Everything posted by druxey
A better indicator of vertical is the dependent anchor shank, I think. (Less possible distortion due to the camera lens).
- 3,560 replies
- clipper
- hull model
Some years ago i had to make a batch of triangular deadeyes. Admittedly they were larger than yours, but I made them from end-grain hardwood stock, first making a kind of Toblerone bar shape, but without the gullies. After drilling them I sliced them off the bar like pieces of bread. They held together well.
- 740 replies
- Tudor
- restoration
(and 4 more)
Nice to see you getting back to the cutter, Michael. Some of us were getting a bit impatient while you worked on live steam and other distractions!
- 2,207 replies
What you need are mini-tarps to tuck around each gun.... Seriously, I learned all kinds of neat things from jewelry making. My silver soldering success rate went from 50% to 99%, amongst other things. My wife benefitted as well; a custom white gold ring and a repousée silver 'waterfall' necklace.... The latter developed my sheet metal forming skills. I miss my days in the jewelers' studio.
I hope that the buyer truly appreciates your fine restoration work. I guess these are tough times for the library system....
- 749 replies
- albertic
- ocean liner
At those sizes, perhaps plastic might be a better proposition than wood?
- 740 replies
- Tudor
- restoration
(and 4 more)
SkiBee: You'll save yourself a lot of grief by removing the garboard and completing fairing with the flexible sanding sticks.
- 62 replies
- muscongus bay lobster smack
- Finished
Well, that was a red letter day, Rob! As I looked through your posts I was thinking that there was a book to be written on her - and I'm glad to see that there will be.
- 3,560 replies
- clipper
- hull model
Just make sure that you have adequate ventilation if using a heater. There are too many cases in winter of death from CO poisoning due to faulty heaters or lack of air.
It's a matter of taste. Somehow, to me, machine carvings lack a certain quality that the hand-carved pieces have. They are, perhaps, a little too perfect. Also, the surface finish of a machine tool gives a different surface finish to that of the burnishing produced by an edge tool.
- 589 replies
- le gros ventre
- cargo
How difficult would it be for you to drill the hole now? You don't say what scale you are working at and how advanced your rigging is. If it's possible, I'd use a drill bit in a pin vise and drill by hand rather than with a power drill. Also, hold a piece of scrap wood inside the bulwark to prevent any chipping out as the bit exits.
Again, just catching up to you. I'm relieved to read that you and your family have come through Covid OK. Not a nice experience, I'm sure. Lovely work and progress, JD. Might I suggest that for lining out planking that thread is more precise than tape? Just a little white glue does it. If you need to shift the line a bit, simply moisten a finger and roll the thread. up or down as needed.
Just caught up with you on your build, Dan. Another neat model done. The burgee is a particularly nice detail. The lively sea is a tough thing to model, but the prop wsh is very convincing. Congratulations!
- 33 replies
- James B Colgate
- whaleback
At the bow it looks as if the third bulkhead needs more fairing; the garboard looks too high at that point. Are you using flexible sanding sticks to fair? If not, do try them.
- 62 replies
- Finished
