Posts posted by Toolmaker
2 hours ago, Roger Pellett said:
If I were shopping for a new drill press, which I don’t intend to do, it would be another FULL SIZED tool with at least 3/8 in chuck capacity, not a “hobby sized” tool.
I think you are maybe missing at least one set of circumstances when “hobby sized” machines are the correct choice. I spent my working life using full size machines but as a retired hobby machinist my decision was to buy miniature machines. My Byrnes saw and sander are miniatures and I have recently purchased a sherline mill. I don’t have large workshop facilities and have commandeered the spare bedroom so I don’t think getting a full size set of machines up the stairs would wash with my better half nor would any sort of machine lubricating regime. Lack of floor space also meant bench top machines.
The sherline is a good piece of kit and I can drill 0.5mm/0.020” without issue using the standard feed. Today I was taking 4mm/0.160” deep cuts in boxwood and holding better than 0.0015” tolerance. So yes to it being small but it certainly behaves like a full size machine. There are limitations, but there always is. You might say that as I’m working in 1/64 or 1/48 then my machines could be the same scale 😂
So for me it’s the usual advice; get the biggest and best that is practical and within budget.
Thank you
Paul
- HardeeHarHar, RichardG, Gregory and 3 others
- 6
12 hours ago, Bob Cleek said:
Beautiful photos on your post, by the way! I'm sure a lot of the newer modelers will find your information very helpful!
Thanks Bob, trying to be helpful is the aim really. I’ve posted a bit on soldering and metal prep as that’s what I know a little about. Being a recent convert to wooden models I hoover up knowledge from here so only seems right to offer some suggestions that aI am more knowledgeable about.
To close my input here (unless any questions arise). I’d say the scribing block and some basic slip gauges are very useful basic editions prior to the full digital height gauge.
I’m fortunate to also have a basic set of slip gauges. Mine are metric.
A 1mm slip sat on one gunport;
A 1.3mm slip sat on the opposite side;
We have interference with the scribe point so the difference in height from the build board is less than 0.3mm or 1/2” in real world at 1/48 scale. Good enough for me.
Im glad you found it interesting.
Thanks
Paul
- mtaylor, No Idea, Paul Le Wol and 1 other
- 4
At this time I am fairly new to both wooden ship building and MSW. As such this is possibly a risky post as I might be either preaching to the converted or just plain wrong.
Although having completed just three builds, I have no doubt that the journey becomes akin to “wood engineering”. I have two 1/48 scale builds on the go and am committed to trying to work within +/- 0.5mm which equals about an inch in real world. I’d be interested if anyone can quote records with regard to accuracy of the day in the early 19th century.
Enough of the post introduction and on the the meat of the subject;
I have not seen much use so far for this tool on MSW but I feel it is under utilised. I see lots of spirit levels but sometimes think the user may not be getting the results they believe they are.
My two current builds have been set up on build boards made from spare kitchen cabinet panels. They are very flat and as spare, also very cheap. The top surface of the build board then becomes the datum. You don’t need to worry if your fixed work surface/table isn’t flat or level, just work from your build board datum. I think with a little experience it is easy to work within 0.2mm or 0.008”.
The tool has different names depending who tells or sells it. To me it was a scribing block used for marking out but it could be a simple height gauge or comparator. You could attach a dial indicator (known as a clock) or just a simple scribe as I have.
Above it is being used to adjust the heights of the bulwarks. In this instance I am not setting a known height, just matching the height of starboard and port.
This next picture I am matching gun port heights. Using the fine adjustment screw whilst moving the scribes point back and forth across the gun port until a touch is felt/heard. You then slide your scribe block to the opposite side and set your wood height accordingly. You will find you are quickly working within very fine tolerances without effort.
The following picture looks to show a point I am trying to make. I have tilted my build board by an inch or so. Tilting it makes it easier to see the laser etch marks used as guides on the gun ports. Using a spirit level in this instance would be inappropriate here, but the scribing block method still works the same.
If you are building a flat keel model you can use the scribe block to set known heights from plans using an engineers rule or slip gauges to set the height. This takes a bit more effort if you are working on a curved keel model..
These scribe blocks are available for around £35 or $40. I’ll leave you to decide if that seems a worthwhile investment. If so, I would add a couple of caveats;
1. As per norm, make sure stem and stern are vertical to the build board.
2. That the build board is wide and long enough to move the scribe block around the model.
Now, If you have taken the time to read all that, thanks
Paul
- CDR_Ret, Harvey Golden, Canute and 6 others
- 9
Your work clearly shows the benefits of taking your time, maintaining high patience levels and a determination to not take short cuts.
Coming from a manufacturing planning background I am having to educate myself in a similar vein.
What May seem slow is often the quickest.
Loverly work.
Thank you
Paul
Richard,
A tricky little component for sure. Lots going on there. I assume that you don’t intend working these machines once built other than showing a working mechanism. Therefore I think as long as you can get a working gib strip then what ever you choose will be fine. Potentially if you lost 1/16” from the 1.313” you will only have reduced the travel on that axis by 3/4” real world.
Nobody would know and we won’t tell.
Good luck and enjoy whichever skinning method you choose.
My own day seems to be following a similar pattern as I attempt a raft of compound angles on gun ports. Hobbies eh, who would have one.
Cheers
Paul
- thibaultron, mtaylor, Egilman and 5 others
- 8
Richard
1 hour ago, Rik Thistle said:I would probably pin the base to the block (by reaming the four fixing holes)
Yes, plenty of options here. Two pins would be enough. With it doweled you could re position if you had more work to do. I would put the dowels towards the middle where you won’t see them should you go right through. You could tap the holes in the casting, you can always drill them clear through later. I half expected you to dowel and loctite it, releasing it when done. Your super glue tip from your previous build.
1 hour ago, Rik Thistle said:Thing is the threaded portion is very long and slender
I haven’t seen this part but is it an option to use M3 left hand studding? It is available. If the part is shouldered can you drill/tap and screw some studding in and lock it in place?
Regarding the play on the saddle of your lathe, it should not really be an issue. Assuming it’s the left hand thread, you will be cutting from headstock to tailstock and again I’m assuming you keep the lead screw permanently engaged while threading. When you power on for each cut your hand should act as a break on the saddle wheel, in effect you are holding against the backlash. Do that for each cut and your thread should have good form.
Of course It’s still a challenge due to the small size.
I’m sure you already have, but I learnt early on to read the drawing notes. It’s often there that the designer writes the detail he forgot to add when he did the drawings.
Good luck, you have some interesting parts ahead.
Paul
- Rik Thistle, Canute, thibaultron and 4 others
- 7
Thanks for the welcome.
Good alignment will certainly help with smooth operation on completion. It looked like the feed mechanism will be operational when finished.I can also see they direct you to have the bosses and spindle bore square. The best way to ensure this would be to skim the two bosses in the same set up as finishing the spindle bore.
Something you might apply to other builds and which may have helped on this one is a method to index the work without an indexer. For instance, if you machined the bottom of the main casting first and then fastened it to a square block. An al/al block would do in this case and block should be a little bigger than the base of the casting. You can now machine any of the other 5 faces of the casting by holding the block in the vice.It all looks very interesting.
Do you have to cut the bevel gears or are they already complete?
Are you going to make your own left hand tap? haha
Does the kit come from the US?Its going to look great
Regards
Paul
- Rik Thistle, thibaultron, Canute and 3 others
- 6
I just spotted that you are off and running again Richard. It looks like you have plenty on your plate with this build.
I see another miniature gem in the making and shall follow along with your fun.
Paul
- Egilman, Rik Thistle, Retired guy and 4 others
- 7
I looked at this, your latest post, from an offline position. I thought it would be just rude not to immediately log in and offer my “crikey that’s outstanding” comment. It really is super work.
I know you can take great photo’s, which they are, but you can only show us what’s in front of you. You present a high bar indeed. Lovely stuff.
Thank you
Paul
- Dave_E, glbarlow, FrankWouts and 1 other
- 4
You can see here the type of iron I use;
The method is simple enough;
Have the joint clean and fixed in place.
Load the hot iron with solder.Using a modellers paint brush, paint the joint with liquid flux and immediately offer the loaded iron to the joint.
The brass immediately heats up and the solder transfers from the iron to the joint.
lastly, avoid any stupid methods of seeing if the iron is hot!
Thanks
Paul
2 hours ago, wefalck said:
What masking tape are you using? In the past I tried painters' masking tape but the glue on it melts and leaves some residues that are not so easy to remove.
Its Tamiya modellers masking tape. Its fairly low tack and in normal use doesn't leave residue. I think for the most part its about keeping the heat very localised which you can do with a fine nosed soldering iron. I generally use a small radiused nose rather than flat.
I hope that helps
Paul
A very enjoyable watch
Thank you
Paul
- Tossedman, mtaylor and thibaultron
- 3
As a follow up to Roger’s post and in agreement with him, I am also a supporter of the soldering iron. My personal preference is a gas powered item. For the most part, ship fittings are lightweight enough to need only soft soldering.
My preferred method for holding parts in place is masking tape.
That may sound doubtful but it is easier to explain in clear pictures. I hope this is seen as helpful rather than indulgent.
Here you can solder between the masking tape and when the tape is removed then solder the rest if you feel it’s necessary. I didn’t.
The next two pictures are the all brass bridge. Almost all the parts were soldered whilst held in place with masking tape.
Some similar examples
Parts were usually taped to a heat resistant tile or held in self grip tweezers.
Another example is the Carley floats.
Minimum size was also not a barrier.
This method of soldering has been discussed before but I thought it worth showing some ideas regarding holding.
Thats definitely me done here on soldering 😂.
Thank you
Paul
Certainly 300 series and 17-4PH(precipitation hardened). I’m sure if you Google it you will find many suppliers for the process.
Thank you
Paul
- thibaultron, allanyed and Canute
- 3
I’m not sure if I’m missing something here, but I have done a lot of blacking to stainless steel parts.
- mtaylor, thibaultron and Canute
- 3
This is great fella’s , your enthusiasm is palpable. It’s always good to see a “all in” approach.
Thank
Paul
- FriedClams, Canute, Old Collingwood and 4 others
- 7
Looking at your gallery images it’s certainly something I would like to see more of.
Thank you
Paul
- Ryland Craze, mtaylor, hollowneck and 1 other
- 4
4 hours ago, allanyed said:
Great looking kit and build, thanks for sharing.
Thank you for the interest shown and taking the time to comment. I’m sure you’re correct that this only worked due to the reasonably simple hull shape. The appeal for me was that I was able to have full length strakes over the complete hull. The last strake ended up varying between 2.2mm and 3.5mm so not much lost over the hull.
I only measured on one side, over assuming, however I was lucky that it came out fairly even.
After I had shaped each piece and bevelled the edge, I did pre-shape them.
3 hours ago, chris watton said:That is a very neat job!
It’s a very neat kit. I thoroughly enjoyed it. Thank you.
3 hours ago, glbarlow said:I’m a devoted fan and practitioner of Chuck’s heat bending method described in the referenced video. Welcome to wood modeling.
I intend to follow your lead. I got away with my cheap fix but intend to up my game going forward. Thanks for commenting, it’s appreciated.
3 hours ago, oakheart said:That is some really good planking, something I will aim to achieve.
Thanks Tim, I’m sure you will do a great job on your upcoming build. If you do intend to try the route I took, here are some notes I made at the time.
The shaping of the planks, even as a bunch of 10 brings its own if’s and but’s;
Measure the widths of your planks and bundle them into +/- 0.05. My 4.1mm average width became 4.0mm on one batch. My Alert planks varied by 0.3mm over the lot.
- Choose the best side of each plank, when you stack them for profiling you will want 5 with the best side facing you and 5 with it facing away. Port and Starboard become a mirror image. On the reverse of each plank Mark the bottom as it’s surprisingly difficult to tell which edge you have profiled once they are all separated.
- Mark m/s on each plank as everything is taken from there. Watch out for losing that mark when you soak the plank😂
- The front taper lends itself to using a plane. As a batch your stack is now about 12mm wide. The v shaped in the plank towards the stern is more problematic. Now if only I had a laser cutter and some nice sheets of pear wood!
- I found I approximately shaped the planks as a batch and then finished each individually.
- I needed to taper the front end of each plank to fit in the keel slot. It’s just a couple of millimetres. Do it on the back of the plank. This and the upper edge bevel should be done before bending. It can be done after should you forget but it’s a lot harder to bevel a compound curved edge.
All the best
Paul
Fairly recently I came over to the other side and began wooden ship building. My first build was a Vanguard Fifie. I feel I planked the hull in the traditional beginner manner and although happy with the result I wanted to improve on my next build. Unfortunately I found this forum a little late and embarked using my own method.
My second build was another Vanguard kit, HMS Alert.
Here is breakdown of how I planked the hull.
The first layer was done in the manner of my Fifie
The next picture is after I had tested my idea with the first 5 planks. It shows me taking measurements for the second band. I have put tape between the lower and upper planks on the bulwarks position. I have also taped (in white) the length at a halfway position for a 5 plank band.
The tapes were removed and the measurements put on paper. I had previously sorted the planking strips and for this band was using 4.1mm width planks. That gave me 15 planks at mid ships. I then divide each bulwark length by 15 and I get a plank width at each bulwark.
I then make 1 plank to those dimensions making sure to mark midship position. This strake is now my pattern and I make nine more to the same dimensions. The planks are individually bevelled and fastened to the framework. This process is then continued for batches of 5 planks per side. I did change the tape from white to yellow Tamiya, as the white had too much stretch.
Hopefully, the rest of the pictures become self explanatory.
By the end it wasn’t too far out for a rough and ready method.
I’m not suggesting this is a great method, but it was a step up towards lining off the hull in a more exacting manner.
My third and current build is the Syren Medway Longboat so I suspect my ad-lib method will not be used by me again. Like I said, it worked for me at that time.
Thanks for looking
Paul
- bruce d, JpR62, Jim Rogers and 12 others
- 15
1 hour ago, DocRob said:
it would have been a wrong approach to my eye.
Sorry for that Rob, just a bit of cross purposes. I agree with your approach on this.
In fact some of those bits are so small I would probably be sticking them on with varnish! The paint would hold them in place.
Cheers
11 hours ago, DocRob said:
The thin PE was warping and bending on eyesight.
Love it,
I have definitely shouted lots worse. That there is frustration.
To be fair Rob, although you know the issues you have faced, your photo’s rarely show anything other than “job done”.
It all looks really good, those racks look great and will improve even further when fitted and painted. They will become just another part of an “amazing” assembly.
I got slightly involved in a conversation on here today about soldering, and your build here was at the forefront of my mind.
I can’t help but think you are batting way above the production level of this kit. The plastic doesn’t look good but your etch work does.
Cheers fella.
Thank you
Paul
- Ryland Craze, mtaylor, Edwardkenway and 2 others
- 5
Height correction and level setting using a scribing block as a cheap height gauge
in Building, Framing, Planking and plating a ships hull and deck
Thanks for taking the time to reply on this. That’s interesting to hear and gets the imagination working in consideration of the old craftsman.
Regards
Paul
