1,013 replies
- victoria
darker is dull, lighter more contrasting. It depends on how you want to show her - the ship in total - and how much you want to have singular parts stand out. When I look at the metal work against the wood, the ropes from your hammock nettings ... you need to look at the bigger picture and look at it from a distance, not from close up. Very impressive though
IT and directives in gov'ment hands makes me sick ... I could go on and on about it, but I'd rather see that worm take shape.- 1,013 replies
- victoria
