Everything posted by mtaylor
Nice work on the shrouds. Most excellent!!!
- 1,873 replies
- occre
- san ildefonso
Brass Framed Display Case
mtaylor replied to isali's topic in Building, Framing, Planking and plating a ships hull and deck
Ira, Can you show us a photo? -
Sweet work, indeed, Adriaan. If you hadn't pointed out the breaks, I wouldn't have seen of them. That seems to be one of those things in ship building... masting and fixing the broken masts.
- 1,038 replies
- King of the Mississippi
- Artesania Latina
SS Vinal Haven by TBlack - FINISHED
mtaylor replied to TBlack's topic in - Build logs for subjects built 1851 - 1900
- 326 replies
- vinal haven
- steam ship
MDF for forms
mtaylor replied to grsjax's topic in Building, Framing, Planking and plating a ships hull and deck
Ah... indeed, two countries separated by a common language, Norman. -
Phil, As has been said many times before.... go buy your own curling iron. The Admirals don't appreciate us messing with their "tools". Better yet, find the one of the Admiral's you want and go buy her the new one and swap. Small price to pay for "peace in our time". Ulises is correct. For hardwoods, they need soaking. Exceptionally hardwoods like ebony will need repeated soakings and bendings.
I have a question about the bolts with the square heads that you made in Post #94. How did you form the square head? Did you heat them and then shape using the tool you showed earlier? Or did you heat the brass to melting and use that tool as a mold? Wonderful work so far. I'm enjoying watching your technique.
- 55 replies
- mercury
- victory models
Soak them, the wrap in a wet (not dripping) paper towel. It will depend upon the power level of the microwave for the amount of time needed. Test on some scrap if at all possible, first. The basic problem though, is the length of the planks and I suggest using the turntable to evenly distribute the microwave energy. Oh.. and get the Admiral's okie-dokie lest you be consigned to picking oakum and eating bread and water.
Vince, Excellent work. As for where to display them... talk to the folks at your local library or a museum.
- 264 replies
- sovereign of the seas
- mantua
Piet, I like the way you're doing this. Methodical trial and error and it seems to be working out very well.
ancre Le Fleuron by cabrapente - FINISHED
mtaylor replied to cabrapente's topic in - Build logs for subjects built 1501 - 1750
The carriages look great. Seems like scratch building does fill up the scrap box in a hurry, doesn't it?- 332 replies
- le fleuron
- 64 gun
MDF for forms
Wayne, Nope....MDF is usually a brown, smooth and looks like what we knew as Masonite. Might be the same stuff. https://www.google.com/search?q=particle+board&tbm=isch&tbo=u&source=univ&sa=X&ei=86GbUqKrH6q5igLJ7YGQBg&sqi=2&ved=0CEUQsAQ&biw=1348&bih=742#q=mdf&tbm=isch Particle board is wood color, and you can see the chunks of wood. https://www.google.com/search?q=particle+board&tbm=isch&tbo=u&source=univ&sa=X&ei=86GbUqKrH6q5igLJ7YGQBg&sqi=2&ved=0CEUQsAQ&biw=1348&bih=742 Similar but different. -
Well done, Augie. And good advice on pre-bending the planks. Ok.. Novemeber is like over in 30 some hours so you only have to hold out for a bit longer. December will be better.
- 2,191 replies
- confederacy
- Model Shipways
Wasa by Lin Feng - Sergal - 1:60
mtaylor replied to Lin Feng's topic in - Kit build logs for subjects built from 1501 - 1750
Dkettl. Ask your planking question here: http://modelshipworld.com/index.php?/forum/14-building-framing-planking-and-plating-a-ships-hull-and-deck/ I think you'll get more eyes on it and more answers. -
Dave, Very clean work on her/it.... dunno' what these would be called.
- 170 replies
- ogallala
- praire schooner
