dvm27
Everything posted by dvm27
  1. Been very close to step 4, Keith! Definitely optional.
  2. Beautiful work, Keith. It seems like backlash is a problem for me when I try to do repeated sequences such as you have done above. I found an article by Sherline on how to adjust for it and I shall have to read it.
  3. My set is in the mail and I'm looking forward to receiving them! Michael writes that he has a few left.
  4. That's really cool Dennis. It would be even cooler if you were to use a contemporary Admiralty dockyard building slip, complete with workers, as the background.
  5. Really enjoying this build, Dan. I really admire those who can build ships of any era with equal excellence. Great link, Keith! Don't believe I've come across micro brass tubing that small before.
  6. My God man...that's craftsmanship!
  7. Looking great Ben. Your ports are lining up very fair. Are you still cutting the sill mortises prior to installing the frames?
  8. Wonderful work on that stern framing (and everything else)!
  9. Plank on frame airplane modeling...a far cry from the plastic models of my youth. Makes me want to take a stab at a WWI biplane or triplane. Or recently, I was diverted by a You Tube modelers chanel specializing in WWII aircraft https://www.youtube.com/watch?v=j-Mdr1mgVuU. The level of detail and finishing is amazing. And those damned Pocher classic automobiles...
  10. Well Kenny, Harold did not use power tools (except a lathe perhaps). He even cut out all his frames with a fret saw. So while power tools are nice you can certainly do excellent work without them or with brands that aren't quite Byrnes quality.
  11. I don't know, Keith. Would you slap a coat of gray paint over the Mona Lisa?
  12. Following Mike's point, you may also wish to consider building a jig to make sure all the frames are the correct height and orientation. On the jig add a keel stop at the bottom to fit the keel slot and two small stops above the toptimbers. On the glued up blank first cut and file the slot for the rabbet. Then trim the toptimbers to fit the top stops. Now that the glued up frame pieces fit the jig exactly, you can cut out the body of the frame and the maximum height of breadth (widest part across the hull) should line up perfectly on both sides of the hull. I would also leave 1/16" outside the line while cutting to allow for slight errors in raising the frames. Finally, if you can swing it, I would highly recommend the Byrnes disk sander to finish the outside of the frames and an oscillating spindle sander for the insides. It'll cut your frame making time in half.
  13. Just personal preference, Kenny, but I believe if you're going to take the time trouble to build a framed model you should leave some of it visible. I think Harold's method of leaving off the planking just below the wales is a good compromise. Otherwise, there are cheaper and faster methods of constructing a hull (plank on bulkhead, lift method, etc.). Or one could plank one whole side and leave the other side in frame. Only problem with this is displaying it to its best advantage.
  14. Druxey is certainly correct, Mark. I find that anguishing and deliberating over redoing a part takes more time than the actual repairs. My motto - when in doubt, rip it out! Of course that could explain why my models take so long to complete.
  15. Good luck with your Raleigh build, Kenny. I built two Hahn-style models before I switched to upright building. His methods may be a bit wasteful but it insures a fair, solid hull. Try to do as much construction and fairing of the hull as you can before separating it.
  16. For those of you who enjoy following Glenn's building log I'm sure you also miss his updates. Glenn's profession is actually building model ships (which should come as no surprise to anyone here) and he has been very busy trying to complete several projects and preparing for new ones. As much as he enjoys posting on this site, there literally are no enough hours in the day for him to do his job and keep us up to date on his progress. But he will return as soon as he gets caught up and wishes everyone the best. Perhaps it's not ideal when your hobby becomes your profession!
  17. Sweet work Keith. What thickness is that slitting saw and how many TPI (if it says)?
  18. If you are building ship's fittings yourself there are many parts that need to be mass produced (cannon brackets, knightheads, capstan etc.). Having two (or three!) saws with different setups makes this process much easier.
  19. You must be very organized to keep all the individual futtocks together with their neighbors. There must be over a thousand pieces. What if that box fell over...
  20. 3 1/2 years!? Seems like yesterday you were just finishing up the Naiad frigate and pondering your next project. Time truly does accelerate the older you get. Bummed, but in great admiration of your masts and model in general.
  21. I just bought up their entire inventory so you're all out of luck! I'm hoping it will finance my retirement, Chuck.
  22. Lovely turning, Keith. It also looks just like those pedestal bases supplied by Model Shipways years ago (if the top were to be slotted for the keel).
  23. Sweet planking job, Erik. Looks like you'r right on those tic marks.
  24. Going to be a fantastic build Gaetan. Perhaps include a ruler every so often so we can appreciate how large this build actually is.
