Jesse the hardware mfgs that make door knobs and such out of brass, put a coat of lacquer on the finish to protect it. You might try that on the copper plating. I would try it on some left over plates to make sure it doesn't damage anything. Just a thought. Your ship looks amazing.
Greg
GREG H.
Shaped the pintles & gudgeons. out of a flat brass strip. Drilled holes for pinning to ship. Figured out a way around the soldering. Since the glue wasn't holding the pins on the pintles I made a much longer pin & inserted them up into the wood with CA glue. They are pinned in the notch in the rudder & come straight down laying against the pintles. It looks just like it was attached to the pintle & no one can tell that it goes past the pintle & up into the wood. I did add some CA where they touch in the bend of the pintle. This works well & is very sturdy.
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Thanks guys. It almost stumped me....... almost
I had these super tiny b brass nails from years ago. I wish I could remember where I got them. There are not enough to finish nailing the gudgeons to the stern. The heads on these are much smaller than anything else I have so I am now in the process of painstakingly filing down bigger nail heads to this much smaller size. Need about 15 more. I think I drilled way too many nail holes.
Thank you Jason.
Jesse
Edited by JesseLee
Nice job on the rudder Jesse. If you're looking for those little nails/rivets, you could ask Dirk/Dubz where he gets those small rivets he uses all the time.  :)
GEORGE
That looks amazing!
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Brilliant way to work around the "no solder" issue.  The results are what counts JesseLee.  It's looking really very good.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Saw that I had forgot to make the upper hinge parts at the top of the rudder in the black painted area. Made that & got it all on. Al nails are in & rudder is on.
Outstanding, Jesse.
Good catch! I like it!
-Elijah
Current build(s):
Completed build(s):
Member of:
Glued the letters for name on. I think I got them spaced a little too close together but they are on & I'm not going to undo them.
Attached a few eyebolts & rings
Painted the figurehead. The instructions left it like unpainted wood. I asked Chuck about it & he said it most likely was painted as other figureheads were so this is what I came up with.
Jesse -
I think your letters look GREAT - straight, centered, and evenly spaced.  I hope I can do as well.  I like your choice of paint colors for your figurehead.  She certainly looks like a syren :) (anatomically correct) .  And she looks very much like the real figureheads I remember from nautical museums.
<<Gary>>
current build: SYREN
nearly done:  Fair American, Benjamin W. Latham
future builds:  Emma C. Berry
completed builds:  Rattlesnake, Newsboy, Sultana
I agree with Gary Jesse!  The letters look fine and the figurehead looks better painted, rather than left natural.  :)
Cheers
GEORGE
Letters look fine JesseLee.  Yup, figure heads should be painted and your choice of colors is just great.
Cheers,
                       VOC Ship Surabaya
Thanks guys!
Wow! Amazing work! The figurehead looks great! :)
-Elijah
Current build(s):
Completed build(s):
Member of:
I have put the sweep port lids on. Used the photo etched brass parts supplied for the hinges. Don't have any blackening solution so they are painted black. Used the cast metal pieces for the decorative carvings over the stern ports. Played with different tan & brown acrylic paints to make them look like wood. I cannot however get the quarter badges painted to look like wood. I have tried for almost 2 weeks, even taking it all off 7 starting over 3 times. I just cant seem to make it work with them like it did with the decorative trim so I am starting to see if I can build them with wood. Working on the window frames. This is very slow work & is slowing me down a lot. Will still keep trying with the paint too in case I'm not able to duplicate them.
