Hello,
at the 3rd attempt I made a real brass disc with a diameter of 1.7 mm and a thickness of 0.5 mm and inserted it into the block.
Compared to the imitated disks, the difference is only marginal and does not justify the additional effort.
I will probably make the "fake block".
Johann, I agree, probably not work all the work, but still amazing that you are able to fabricate such small working details with such scale appearance. Well done.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
... 1.7 mm x .5mm  sheaves???.....that is simply astonishing. How in the world is one even able to apply the groove to the perimeter of the sheave?
Built & De-Commissioned: HMS Endeavour (Corel), HMS Unicorn (Corel),
Abandoned: HMS Bounty (AL)
Completed : Wappen Von Hamburg (Corel), Le Renommee (Euromodel)... on hold
Current WIP: Berlin by Corel
On Shelf:  HMS Bounty (Billings),
Such precision work. Simply amazing.
-Brian
Current Builds:        Completed Builds:
Planning my next adventure.        HMB Endeavor: Artesania Latina
        USS Constitution - Cross Section: Mamoli
Non-Ship Builds:        HMS Victory - Cross Section: Corel
New Shipyard        King of the Mississippi - Steamboat: Artesania Latina
        Battle Station Section: Panart (Gallery)
In Dry-dock        Chaperon - 1884 Steamer: Model Shipways
USS Constellation: Aretesania Latina                                                       USS Cairo - 1862 Ironclad: Scratch Build
Flying Fish: Model Shipways        Mississippi River Towboat Caroline N.
@mbp521
@mugje
@rtropp
Hello,
thank you very much for your positive comments.
And thank you all for the many LIKES.
That motivates me a lot.
"Great work.  I'm going to give it a try.  Can you tell me where you got the patterns for the blocks?"
Hello, Richard,
for this special type of block, which is only attached to the shrouds, there are corresponding drawings in the Atlas du Génie Maritime on plate no. 212.
Do you know the Atlas du Génie Maritime ?
This is a collection of technical construction drawings of the French Navy from the 19th century.
Here the corresponding plate no. 212:
@Ponto
".. 1.7 mm x .5mm  sheaves???.....that is simply astonishing. How in the world is one even able to apply the groove to the perimeter of the sheave?"
Excuse me,
unfortunately I did not see your question and therefore did not answer it.
But in the meantime I have posted a series of pictures for the production of these blocks. Maybe you have already seen them.
The groove is simply made with a needle file.
Hi Johann. Thank you  for the how to post on making those tiny blocks  and your work still leaves me on the speechless side. I took a look at the reference you gave on the  Atlas du Génie Maritime and think am going to hang on to that one. Do you know off hand if they have published the Atlas in book form since then? Could be a good one to get. Only item I have that comes close to this is the Encyclopedie Methodique Marine, 3 vols set and 1 vol of plates. Thank you. Gary
The 'Atlas' was never published as a book as such. In fact, it was a collection of loose lithographs that was being added to from time to time. No one institution seems to have a complete collection. The French Service Historique de la Defence (SHD) in Vincennes/Paris has one pretty complete collection. The Musée de la Marine in Paris too. However the Musée des Arts et Metiers in Paris has a collection that has some sheets that are not in the other collections. The Universit of Genoa in Italy also has a quite comprehensive collection: https://duilioship.unige.it/
There is also a collection of thumbnails of it on http://www.shipmodell.com/index_files/0PLAN_ATLAS1.html
Hello,
in the meantime I have made the 1 and 2-disc blocks, the special kind.
So now a total of 30 pieces of this special block type are finished.
As a reminder: it is a kind of guiding block which was fixed in the shrouds. In French these blocks are called "Moques de conduits".
A kind of fairleads, but with discs.
Nicely made Johann.  The attention to detail is marvelous, especially your splice around the Fairleads or "Moques de conduits".
By the way, the disks you refer to are called “sheaves” in English.
No criticism, just trying to help teach like you are teaching all of us what can be accomplished in beautiful scale details. Keep it up 😃
Hello,
the first of these blocks was attached to the main shrouds.
As an aid I used a wooden strip which was covered with a double-sided adhesive tape.
Nevertheless it is a very difficult job to tie up these tiny pieces with Japanese silk yarn.
@Dziadeczek
Thanks for your appreciation.
I have already thought about that. No matter how cleanly you handle the glue, there is always a residue and you might see that.
My philosophy in model making is, only as much glue as absolutely necessary.
I prefer fast-drying solvent-based lacquer (zapon lacquer, as used to protect brass and silver from tarnishing) for this purposes. It is basically invisible and can be loosened with a drop of acetone, if needed. It can also applied in small quantities with a fine brush.
Today I once again felt the need to create a scene in the style of a historical postcard on the battery deck of the French corvette. The "Second Maitre" is from the book "La Marine" from 1843 after an illustration by Morel-Fatio.
