28 minutes ago, vossiewulf said:
Only thing is to make sure you follow the directions to get correct flow-out and leveling, and you should see if they have an extender to slow drying time if you're applying it in warm weather. It dries plenty fast even with an extender/leveling agent.
I assume you are referring to applying by brush? This one comes in a 400gm spray can with a very fine spray nozzle for even application.
Thanks for the info on the number of coats - that was going to be my next question :D .
BTW - warm weather is not going to be a problem in the near future. We're heading into winter down here, and it can drop below freezing. I have reverse-cycle aircon though :D .
:cheers:  Danny
Cheers, Danny
No, it's too fast-drying in general to be a good brush finish, I've sprayed it whenever I use it. If the temp gets much above 70 degrees F you start to need an extender to give it time to flow out and level before the surface starts hardening.
But if it's in a spray can you're not going to be adding anything to it anyway, so no worries.
It sands very well (cellulose after all) wet if you give it time to dry. Guitar makers would say min 24 hours for that and I agree, it will be gummy if you try to sand too early.
Thanks for the extra info vossiewulf, much appreciated. I intend to spray all the sheets of my next model as soon as I get them, so they'll have plenty of time to dry before sanding while I start on the hull framing (or spend a week looking at the plans :D ).
I've rolled and glued all six Air Ventilators. I'm reasonably happy with the results, considering their size. They look pretty good without magnification :D . I tried my hand at dry-brushing the yellow one, using Artist's Acrylic straight from the tube. The Yellow Ochre is a pretty good match for the printed colour. I'll give it another coat or two before fitting :
The Skylights were a step up from anything I've made so far. They haven't turned out perfect, but acceptable. I learned a few new techniques while constructing these which will come in handy later on :) :
These are the parts for the Capstan. I'm getting rather good at cutting tiny circles, if I say so myself :D . The one on the right is only 1mm in diameter:
:cheers:  Danny
Cheers, Danny
The Capstan has been made and fitted. I'm not totally satisfied with it, and I may pull it back off and do a bit more work to it :
I came up with an idea to improve the round edges of the skylights to make them completely round. I wiped some CA around the edge and sanded it to shape - MUCH better :) . This is what I'm thinking of doing with the Capstan, although I'm in two minds. Maybe I should leave it "warts and all" to show the gradual improvement in my card modelling skills? BTW - I touched up the paintwork on the skylights after I took this pic :
Some Progress Pics with the recent additions fitted :
The Capstan Rollers. There are 10 layers of paper in each one. They will be getting the CA/sanding trick when they dry :
:cheers:  Danny
Cheers, Danny
30 minutes ago, Jim Lad said:
Danny, if you're not completely satisfied with that capstan, then have another go at it - otherwise it will continue to bug you for ever.
Yeah, you're probably right John. There are a LOT of things I'm not completely happy with, but I'm using this model as a training exercise for my next one :D  .
I thought I'd take a pic with my giant oversize fake hand ;) :
:cheers:  Danny
Cheers, Danny
Thanks for looking in John and Rick.
The finished Rollers. The one on the right has had the CA/sanding treatment and been dry-brushed with black acrylic. It looks 100% better than before :) :
All four fitted to the deck :
:cheers:  Danny
Cheers, Danny
Thanks John :) .
Question for Slog - is the AOTS book of Bismarck worth buying? I've seen a few negative Reviews regarding accuracy.
:cheers:  Danny
Cheers, Danny
The Stoppers, or Anchor Chain Guides if you like, are next. Some delicate cutting and folding required :
I kept looking at the Steam Vent (?) pipe and decided to attempt a re-do. You decide if it's an improvement :D :
:cheers:  Danny
Cheers, Danny
4 hours ago, Dan Vad said:
Thanks John :) .
:cheers:  Danny
Hi Danny
your new steam pipe looks much better.
RE Bismarck book I was lucky to pick it up in a sale somewhere. Not sure of its accuracy. I got it more for the 'iron work' as the GPM Bismarck doesn't really give details on this as it's part of the print. I really can't say if worth getting or not as I never got round to using it for my intended purpose. I think I would go for the 3D rendered book if doing it again.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
I guess you mean THIS ONE ? I hope so, because I just ordered it :D . $31.81 with FREE SHIPPING from the UK - gotta love that, it's cheaper than the AOTS book :D .
:cheers:  Danny
Cheers, Danny
Now I'm really starting to go beyond the contract :D - this is the wheel for one of the three Pumps. It's 5mm in diameter, and double thickness 160gsm paper. I don't know if they expected the builder to cut out the inside pieces but I had a go at it anyway - successfully :D . Being double thickness and printed on the reverse side as well I couldn't use CA to stiffen the paper as it took all the print off on a test piece, so it was all cut in the "raw" state. I used the tiny chisel in the pic to cut the inside of the rim - it's not much wider than a sheet of paper :o . After I cut it out I dipped it in CA to strengthen it in preparation for what I thought was going to me a fairly major clean-up. All it needed was a light sand on both sides with extra-fine wet-and-dry - YAY. Then I dry-brushed it Matt Black :
EDIT - After thinking about it a bit more I realised that I COULD stiffen the paper with CA before cutting it out, as long as I applied it on the BACK of the piece. I'm painting them anyway, so it doesn't matter if the print comes off the back. A test piece proved that as long as I was careful it didn't affect the printing on the front side, so I still had lines I could follow :) .
:cheers:  Danny
Cheers, Danny
38 minutes ago, Jim Lad said:
Now it's getting ridiculous, Danny! :o
Isn't it just :D . In fact, I had at look at the completed demonstration models on the Paper Shipwrights site - one has the wheel with a solid centre, the other leaves it off altogether :D :
Remember, this is a practice ship for improving my paper modelling skills. I may as well try a few things out now before the real thing starts. Although I doubt there will be paper details this small on Bismarck - I'd guess they'd be replaced with PE.
:cheers:  Danny
Cheers, Danny
1 hour ago, amateur said:
The second one is different on a lot of details (and major parts also).
Perhaps the wheel isn't missing because they couldn't make it as they wanted :)
Jan, they are from different time periods in the ship's history. Perhaps she had a different pumping system on the one in the 2nd pic? The 2nd one is the more recent version.
Well, using CA on the backs of the pieces before cutting was a success. It was a lot easier (relatively speaking :) ) to cut the wheel legs. Only two more to do :rolleyes: . It looks like I've glued the wheel in crooked - not so. There is a Crank system similar to the Chain Pumps on older ships to be made and fitted, the wheel is at an angle to clear the other deck fittings. All will be revealed later on :) :
I've also made and fitted four Bollards :
:cheers:  Danny
Cheers, Danny
Hey howya goin Danny mate, shes coming along nicely.    :bird-vi:
I'm probably not going to live long enough to build all these but I'm BLOODY going to try HAHAHA.
Future Builds: The Schooner Bluenose, scale 1:48, POF Scratch Build (Gene Bodnar practicum - Plans from modelshipbuilder.com)
                       HMS Victory, scale 1:64 or 1:48, POF Scratch Build (John McKay's plans)
Current Builds: 42ft Longboat Armed for War 1834, scale 1:36 POF Scratch Build (Plans from A.N.C.R.E.)
                        Galley Washington 1776, scale 1:48, POF Scratch Build (NRG's Plans)
                        Ragusian Carrack, scale 1:59, POB kit (MarisStella)
                        King of the Mississippi, scale 1:80, POB Kit (Artesania Latina)
                        HMS Snake 1797, 18 Gun Sloop of War, scale 1:64, POB Kit (Jotika/CalderCraft)
Current Build: Stage Coach 1848, scale 1:10, Kit (Artesania Latina) Shhh don't tell the Admins I'm building this I'll hide it here ^under this line^ so they don't see it HAHAHA.
this lacquer is good to impregnate the printed pages with, after the print. to stabilise the ink used. just spray over using either airbrush, or you could brush it over in thin layer...
Pavol stands for Paul, Pablo, Paolo etc. Please do not try to pronounce it, just call me Pav...
:cheers:  Danny
ahem
http://www.papirove-modely.cz/velkynahled/173530
this here, my friend, is a part of cockpit of the arado plane, from bismarck. and there are parts even smaller. the red "thing" next to it, is a painted tic-tac candy. there are a-a guns that are made off like 20 parts, most of them are too small to grab in your hand.
picture is a courtesy of Martanek411, who is building Bismarck, yamato, Tirpitz, scharnhorst and hood at the same time. what can i say, masochist at the least...
your getting the hang of it ;)   it looks great!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Impressive Pav, but I won't be going there as my eyes and hands aren't what they used to be. Although, considering thickness, my Pumps weren't much bigger than those bits :) .
THESE are the replacement Photo-Etch guns, courtesy of Captain Slog ;) , the same as I'll be making.
:cheers:  Danny
Cheers, Danny
:cheers:  Danny
Hi Danny
believe me they will give your eyes a work out 65+ parts for each gun !
cheers
Slog
Might be time to update my magnifying visor :D .
:cheers:  Danny
Cheers, Danny
Dan, have you decided which Bismarck you going to build? Halinski, gpm, jsc, maly modelarz? Or perhaps one of the free versions?
Hi Pav, the GPM Bismarck (with all the extra PE sets etc) has already been ordered and paid for and is hopefully in transit somewhere between Poland and Australia :D . According to Slog it usually takes around two weeks for orders to arrive, so by the end of next week ....... :)
:cheers:  Danny
Cheers, Danny
