Halifax by rafine - FINISHED - The Lumberyard - 1:48 - semi-scratch schooner
7 hours ago, rafine said:
Al, I don't really remember just how long it took, but I'm sure that it was at least two or three weeks.
Bob
I'm sure the kits are put together per order and not on the shelf. I'm in no hurry. I'm not really ready for it anyway. My skills are not quite there yet.
The heart is happiest when the head and the hands work together.
Al
Current Builds:
HMS Halifax 1/48 POF Lumberyard Kit
Model Shipways Glad Tidings
Acoustic Guitar Build FINISHED
Link to comment
Share on other sites
As a break from work on the guns, I decided to complete the detailing of the aft portion of the decks. This involved making and mounting the topsail sheet bitts, finishing and mounting the pumps and permanently mounting the deckhouse/companionway.
The bitts were easy, consisting of boxwood strip pieces slotted with a file for a secure fit together, and pinned and glued to the deck.
The pumps were more work. The tubes had been made and fitted previously (as shown in a prior post). At this point they were completed by making up the mechanism. This consisted of handles cut from styrene sheet, filed to final shape and drilled for small dowels and wire, and brackets for the handles made from wood strip, but painted black to simulate metal. The completed pumps were then mounted through the openings previously made through the upper and lower decks.
The deckhouse/companionway had been made previously (as shown in a prior post) and was merely glued in place at this time.
Now it's back to rigging guns.
Bob
Link to comment
Those cannons are very nice Bob! What have you bee using to finish the carriages and other wooden items?
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Link to comment
very nice work on the pumps and cannons...the aft deck is fitting out nicely  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Thanks so much Elijah, Denis and the "likes".
Elijah, all of the unpainted wood is finished with Minwax satin wipe-on poly. One or two coats, usually applied with a cloth, rubbed down with 000 steel wool, and buffed with a soft cloth.
Bob
Link to comment
Great work on the pumps and the rest of the deck pieces.
Rusty
"So Long For Now" B)
Current Builds: Speedwell
Link to comment
Link to comment
I'm almost to the end of work on the deck. I've now mounted and rigged the remaining four guns, added the cross piece to the fore bitts and permanently mounted the previously made stack for the galley stove. I also threaded the anchor cables through the hawse holes and up through the openings on the forecastle deck (a ticklish job that probably should have been done earlier).
All that remains to be done is the windlass and probably a few cleats for rigging attachment. I'm still working out how to go about doing the windlass.
Bob
Link to comment
A great model Bob,
love all the fitting out details, they are wonderful !
Nils
Current builds
-Lightship Elbe 1
Completed
Link to comment
Link to comment
Really nice work  - love the cannons.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Link to comment
super nice work Bob........the cannons look great!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
After spending a few days up north with family for the Thanksgiving holiday, I'm back and have finished work on the hull and deck. The final work involved making and mounting the windlass, running the anchor cables around the windlass and down into the hold, and adding some cleats. I also remounted the galley stack.
The windlass was made up from boxwood strip, which was drilled and filed for the bars, beveled on the edges and then assembled around end pieces cut and filed to fit the octagonal shape of the windlass barrel. I had to make some small adjustments to the uprights to fit the barrel as made. After mounting the windlass, I wound the anchor cables around it and then ran them down into the hold, where they were glued to rope coils that had been placed down there long ago.
The cleats are 7mm laser cut pieces from Syren, shaped with files and mounted with pins.
This completes work on the hull and deck, except for the swivel guns and anchors, which will be done after the rigging. I will now be moving on to the masting and rigging.
Bob
Link to comment
nice job on the windlass........the deck is really look'in my-t fine  ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
