Cutter Cheerful 1806 by rafine - FINISHED
Link to comment
Share on other sites
Looks good Bob!
1300 holes drilled by hand?  1300 more to do again?  You're more man than me.  I'd definitely be reaching for a rotary tool of some type...
Wes Cook
Current Build: USF Constitution (Model Shipways)
USF Essex (Scratch build)
MS Syren (build log lost, need to rebuild)
Future Builds: MS Confederacy
Link to comment
Thanks so much Wes and the "likes". I would reach for the rotary tool as well, but, truthfully, i can't use one to drill those holes without slipping and skipping
unless i drill starter holes by hand first.
Bob
Link to comment
Guest Tim I.
Bob,
One thing I have found to help is using a thumb tack to create in an indent for the drill head to sit in. Also working at a very low RPM so as to not "walk" or skip the bit.
I do not know if this helps or not. I know what you mean though. I tend to use a pin vice over a rotary tool more, as it offers much more control. Albeit at the cost of a sore wrist or hand.
Thank you,
Tim
Edited by Tim I.
Link to comment
Fabulous work on the hull Bob - your attention to detail and your precision are an example to us all!
hamilton
MS Glad Tidings (1937) (in need of a refit)HMS Blandford (1719) from Corel HMS GreyhoundFair Rosamund (1832) from OcCre Dos Amigos (missing in action); Amati Hannah (ship in a bottle); Mamoli America (1851)Bluenose fishing schooner (1921) (scratch); Off-Centre Sailing Skiff (scratch)
Link to comment
Lovely job, Bob. On my first model I drilled all the thousands of treenail holes using a pin vice, so know how you felt! I now 'dimple' the surface with a sharp point and can then confidently use a rotary handpiece (a Proxxon in this case) to drill those holes where I want them.
Link to comment
Thanks so much Hamilton, Druxey, Johann and the "likes".
Druxey, actually I've done it both ways -- drilling starter holes by hand and finishing with a Dremel, and drilling all the way by hand. It seems to take about the same time and effort each way.
Bob
Link to comment
I have now completed the lower planking on the port side. This involved the same process used on the starboard side -- planking, tree nailing, final sanding and repainting of the wale. Although the two sides didn't come out exactly identical, they are very close. The hull is now fully planked.
With the completion of this work, it is time to turn my attention inboard and thin down the bulkheads in preparation for the bulwark planking.
Bob
Link to comment
[Although the two sides didn't come out exactly identical, they are very close.]
Are you kidding me Bob?!!! I think we may have different definitions of "close". Very nicely done. Very nice indeed. :)
Link to comment
Thanks so much Dirk, Lionfish, Chuck, Grant, Druxey, Tim and George for the generous comments and also to the "likes" for their continuing interest . Always appreciated.
Bob
Link to comment
beautiful pictures of very beautifil work Bob,
it is a treat for the eyes to look at...
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
A big milestone and well done getting there, Bob.  :cheers:
Link to comment
The word 'pristine' doesn't even come close.  Sit back for a minute and enjoy the view.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Link to comment
Hi Bob. I agree with everyone on the superb, as always, planking job! I can't wait to see the inboard work.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Inboard work underway. I have thinned down the bulkheads and made and added the false deck. This involved a fair amount of effort, but nothing that was particularly difficult or interesting to see.
For the bulkhead thinning, I followed Chuck's lead and started with a Dremel with a rough sanding drum, followed by sanding sticks and chisels. I also added filler strips at the bow and stern to aid in planking and to facilitate the drilling of various holes. When I was satisfied that all  was thin enough and fair, I moved on to the false deck.
The deck was cut from basswood sheet using the template in the plans. I cut it a little oversize and trimmed to fit. Before gluing it in place, I cut the mast hole, the opening for the skylight and the notches for the stern frames. I also marked out the positions of the hatches and companionway and also marked the position of the "deck beams" in preparation for deck planking. I cut the deck into four pieces to make gluing it in place a little easier.
Now, it's on to the interior bulwark planking.
Bob
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
