Everything posted by mtaylor
I'm alsoi in the PNW and I'd recommend a case. With smokey summers (even if it's just prescribed burns) and the winds coming in off shore do stir up a lot of dust... volcanic dust it seems. Go for a display case. You won't regret it and the admiral will also appreciate not having a dust magnet on the loose.
Welcome to MSW, Dave. Yes.. the Billing kit is not for beginners. Historically, their instructions are not for the faint of heart and sketchy is an understatement as they are really just a guideline as the plans are the important part. Good advise has been given about starting simple and also build logs. You might look into the ModelExpo's beginner's kits.
Hopefully you can find square stock at the size you need. Is 3D printing an option for those?
- 553 replies
- sloop of war
- constellation
(and 3 more)
I have a deep appreciation for the manuals and those who do them. James is exceptional. I say this as former tech writer who did manuals often times without ever seeing the equipment and only the plans. My hat is tipped and I raise a salute.
- 488 replies
- Indefatigable
- Vanguard Models
The area I live in goes from 0% humidity in summer to 100% in winter. With cotton thread I learned after my first rigged model to "pain" the ropes with a mix of 50/50 water and white glue during the dry season. Once that dries, humidity doesn't affect it.
MSW = My special world. Nothing could be closer to the truth than that. Take your time to breathe and cry if you need to.
F-86F-30 Sabre by Javlin - FINISHED - Kinetic - 1/32
mtaylor replied to Javlin's topic in Non-ship/categorised builds
No worries, sir. -
Edited... never mind my asking about a log. It just popped up while I was typing. -
Welcome to MSW. Have you done a search here for Pilar? There are some build logs and it's probable that someone still has the plans that they might let you have. I do suggest you introduce your self here and then make a post here for the plans: https://modelshipworld.com/forum/13-discussions-for-ships-plans-and-project-research-general-research-on-specific-vessels-and-ship-types/
Ventilation Ideas for Sanding in a Small Apartment
mtaylor replied to Glomar's topic in Modeling tools and Workshop Equipment
One thing (among several) I've found that works is window fan that blows out. I open a window on the opposite of the apartment to help set up a draft. When I can't open a window, I use portable air filter system. I also run a shop vac set up where I'm sanding/cutting. -
Harry, there's not a high spot on the deck is there? Have you put the superstructure on a piece of glass as "level test "?
As they went deep into the exploration of the Wasa wreck in the museum, they discovered that her carvings were not monochromatic but rich in colors much like what you are doing. I feel you're pretty close on your philosophy and implementation. Edit... looks like Bill posted while I was typing away and we both agree on your decorative choices.
- 2,696 replies
- heller
- soleil royal
(and 9 more)
