BANYAN
SPECIAL CONTRIBUTOR
Everything posted by BANYAN
  1. Looks very good Russ; nice trimming work. Great decision on the wood grain, always pays to have the strength of the wood working for you. cheers Pat
  2. Mark, you have rebuilt so much of this model that you could have two ships That said, I very much like your attitude that near enough is not good enough; and it will pay dividends in the long run as you say. That deck planking is coming on very nicely. cheers Pat
  3. Believe in learning the hard way do you mate? - ouch they looked pretty good too which makes it worse cheers Pat
  4. very nice job on the boats Dave; they look terrific. The 3D printed parts look excellent also, glad to see you persisted. I am assuming the ironwork for the masts etc are also 3D printed? cheers Pat
  5. Great to see you back at the build table Denis; hopefully all is good now? cheers Pat
  6. very effective technique; many thanks for sharing it. A great explanation of the steps etc. cheers Pat
  7. Great progress greg; hopefully the book will not expose too much difference. You have certainly made some major improvements to the base kit. cheers Pat
  8. Hi folks, have not updated this build for awhile as I have been busy researching all the fitting necessary to be fixed to the bulwarks as once deck furniture is added there will be little or very restricted access to the bulwarks. I am currently determining the rigging/belaying plan to determine where cleats, eyebolts, belaying pin racks/rails and leads/blocks need to be fitted. I am also continuing to research the armaments: see following which has been resolved. cheers Pat
  9. Hi Denis - found you I was wondering why your trawler was mothballed An interesting build with very good progress. I have bolted my chair to the floor so I can't be pushed aside I think the purpose of the Like button, as used now, is to allow readers to acknowledge posts and a like means they like what you have said or done - which to me is a sensible implementation. cheers Pat
  10. Thanks for showing your process and build sequence for the frames Gaetan. It is very informative and shows how important it is to have a well thought through process in the mass production of frames. It seems you have found efficiencies in this process rather than manufacturing one frame at a time. cheers Pat
  11. Les, I recommend having another look at that diagram. Marquardt shows the overall pump and it is correct for an Elm Tree pump style. All pumps went all the way down to the bilges. What is shown below decks is the pump chamber/suction pipe (trunk). the bit above deck is the exposed bit seen on almost all drawing s of ship using this design. Sometimes they were on the upper/weather deck as for Endeavour, sometimes on the gun deck for multiple gun deck vessels, and sometimes a couple on one deck, and a couple on the other. What is different with Marquardt's depiction is the height of the trunk (raising pipe as he calls it) protruding above the deck. Whether the amount protruding that he shows is correct or not I cannot say, but the concept/style of pump is correct. Also note the scale of the drawing as the height would be a little more than perhaps perceived at first glance; but it is depicted as a shorter exposed trunk than normally seen for this style of pump. cheers Pat
  12. Thanks Per, just found this post of yours - a very handy link cheers Pat
  13. Nice job Dave; they look very good, and makes me wonder why I didn't consider yellow/ochre for the thwarts etc - looks good against the white. cheers Pat
  14. Great pictorial description of the process and jigs Michael. A masterclass in micro metal-smithing. cheers Pat
  15. I have workshop envy; any cures? That is a very organised way of working Gaetan; you obviously have a very well thought through process of construction. cheers Pat
  16. Late to the party Gaetan, but I hope I can find some standing room somewhere? I will enjoy this build; I have followed all your others so this will be a masterpiece with all that practice cheers Pat
  17. If hidden, the framing size does not matter as long as it fits the required space save yourself some additional work unless it looks hideously over engineered cheers Pat
  18. Great example of restoration Michael; you would be hard pressed to notice any repairs in most places which maintains the integrity of the model itself. cheers Pat
  19. Hi Greg, I just added a little about salt to my last post - wires crossed in passing As COG said, don't overdo salt as it is a very poorly maintained ship that would have too much of it. The Japanese in modern times have some of the best maintained ship's I have seen, so that must be a cultural thing also and would have been evident in WWII also. But in prolonged periods of high-intensity operations, some issues would have developed, no matter how disciplined the ship's husbandry - a matter of priorities. A salt line on the waterline would indicate a ship alongside for a prolonged period with very little maintenance or water movement (current etc). The action of the sea on the hull would have prevented such encrustation. Have a look at the many photos of ships at sea (steel navy - waterline/hull etc) and notice there is no salt encrusted; sometimes a little wear and tear from bumps etc but that would be about it. cheers Pat
  20. Hi Greg, Chris has basically nailed it. Unless the ship was in an operational environment for a prolonged period, the upper decks were well maintained with a washdown as required. Noting in older ships, up to 1980s or so, fresh water was a real hassle and needed to be carefully managed (I well remember the 3 minute rule of the splash, lather, rinse and dash daily shower :)), so a wash down was done with sea water unless the salt had caked too much. Breakwaters etc would only rust if maintenance access was a problem or the area had been chipped due to shell casing chipping or other operational wear and tear, (prolonged periods in an operational environment where crews were closed up in two watches and manning their weapons, making maintenance a lower priority). So, if depicting a ship in an operational environment which had been at sea for awhile, then there would have been some minor upper deck rust runs etc from fittings, depending on how long at sea and in what Defence State the ship had been operating. But it would not have been too much as basic maintenance, such as wash downs would have been observed regularly, for crew safety, weapon and ship husbandry etc. As you have depicted significant rust etc on the sides, this I would assume would mean she has been at sa for a while, and some minor rust and streaks on upper deck fittings may have ensued, especially in unmanned areas (away from some weapons and ready access). Things such as capstans, boats, davits and cranes that were required for safety and weapons service would have been well maintained but painting/ship's husbandry may have been minimal. As to salt, minimal on the upper deck and superstructure areas ready to hand, unless immediately after some roughers, at which time a wash down would have been organised. Ship's are designed to shed water so accumulation of salt would have been in nooks and crannies only, and then would only have been a slight puddle of crystals, and a powdery effect on some screens - I would stay away from showing too much salt build up as it would have been a very poor XO and Bosun who let it build up to an extent that it would show, even in war time. Then again, on the Murmansk run In the tropics we would actively chase down passing showers etc when possible to provide nature's wash down cheers Pat
  21. Impressive Greg; done as if with the hand of the very experienced. cheers Pat
