Gregory
Posts posted by Gregory
  1. I've used these blades from Amazon with very good results. The kerf is a bit more than I would like, but they are a fraction of the cost of Proxxon or Micromark blades.
    They have 10mm arbor.
    Avenger AV-34024-5 Combination cut saw Blade
    I found this on Amazon UK.  Looks like it could be the same thing unlabled.
    ZhuJinSheng Cutting Disk 1pcs Out Diameter 85mm 24T/36T Mini Circular Saw Blade Wood Cutting Blade
  2. 14 minutes ago, popeye2sea said:
    However in the second photo the lines leading from the spritsail yardarms to the fore and fore topmast yard arms do not make any sense.
    The rigging of the  model in the picture is a disaster in more ways than one..  I believe the rigging with the Model Expo plans is pretty reliable.
  3. On 4/11/2020 at 5:26 PM, captainscott said:
    Ripping planks is all I would probably use it for.
    Unless you are going to be ripping balsa planks, none of those cheap saws are going to be much good.
    I have had one of these:  MicroLux Mini Tilt Arbor Table Saw for about 20 years, and it can cut planks with a decent blade and finely adjustable rip fence.
    At that price one would do to well spend an extra hundred or so for the Byrnes.  I keep thinking about getting one myself, but I haven't got into scratch building yet
    and my little saw does everything I need to do right now.
  4. 26 minutes ago, Paul_S said:
    Should i sand a rabbet? on the bottom of the keel to help them fit,
    You should sand out a ' bearding line, so the keel and stern post stand proud of the ' back bone ', that some call the false keel.
    This illustration shows a chisel being used, but with the MDF in this kit, you should be able to do most of it with sanding tools.
    On a double planked hull, a true rabbet is more of a challenge.  The kit design assumes you will fit the final planking flush with the keel and stem to give the appearance of a Rabbet.
    Another option is to fit some very small ( 1 x 1 mm ) stock along the bottom and front of the backbone as seen here, in Chuck's Cheerful. This creates a slot that serves as a rabbet.
    However you have to consider the thickness of both layers of planking.
  5. P.S.
    I have picked up so many tips from the other members here, I may not always remember to give credit where credit is due.  With that in mind, I want to say that I got the idea for the scarfed planks near the margin from Chuck's instructions for the USF Confederacy.  The instructions for most, if not all of Chucks designs are available for free at Model Expo, and they are an incredible resource for detail work.
    However, they are a mixed blessing in that they really set the bar high, and make it a little difficult for me to reach a point where I can say " O.K., That's good enough; time to move on.
  6. Finished up the quarterdeck planking. If you compare my finished work to the last post, I decided to increase the number of imaginary  beams under the quarterdeck.  Three would have been unlikely and it made it difficult make the scarfed planks look nailed realistically.
    It is my understanding that ' nibbing ' wasn't done in the period ( 1711 ) this ship represents, so I shaped the outer planks with hook scarfs  to avoid points butting into the margin.
    As I was finishing this up, I was reminded of why I like to do this off the ship..   I had completed, or thought I had, the work you see above and was applying some poly when I realized I had left out a plank on the left side of the deck.  It was obvious after the fact, but I had spent so much time staring at the tree nail pattern, I guess I saw what I wanted to see.
    Anyway I was able to splice in the missing plank/s with very little effort compared to the problem it would have been if all the planks had been glued onto the false deck.  Instead of just splicing in a plank, all of the planks to the left of the missing one, would have to have been ripped out.
