Hello gentlemen !
Following the mistake I made by positioning a black join - not to simulate a caulking - but to show that the barrels were composed of several pieces, I decided to start all over again.
So I trimmed my chopsticks, without the join this time :
Then I ordered copper roll (Petr - my new Czech friend - advised me) :
Back on the lathe, still using a rubber band allowing me to machine both sides of the barrels without damaging them :
Vérification :
Then the result on a serie :
The lids :
For the continuation of the work on these lids, here in pictures, how I proceeded, for those that it could interest :
Then comes the work of copper. I use gloves so as not to 'grease' and I cut small strips corresponding to the size of barrels :
The advantage of this copper roll is that it can be immersed in a liquid without altering the self-adhesive part :
For rinsing, I followed Petr's advice : "Bicarbonate de soude" dissolved in distilled water :
After drying, the copper strips are cut into thin lengths using a ruler and a scalpel, then it is patience :
Nothing complicated, but it's quite long.
In the end, I declined 6 series of barrels :
To obtain 88 barrels :
No more black joints, so it is more in line with reality, but we see less separations between the boards ... Question of choice !
They were the most "big" barrels. There will be others thereafter, but not for the moment : I'm starting to saturate!
See you later !
Patrick
Edited by JOUFF
Beautiful but tedious work.  Well done.
Hello gentlemen and thank you for your encouragement !
Continuing work in the bottom of the hull ...
This remark, from another forum :
Quote
Hello
Nice work, watch out for the rear bunker the cross section is wrong, you have to reduce the housing of the lantern.
Good luck for the future.
Patrick [/ quote]
is quite accurate: if we stick strictly to the cross-sectional plan, it does not work. So I 'managed' with some difficulty to bring all this !
The local of the lantern is not yet glued ...
It suits me, despite the small difficulty compared to the plan! That it serves the following modellers ...
Patrick
Edited by JOUFF
wonderful barrel making Patrick,
Nils
Current builds
-Lightship Elbe 1
Completed
Hello gentlemen !
I continued with the creation of tin plates protecting the bungs of certain barrels:
I picked up a few twigs to make the logs:
Finally, I positioned all this small world at the bottom of the hold :
My little companion stands guard :
Here for the moment, the following in a few times.
Good day to you all !
Patrick
  • 7 months later...
C'est une petite merveille        (a little gem)
Carl
Superbe ! Quelle précision ! et merci de partager votre merveilleux travail !
Jean-Paul
'You are not carving a bear with a chain saw here folks',
Chuck Passaro, ´Queen Anne Style Barge´ manual of instructions
Current builds :
Finished build :
Next on list :
  • HMS Winchelsea 1764 - Syren Ship Model - 1:48
8 hours ago, JOUFF said:
The lantern, following the development of the pieces until I see how to braze them
Lovely job.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Good evening gentlemen and ... thank you for your encouragement!
Finally, after a few tests, I tried the adventure and ... I won !!!!
I was satisfied with a simple little "first price" blowtorch, some paste and a little refractory stone, and here is the result :
The base is not fixed yet ... I'll see for the windows and the candle before. I even managed to close the ring by brazing it.
I think I understood how to braze, finally I made myself a "mountain" when in the end it is not very complicated. Even during my tests I did not manage to melt my pieces (others of course : I did not want to start all over again ! )
To be continued ...
Good evening to you !
Patrick
petite, mais une grande merveille ...        (small but super beautiful)
Carl
