Everything posted by druxey
Silver soldering - Copper vs Brass
druxey replied to rtropp's topic in Metal Work, Soldering and Metal Fittings
That seems strange, Richard. I assume that it really is copper that you have there. Perhaps someone else can suggest what is going wrong. -
Are all the surfaces clean of all dirt or grease? Are the surfaces in close contact? These are the two most common causes of joint failure. -
ancre Le Fleuron by cabrapente - FINISHED
druxey replied to cabrapente's topic in - Build logs for subjects built 1501 - 1750
You are a brave man: carving those rails already in place!- 332 replies
- le fleuron
- 64 gun
Bee-ootiful, Ed! Your comments on 19th century paint are interesting. I agree that oil based paints dry to a glossy finish, but the addition of turpentine as drying agent will tend to flatten the finish somewhat. Without drying agents in the paint, the film would take weeks if not months to polymerize, i.e. 'dry'. I imagine that the shipyard would have used some turpentine in their paint mix.
- 3,618 replies
- young america
- clipper
Scratch Build George Law rigging question
druxey replied to Boat Doc's topic in Masting, rigging and sails
There are many good books on period rigging. Underhill is certainly one. Another you might consider is Longridge's Cutty Sark. -
to pickle or not pickle, that is the question.
Picking will clean off corrosive flux by-products as well as oxidation on the parts. -
If sails were to be bent to the square yards, one would need the usual assortment of blocks for buntlines, clueless and leechlines attached. Also there would surely be footropes. I believe there were also jackstays fitted during this time period. Presumably there would be mast hoops and brail blocks for the fore and aft sails as well. -
The problem is that virtually any finish forms a sealing film over the wood surfaces. This will always interfere with a good glue bond. There are only three possible solutions: 1) Apply finish only when construction is complete. 2) Scrape off the finish wherever you need to apply glue. 3) Do not apply any finish. The first method is simpler. However, you will need to exercise ingenuity to get into tight corners. The second is labor-intensive and still may not guarantee a good bond. The third method is almost fool-proof. Eternal gratitude accepted!
Kits aren't necessarily historically correct, Rick. Some are better than others, others are flights of fancy. The open exposed toptimbers are more representative of 19th century and early 20th century fishing craft. If you are interested in historically accurate models, there are many, many good books available on the subject.
Some sub-assemblies work: where there is a flat mating surface, such as deadwood to keel. Some are near impossible, unless you are the world's most accurate model maker. The curved stem to knee of the head joint is an example. In that instance, one piece at a time is a better strategy. However, if you want to find out the hard way.... So, the Subaru 4-wheel drive got you to work this morning? Do you get merit points for making it in?
Not sure about tattoo procedures, but two possible ways of transferring patterns to wood are: 1) Graphite paper. This is similar to old-fashioned carbon paper but not greasy or messy. Place a sheet face down over the wood, the paper pattern on top and press through the design with a sharp hard pencil tip. 2) Rubber cement. Coat the wood surface and the back of the paper pattern and allow to dry. Press the surfaces together like contact cement. Cut out to part, then peel off the paper. Rub any remaining rubber cement off the wood with a piece of crepe rubber.
Well, you are a prolific modelmaker, with time for pysanky as well! Nice work on the pintles and straps, Toni.
- 1,449 replies
Lovely so far, Ben. Congratulations! What's next? The counter timbers?
- 889 replies
Proxxon compound table -- Opinions?
druxey replied to rtropp's topic in Modeling tools and Workshop Equipment
I've had no problem with the Proxxon table, which I've been using for several years. Yes, the hand wheels are a bit small in 'throw' and not the most comfortable such as on my watchmakers' cross-slide, but they are useable. I placed a dot of red paint on the '0' of the hand wheels and yellow at the '5', which makes life much easier when counting off turns and decimal fractions of a turn.
