Glad to see you back in the workshop Danny!  :) Clever jig you tooled up for gratings. I like it!  :)
GEORGE
G'day Danny
Again I'm speechless. The buttons are up to your usual standard. To high for us mortals.
The gratings are also uniquely you! Did you say they were 0.75 mm wide, if so what is the thickness of your saw blade? I would like to know where you got it, so I can get one for my proxxon saw table.
Thanks mate
Greg
"Nothing is impossible, it's only what limitations that you put on yourself make it seems impossible! "
Current log : The Royal Yacht Royal Caroline 1749 1:32 by Greg Ashwood:...
Thank you John, Mark, Nils, Grant, George and Greg :) .
Oops, my mistake Greg - they are actually half that thickness (0.38mm) by 1.4mm wide. I used a 2 1/2" x 0.020" (1.0mm) kerf blade that I bought from Jim Byrnes (Model Machines). I can cut even thinner stock than that, depending on the type of timber. English Box will cut down to almost zero thickness :) .
:cheers:  Danny
Cheers, Danny
Thanks Pat.
The Mainmast Partners on Vulture are rather unusual, being a wedge shape. There are four pieces to them :
The Pump tubes fitted :
:cheers:  Danny
Cheers, Danny
Jaw-dropping work, Danny.
Thank you all for the comments and Likes :) .
I've moved to the External Planking of the Port side, as one of the next steps on the inside is fitting the Port Liners which need to be done after the external planking goes on.
First up is the Wales, which are 4 1/2" thick (real size). The upper strake is parallel while the two lower strakes are in "Top and Butt" configuration. I've made them from Ebony.
The smudges on the wales are from water, as I'd just fitted them and cleaned off the excess glue. I've sanded a very slight bevel on the edges to make them stand out a bit better. The top and bottom strakes have a significant bevel where they meet up with the thinner strakes above and below :
:cheers:  Danny
Cheers, Danny
Hi Danny.
Just catching up of your fabulous cross section.
Very Very nice. Your attention to detail is spot on.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
G'day Danny.
Again immaculate work. Your knowledge is so vast and I, for one thank you so much for sharing it with us.
I've got another question. I think it was in your last build. You mentioned that you left spaces in the internal planking for fresh air below decks. But where does the fresh air comes from?
Thanks again mate
Greg
Thank you Pat, Anthony, Greg and Greg :) .
Natural circulation as hotter air rises I guess Greg.
Hi all,
It seems like an age since I last updated the log, but I've been busy with the tedious (but fun) work of planking and treenailing the hull :
I've clear coated the hull inside and out to the level of the wales. Further work on Drift Rails etc will be done before I go higher :
I also fitted the afore-mentioned Port Liners :
:cheers:  Danny
Cheers, Danny
I'll be coming back to this last posting of yours a few times yet!
Edited by AON
Alan O'Neill
G'day Danny
As usual work is excellent. I wish I had half your talent and I'll be a 'happy chappy'. Love your details in the tree nails.
Thanks Robin! There must be a vent or something above deck to allow for fresh air to circulate.
Havagooday all
Greg
beautiful work Danny,
planking, treenailing and surface treatment is top notch !
it must be a very delicate job to safely hit every frame twice for a planks rest (from sheer to keel) with those staggered treenails, well done !
Nils
Current builds
-Lightship Elbe 1
Completed
Dan,
There is a different pattern for the six hull strakes just below the whales that seems to be repeated on the deck. Can you tell me about more about the origins of that pattern.  I only see it rarely in the builds here or the models in museums.
Thanks,
Richard
Richard
Member: The Nautical Research Guild
Thank you all once again for the comments and Likes :) .
Richard, the planking "pattern" is called Top and Butt. It's used in areas of high stress such as the Wales and the 6 planks below them, and also on the Gun Deck where the guns are placed.
:cheers:  Danny
Cheers, Danny
Dan,
Do you know if this was generally used or limited to certain size ships, or ships built by certain nations, etc.?
I really like the way it looks, but would not want to use it incorrectly.
Thanks
Richard
Richard
